CPU and GPU overheating after upgrading to 1,333 MHz memory
I had 8 GiB of memory in my HP Pavilion dv7-4110em XE287EA#BED working at 1,066 MHz because one of the 2 4-GiB memory modules had a maximum frequency of 1,066 MHz. Today, I replaced that module with a 4-GiB module which can work at 1,333 MHz. So, now my 8 GiB of memory works at 1,333 MHz. Windows work noticeably faster.
However, the CPU and GPU temperatures now go over 90 °C and the laptop goes into hibernation. Is there a way to avoid this - somehow slow down the CPU when the temperature is too high, or similar?
How can I make the laptop go into standby instead of hibernation when this happens?
Saltgrass
Over in the BSOD forum, there is a reference to a program called CPU-Z. Perhaps you could check that sticky and post your results.
There is probably an option in your bios to warn you if the CPU goes above a certain temp. Maybe you could use that to set a lower level.
I think changing the memory might increase the voltage to the CPU, but I am not that acquainted with these operations.
Running a processor at that temp may burn it out, or at least reduce its lifespan. The last time I checked the temp limit of a processor, it was around 180° F. 90°C is about 194° F. Did you replace the memory with the same type?
Details of your system might help folks understand your situation, processor, etc.
nmsuk
Windows Forum Admin
The option in the bios maybe called speedstep.
Short report on my system:
Computer:      Hewlett-Packard HP Pavilion dv7 Notebook PC
CPU:           Intel Core i7-720QM (Clarksfield SV, B1)
               1600 MHz (12.00x133.3) @ 930 MHz (7.00x133.0)
Motherboard:   Hewlett-Packard 1449
Chipset:       Intel HM55 (IbexPeak-M DH)
Memory:        8192 MBytes @ 664 MHz, 9.0-9-9-24
               - 4096 MB PC10600 DDR3 SDRAM - Samsung M471B5273CH0-CH9
               - 4096 MB PC10600 DDR3 SDRAM - Transcend JM1333KSN-4G
Graphics:      ATI Mobility RADEON HD 5650 [HP]
               ATI Mobility RADEON HD 5650 (MADISON PRO/LP / Capilano PRO/LP/CE), 1024 MB GDDR3 SDRAM
Drive:         WDC WD10TPVT-65HT5T0, 976.8 GB, Serial ATA 3Gb/s
Drive:         hp BD-ROM BC-5501H, BD-ROM
Drive:         hp BD ROM BC-5501H, BD-ROM
Drive:         __RAID__ _DUMMYDEVICE____, DVD-RAM Writer
Drive:         VXDV BD-HD-DVDRAM S15, BD-RE
Sound:         Intel 5 Series/34x0 Chipset PCH - High Definition Audio Controller [B2]
Sound:         ATI Redwood/Madison/Capilano - High Definition Audio Controller
Network:       Ralink RT3090 802.11n 1T/1R PCI-E Wireless Network Adapter
OS:            Microsoft Windows 7 Ultimate (x64) Build 7601
Long report on my system:
HWiNFO64 Version 3.86-1370
NLOVRIC -------------------------------------------------------------------
 [Current Computer]
  Computer Brand Name:                    Hewlett-Packard HP Pavilion dv7 Notebook PC
 [Operating System]
  Operating System:                       Microsoft Windows 7 Ultimate (x64) Build 7601
  Service Pack:                           Service Pack 1
Central Processor(s) ------------------------------------------------------
 [CPU Unit Count]
  Number Of Processor Packages (Physical): 1
  Number Of Processors Cores:             4
  Number Of Logical Processors:           8
Intel Core i7-720QM -------------------------------------------------------
 [General Information]
  Processor Name:                         Intel Core i7-720QM
  Original Processor Frequency:           1600.0 MHz
  Original Processor Frequency [MHz]:     1600
  CPU Brand Name:                         Intel(R) Core(TM) i7 CPU       Q 720  @ 1.60GHz
  CPU Vendor:                             GenuineIntel
  CPU Stepping:                           B1
  CPU Code Name:                          Clarksfield SV
  CPU S-Spec:                             SLBLY
  CPU Thermal Design Power (TDP):         45.0 W
  CPU Thermal Design Current (TDC):       37.0 A
  CPU Type:                               Production Unit
  CPU Platform:                           Socket G1 (rPGA988A)
  Microcode Update Revision:              4
  Number of CPU Cores:                    4
  Number of Logical CPUs:                 8
 [Operating Points]
  CPU LFM (Minimum):                      933.3 MHz = 7.00 x 133.3 MHz
  CPU HFM (Maximum):                      1600.0 MHz = 12.00 x 133.3 MHz
  CPU Turbo:                              2800.0 MHz = 21.00 x 133.3 MHz [Locked]
  CPU Current:                            1462.8 MHz = 11.00 x 133.0 MHz
  Uncore Current:                         1994.8 MHz = 15.00 x 133.0 MHz
  CPU Internal Bus Type:                  Intel QuickPath Interconnect (QPI) v1.0
  Number of QPI Links per CPU:            1
  Maximum Supported QPI Link Clock:       2133 MHz (4.27 GT/s)
  Current QPI Link Clock:                 2127 MHz (4.26 GT/s)
  CPU External Bus Type:                  Intel Direct Media Interface (DMI) v2.0
  Maximum DMI Link Speed:                 2.5 GT/s
  Current DMI Link Speed:                 2.5 GT/s
 [Cache and TLB]
  L1 Cache:                               Instruction: 4 x 32 KBytes, Data: 4 x 32 KBytes
  L2 Cache:                               Integrated: 4 x 256 KBytes
  L3 Cache:                               6 MBytes
  Instruction TLB:                        2MB/4MB Pages, Fully associative, 7 entries
  Data TLB:                               4 KB Pages, 4-way set associative, 64 entries
 [Standard Feature Flags]
  FPU on Chip                             Present
  Enhanced Virtual-86 Mode                Present
  I/O Breakpoints                         Present
  Page Size Extensions                    Present
  Time Stamp Counter                      Present
  Pentium-style Model Specific Registers  Present
  Physical Address Extension              Present
  Machine Check Exception                 Present
  CMPXCHG8B Instruction                   Present
  APIC On Chip / PGE (AMD)                Present
  Fast System Call                        Present
  Memory Type Range Registers             Present
  Page Global Feature                     Present
  Machine Check Architecture              Present
  CMOV Instruction                        Present
  Page Attribute Table                    Present
  36-bit Page Size Extensions             Present
  Processor Number                        Not Present
  CLFLUSH Instruction                     Present
  Debug Trace and EMON Store              Present
  Internal ACPI Support                   Present
  MMX Technology                          Present
  Fast FP Save/Restore (IA MMX-2)         Present
  Streaming SIMD Extensions               Present
  Streaming SIMD Extensions 2             Present
  Self-Snoop                              Present
  Multi-Threading Capable                 Present
  Automatic Clock Control                 Present
  IA-64 Processor                         Not Present
  Signal Break on FERR                    Present
  Streaming SIMD Extensions 3             Present
  Carryless Multiplication (PCLMULQDQ)/GFMUL Not Present
  64-Bit Debug Store                      Present
  MONITOR/MWAIT Support                   Present
  CPL Qualified Debug Store               Present
  Virtual Machine Extensions              Present
  Safer Mode Extensions (Intel TXT)       Present
  Thermal Monitor 2                       Present
  Supplemental Streaming SIMD Extensions 3 Present
  Enhanced SpeedStep Technology           Present
  L1 Context ID                           Not Present
  Segment Limit Checking                  Not Present
  Fused Multiply Add                      Not Present
  CMPXCHG16B Support                      Present
  Send Task Priority Messages Disabling   Present
  Performance/Debug Capability MSR        Present
  Processor Context ID                    Not Present
  Direct Cache Access                     Not Present
  Streaming SIMD Extensions 4.1           Present
  Streaming SIMD Extensions 4.2           Present
  Extended xAPIC                          Not Present
  MOVBE Instruction                       Not Present
  POPCNT Instruction                      Present
  TSC-deadline Timer                      Not Present
  AES Cryptography Support                Not Present
  XSAVE/XRSTOR/XSETBV/XGETBV Instructions Not Present
  XGETBV/XSETBV OS Enabled                Not Present
  AVX Support                             Not Present
  Float16 Instructions                    Not Present
  Random Number Read Instruction          Not Present
 [Extended Feature Flags]
  64-bit Extensions                       Present
  RDTSCP and TSC_AUX Support              Present
  1 GB large page support                 Not Present
  No Execute                              Present
  SYSCALL/SYSRET Support                  Present
 [Enhanced Features]
  Thermal Monitor 1:                      Supported, Enabled
  Thermal Monitor 2:                      Supported, Enabled
  Enhanced Intel SpeedStep (GV3):         Supported, Enabled
  Bi-directional PROCHOT#:                Enabled
  Extended Auto-HALT State C1E:           Enabled
  Extended Stop Grant State C2E:          N/A
  Enhanced Halt State C3E:                N/A
  Enhanced Halt State C4E:                N/A
  Enhanced Halt State Hard C4E:           N/A
  Hardware Prefetcher:                    Not Supported
  DCU Prefetcher:                         Not Supported
  IP Prefetcher:                          Not Supported
  Adjacent Cache Line Prefetch:           Not Supported
  MLC Streamer Prefetcher                 Supported, Enabled
  MLC Spatial Prefetcher                  Supported, Enabled
  DCU Streamer Prefetcher                 Supported, Enabled
  DCU IP Prefetcher                       Supported, Enabled
  Intel Dynamic Acceleration (IDA) Technology: Not Supported
  Intel Dynamic FSB Switching:            Not Supported
  Enhanced Multi Threaded Thermal Management: N/A
  Intel Turbo Boost Technology:           Supported, Enabled
  Programmabe Ratio Limits:               Not Supported
  Programmabe TDC/TDP Limits:             Not Supported
 [IIO Features]
  VT-d:                                   Supported
  TXT:                                    Not Supported
  PCIe Port0:                             Supported
  PCIe Port1:                             Not Supported
  PCIe Port2:                             Supported
  PCIe Port3:                             Not Supported
  PCIe x16:                               Supported
 [Memory Ranges]
  Maximum Physical Address Size:          36-bit (64 GBytes)
  Maximum Virtual Address Size:           48-bit (256 TBytes)
 [MTRRs]
  Range 0-80000000 (0MB-2048MB) Type:     Write Back (WB)
  Range 80000000-C0000000 (2048MB-3072MB) Type: Write Back (WB)
  Range BC000000-C0000000 (3008MB-3072MB) Type: Uncacheable (UC)
  Range FFE00000-100000000 (4094MB-4096MB) Type: Write Protected (WP)
  Range 100000000-200000000 (4096MB-8192MB) Type: Write Back (WB)
  Range 200000000-240000000 (8192MB-9216MB) Type: Write Back (WB)
Motherboard ---------------------------------------------------------------
 [Computer]
 [Motherboard]
  Motherboard Model:                      Hewlett-Packard 1449
  Motherboard Chipset:                    Intel HM55 (IbexPeak-M DH)
  Motherboard Slots:                      2xPCI Express x1, 2xPCI Express x2, 1xPCI Express x16
  PCI Express Version Supported:          v2.0
  USB Version Supported:                  v2.0
 [PCH Features]
  Intel Identity Protection Technology:   Not Supported
  USB 2.0 Ports 6 and 7:                  Supported
  PCI Express Ports 7 and 8:              Not Supported
  FIS Based Port Multiplier:              Not Supported
  SATA Ports 2 and 3:                     Not Supported
  SATA RAID 0/1/5/10:                     Not Supported
 [BIOS]
  BIOS Manufacturer:                      Insyde Software
  BIOS Date:                              10/21/2010
  BIOS Version:                           F.23
  EFI BIOS:                               Capable
  Super-IO/LPC Chip:                      Unknown
 [Driver/BIOS Updates]
ACPI Devices --------------------------------------------------------------
Microsoft AC Adapter ------------------------------------------------------
  Device Name:                            Microsoft AC Adapter
ACPI Fixed Feature Button -------------------------------------------------
  Device Name:                            ACPI Fixed Feature Button
Intel Processor -----------------------------------------------------------
  Device Name:                            Intel Processor
HP Mobile Data Protection Sensor ------------------------------------------
  Device Name:                            HP Mobile Data Protection Sensor
 [Assigned Resources]
  IRQ:                                    23
 [Alternative 1]
  IRQ:                                    23
Intel(R) 82802 Firmware Hub Device ----------------------------------------
  Device Name:                            Intel(R) 82802 Firmware Hub Device
  Memory Location:                        FF000000 - FFFFFFFF
 [Alternative 1]
Programmable interrupt controller -----------------------------------------
  Device Name:                            Programmable interrupt controller
  I/O Port:                               0020 - 0021
  I/O Port:                               0030 - 0031
  I/O Port:                               00A0 - 00A1
  I/O Port:                               00B0 - 00B1
  IRQ:                                    1114369
  IRQ:                                    1114369
  IRQ:                                    1114369
  IRQ:                                    1114369
 [Alternative 1]
  I/O Port:                               0024 - 0025
  I/O Port:                               0028 - 0029
  I/O Port:                               002C - 002D
  I/O Port:                               0034 - 0035
  I/O Port:                               0038 - 0039
  I/O Port:                               003C - 003D
  I/O Port:                               00A4 - 00A5
  I/O Port:                               00A8 - 00A9
  I/O Port:                               00AC - 00AD
  I/O Port:                               00B4 - 00B5
  I/O Port:                               00B8 - 00B9
  I/O Port:                               00BC - 00BD
  I/O Port:                               04D0 - 04D1
System timer --------------------------------------------------------------
  Device Name:                            System timer
  I/O Port:                               0040 - 0043
  DMA:                                    0
 [Alternative 1]
  I/O Port:                               0050 - 0053
  IRQ:                                    0
High precision event timer ------------------------------------------------
  Device Name:                            High precision event timer
  Memory Location:                        FED00000 - FED003FF
 [Alternative 1]
Direct memory access controller -------------------------------------------
  Device Name:                            Direct memory access controller
  I/O Port:                               0000 - 001F
 [Alternative 1]
  I/O Port:                               0081 - 0091
  I/O Port:                               0093 - 009F
  I/O Port:                               00C0 - 00DF
  DMA:                                    4
Standard PS/2 Keyboard ----------------------------------------------------
  Device Name:                            Standard PS/2 Keyboard
  I/O Port:                               0060
  I/O Port:                               0000
 [Alternative 1]
  I/O Port:                               0060
  I/O Port:                               0064
  IRQ:                                    1
PCI bus -------------------------------------------------------------------
  Device Name:                            PCI bus
 [Alternative 1]
  I/O Port:                               0000 - FFFFFFFF
  Memory Location:                        000A0000 - 000BFFFF
 [Alternative 1]
  I/O Port:                               0000 - 0CF7
  I/O Port:                               0D00 - FFFF
  Memory Location:                        C0000000 - FEAFFFFF
System CMOS/real time clock -----------------------------------------------
  Device Name:                            System CMOS/real time clock
  I/O Port:                               0070 - 0077
 [Alternative 1]
  IRQ:                                    8
Motherboard resources -----------------------------------------------------
  Device Name:                            Motherboard resources
  Memory Location:                        FED1C000 - FED1FFFF
  Memory Location:                        FED90000 - FED93FFF
 [Alternative 1]
  Memory Location:                        FED1B000 - FED1BFFF
  Memory Location:                        F0000000 - F1FFFFFF
  Memory Location:                        FED20000 - FED3FFFF
  Memory Location:                        FEE00000 - FEEFFFFF
  Memory Location:                        D4200000 - D4200FFF
  I/O Port:                               002E - 002F
  I/O Port:                               0065
  I/O Port:                               0000 - 006F
  I/O Port:                               0092
  I/O Port:                               FFFF
  I/O Port:                               0000 - 03FF
  IRQ:                                    1114369
  IRQ:                                    1114369
 [Alternative 1]
  I/O Port:                               004E - 004F
  I/O Port:                               0061
  I/O Port:                               0063
  I/O Port:                               0065
  I/O Port:                               0067
  I/O Port:                               0070
  I/O Port:                               0080
  I/O Port:                               0092
  I/O Port:                               00B2 - 00B3
  I/O Port:                               0680 - 069F
  I/O Port:                               0800 - 080F
  I/O Port:                               FFFF
  I/O Port:                               FFFF
  I/O Port:                               0400 - 047F
  I/O Port:                               0500 - 057F
  I/O Port:                               164E - 164F
  I/O Port:                               0380 - 038E
Numeric data processor ----------------------------------------------------
  Device Name:                            Numeric data processor
  I/O Port:                               00F0
 [Alternative 1]
  I/O Port:                               00F0
  IRQ:                                    13
Microsoft ACPI-Compliant Embedded Controller ------------------------------
  Device Name:                            Microsoft ACPI-Compliant Embedded Controller
  I/O Port:                               0062
 [Alternative 1]
  I/O Port:                               0062
  I/O Port:                               0066
Microsoft ACPI-Compliant Control Method Battery ---------------------------
  Device Name:                            Microsoft ACPI-Compliant Control Method Battery
ACPI Power Button ---------------------------------------------------------
  Device Name:                            ACPI Power Button
ACPI Lid ------------------------------------------------------------------
  Device Name:                            ACPI Lid
Microsoft Windows Management Interface for ACPI ---------------------------
  Device Name:                            Microsoft Windows Management Interface for ACPI
Synaptics PS/2 Port TouchPad ----------------------------------------------
  Device Name:                            Synaptics PS/2 Port TouchPad
  IRQ:                                    12
 [Alternative 1]
  IRQ:                                    12
ACPI Thermal Zone ---------------------------------------------------------
  Device Name:                            ACPI Thermal Zone
SMBIOS DMI ----------------------------------------------------------------
BIOS ----------------------------------------------------------------------
  BIOS Vendor:                            Hewlett-Packard
  BIOS Version:                           F.23
  BIOS Release Date:                      10/21/2010
  BIOS Start Segment:                     0
  BIOS Size:                              1536 KBytes
  ISA Support:                            Not Present
  MCA Support:                            Not Present
  EISA Support:                           Not Present
  PCI Support:                            Present
  PC Card (PCMCIA) Support:               Not Present
  Plug-and-Play Support:                  Not Present
  APM Support:                            Not Present
  Flash BIOS:                             Present
  BIOS Shadow:                            Present
  VL-VESA Support:                        Not Present
  ESCD Support:                           Not Present
  Boot from CD:                           Present
  Selectable Boot:                        Present
  BIOS ROM Socketed:                      Not Present
  Boot from PC Card:                      Not Present
  EDD Support:                            Present
  NEC PC-98 Support:                      Not Present
  ACPI Support:                           Present
  USB Legacy Support:                     Present
  AGP Support:                            Not Present
  I2O Boot Support:                       Not Present
  LS-120 Boot Support:                    Not Present
  ATAPI ZIP Drive Boot Support:           Not Present
  IEE1394 Boot Support:                   Not Present
  Smart Battery Support:                  Not Present
 [BIOS Updates]
System --------------------------------------------------------------------
  System Manufacturer:                    Hewlett-Packard
  Product Name:                           HP Pavilion dv7 Notebook PC
  Product Version:                        0589110000242B20010020100
  SKU Number:                             XE287EA#BED
  Family:                                 103C_5335KV
 [Driver Updates]
Mainboard -----------------------------------------------------------------
  Mainboard Manufacturer:                 Hewlett-Packard
  Mainboard Name:                         1449
  Mainboard Version:                      65.35
  Asset Tag:                              Base Board Asset Tag
  Location in chassis:                    Base Board Chassis Location
System Enclosure ----------------------------------------------------------
  Case Type:                              Notebook
  Version:                                N/A
  Asset Tag Number:
System Slots --------------------------------------------------------------
PCI Express Graphic X16 ---------------------------------------------------
  Slot Designation:                       PCI Express Graphic X16
  Slot Type:                              PCI Express x16
  Slot Usage:                             Empty
  Slot Data Bus Width:                    16x / x16
  Slot Length:                            Unknown
PCI Express X1-0 ----------------------------------------------------------
  Slot Designation:                       PCI Express X1-0
  Slot Type:                              PCI Express x2
  Slot Usage:                             Empty
  Slot Data Bus Width:                    1x / x1
PCI Express X1-1 ----------------------------------------------------------
  Slot Designation:                       PCI Express X1-1
  Slot Usage:                             Empty
On Board Device -----------------------------------------------------------
  Device Description:                     Video Graphics Controller
  Device Type:                            Video Adapter
  Device Status:                          <Enabled>
  Device Description:                     Realtek Lan Controller
  Device Type:                            Ethernet Adapter
OEM Strings ---------------------------------------------------------------
System Configuration Options ----------------------------------------------
System Event Log ----------------------------------------------------------
Built-in Pointing Device --------------------------------------------------
  Device Type:                            Touch Pad
  Interface Type:                         PS/2
  Nuber of Buttons:                       4
Portable Battery ----------------------------------------------------------
  Battery Location:                       In the back
  Battery Manufacturer:                   13DP-SDI51
  Manufacture Date:                       Unknown
  Device Name:                            MU06055
  Device Chemistry:                       Lithium-ion
  Design Capacity:                        5100 mWh
  Design Voltage:                         10800 mV
  SBDS Verison Number:                    3.1
  Max. Error in Battery Data:             1
  SBDS Manufacture Date:                  8/27/26
  SBDS Device Chemistry:                  LION
System Boot Information ---------------------------------------------------
  Boot Status:                            No error occured
  Device Description:                     Ralink RT3090 802.11b/g/n WiFi Adapter
  Device Type:                            Unknown
  Device Status:                          <Disabled>
  Device Description:                     Unknown
  Device Description:                     ATI Mobility Radeon HD 5650
  Device Description:
  Device Description:
Intel vPro ----------------------------------------------------------------
  CPU VT-x Support:                       Supported
  CPU VT-x Status:                        Enabled
  CPU VT-x2 Support:                      Not Supported
  CPU VT-x2 Status:                       Disabled
  CPU TXT Support:                        Supported
  CPU TXT Status:                         Disabled
  CPU VMX Status:                         Enabled
  CPU SMX Status:                         Enabled
  Intel ME Status:                        Enabled
  Intel OST Firmware Support:             Not Supported
  Intel ASF Firmware Support:             Not Supported
  Intel AMT Pro Firmware Support:         Not Supported
  Intel AMT Basic Firmware Support:       Not Supported
  Intel TPM Firmware Support:             Not Supported
  Intel Anti-Theft Technology Support:    Not Supported
  Intel Castle Peak Support:              Not Supported
  Intel WoX Support:                      Not Supported
  Intel Virtualization Engine Support:    Not Supported
  Intel TDT Support:                      Not Supported
  TPM On-board:                           Not Supported
  Intel ME Version:                       v6.1, Build 1045, Hotfix 1
  BIOS VT-x Support:                      Not Supported
  BIOS VT-d Support:                      Supported
  BIOS TXT Support:                       Supported
  BIOS TPM Support:                       Not Supported
  BIOS ME Support:                        Supported
  BIOS VA Extensions Support:             Supported
  SPI Flash PDR Reserved:                 Supported
  BIOS VA Support:                        2.6
Processor -----------------------------------------------------------------
  Processor Manufacturer:                 Intel(R) Corporation
  Processor Version:                      Intel(R) Core(TM) i7 CPU       Q 720  @ 1.60GHz
  External Clock:                         1066 MHz
  Maximum Clock Supported:                1600 MHz
  Current Clock:                          1600 MHz
  CPU Socket:                             Populated
  CPU Status:                             Enabled
  Processor Type:                         Central Processor
  Processor Voltage:                      1.2 V
  Processor Upgrade:                      ZIF
  Socket Designation:                     CPU
 [Driver Updates]
L3 Cache ------------------------------------------------------------------
  Socket Designation:                     L3 Cache
  Cache State:                            Enabled
  Cache Type:                             Internal, Unified
  Cache Scheme:                           Write-Through
  Supported SRAM Type:                    Synchronous
  Current SRAM Type:                      Synchronous
  Cache Speed:                            Unknown
  Error Correction Type:
  Maximum Cache Size:                     6144 KBytes
  Installed Cache Size:                   6144 KBytes
  Cache Associativity:                    Unknown
L1 Cache ------------------------------------------------------------------
  Socket Designation:                     L1 Cache
  Cache Type:                             Internal, Data
  Maximum Cache Size:                     32 KBytes
  Installed Cache Size:                   32 KBytes
  Cache Associativity:                    8-way Set-Associative
L2 Cache ------------------------------------------------------------------
  Socket Designation:                     L2 Cache
  Maximum Cache Size:                     256 KBytes
  Installed Cache Size:                   256 KBytes
  Cache Type:                             Internal, Instruction
  Cache Associativity:                    4-way Set-Associative
Memory Devices ------------------------------------------------------------
Physical Memory Array -----------------------------------------------------
  Array Location:                         System board
  Array Use:                              System memory
  Error Detecting Method:                 None
  Memory Capacity:                        8388608 KBytes
  Memory Devices:                         2
Memory Device -------------------------------------------------------------
  Total Width:                            64 bits
  Data Width:                             64 bits
  Device Size:                            4096 MBytes
  Device Form Factor:                     SODIMM
  Device Locator:                         Bottom - Slot 1
  Bank Locator:                           BANK 0
  Device Type Detail:                     Synchronous
  Memory Speed:                           1333 MHz
  Manufacturer:                           Samsung
  Part Number:                            M471B5273CH0-CH9
  Asset Tag:                              Unknown
32-bit Memory Error Information -------------------------------------------
Memory Device Mapped Address ----------------------------------------------
  Starting Address:                       00000000
  Ending Address:                         003FFFFF
  Partition Row Position:                 2
  Interleave Position:                    1
  Interleave Data Depth:                  1
  Data Width:                             64 bits
  Device Locator:                         Bottom - Slot 2
  Bank Locator:                           BANK 1
  Manufacturer:                           Transcend
  Part Number:                            JM1333KSN-4G
  Asset Tag:                              Unknown
  Interleave Position:                    2
Memory Array Mapped Address -----------------------------------------------
  Ending Address:                         007FFFFF
  Partition Width:                        2
Memory --------------------------------------------------------------------
 [General information]
  Total Memory Size:                      8 GBytes
  Total Memory Size [MB]:                 8192
 [Current Performance Settings]
  Maximum Supported Memory Clock:         666.7 MHz (5 : 1 ratio)
  Current Memory Clock:                   664.9 MHz (5 : 1 ratio)
  Current Timing (tCAS-tRCD-tRP-tRAS):    9.0-9-9-24
  Memory Runs At:                         Dual-Channel
  Command Rate:                           1T
  Read to Read Delay (tRD_RD) Same Rank:  4T
  Read to Read Delay (tRD_RD) Different Rank: 6T
  Read to Read Delay (tRD_RD) Different DIMM: 7T
  Write to Write Delay (tWR_WR) Same Rank: 4T
  Write to Write Delay (tWR_WR) Different Rank: 7T
  Write to Write Delay (tWR_WR) Different DIMM: 7T
  Read to Write Delay (tRD_WR) Same Rank: 10T
  Read to Write Delay (tRD_WR) Different Rank: 10T
  Read to Write Delay (tRD_WR) Different DIMM: 10T
  Write to Read Delay (tWR_RD) Same Rank (tWTR): 16T
  Write to Read Delay (tWR_RD) Different Rank: 5T
  Write to Read Delay (tWR_RD) Different DIMM: 5T
  Read to Precharge Delay (tRTP):         5T
  Write to Precharge Delay (tWTP/tWR):    21T
  RAS# to RAS# Delay (tRRD):              4T
  Refresh Cycle Time (tRFC):              107T
  Four Activate Window (tFAW):            20T
Row: 0 - 4096 MB PC3-10600 DDR3 SDRAM Samsung M471B5273CH0-CH9 ------------
 [General Module Information]
  Module Number:                          0
  Module Size:                            4096 MBytes
  Memory Type:                            DDR3 SDRAM
  Module Type:                            SO-DIMM
  Memory Speed:                           666.7 MHz (PC3-10600)
  Module Manufacturer:                    Samsung
  Module Part Number:                     M471B5273CH0-CH9
  Module Revision:                        0
  Module Manufacturing Date:              Year: 2010, Week: 39
  Module Manufacturing Location:          1
  SDRAM Manufacturer:                     Samsung
  Error Check/Correction:                 None
 [Module characteristics]
  Row Address Bits:                       15
  Column Address Bits:                    10
  Number Of Banks:                        8
  Module Density:                         2048 Mb
  Number Of Ranks:                        2
  Device Width:                           8 bits
  Bus Width:                              64 bits
  Module Nominal Voltage (VDD):           1.5 V
 [Module timing]
  Minimum SDRAM Cycle Time (tCKmin):      1.500 ns
  CAS# Latencies Supported:               5, 6, 7, 8, 9
  Minimum CAS# Latency Time (tAAmin):     13.125 ns
  Minimum RAS# to CAS# Delay (tRCDmin):   13.125 ns
  Minimum Row Precharge Time (tRPmin):    13.125 ns
  Minimum Active to Precharge Time (tRASmin): 36.000 ns
  Supported Module Timing at 666.7 MHz:   9-9-9-24
  Supported Module Timing at 533.3 MHz:   7-7-7-20
  Supported Module Timing at 400.0 MHz:   6-6-6-15
  Supported Module Timing at 333.3 MHz:   5-5-5-12
  Minimum Write Recovery Time (tWRmin):   15.000 ns
  Minimum Row Active to Row Active Delay (tRRDmin): 6.000 ns
  Minimum Active to Active/Refresh Time (tRCmin): 49.125 ns
  Minimum Refresh Recovery Time Delay (tRFCmin): 160.000 ns
  Minimum Internal Write to Read Command Delay (tWTRmin): 7.500 ns
  Minimum Internal Read to Precharge Command Delay (tRTPmin): 7.500 ns
  Minimum Four Activate Window Delay Time (tFAWmin): 30.000 ns
 [Features]
  On-die Thermal Sensor (ODTS) Readout:   Not Supported
  Auto Self Refresh (ASR):                Not Supported
  Extended Temperature Refresh Rate:      Not Supported
  Extended Temperature Range:             Supported
  Module Temperature Sensor:              Not Supported
  Module Nominal Height:                  29 - 30 mm
  Module Maximum Thickness (Front):       1 - 2 mm
  Module Maximum Thickness (Back):        1 - 2 mm
Row: 2 - 4096 MB PC3-10600 DDR3 SDRAM Transcend JM1333KSN-4G --------------
  Module Number:                          2
  Module Manufacturer:                    Transcend
  Module Part Number:                     JM1333KSN-4G
  Module Revision:                        0
  Module Manufacturing Date:              Year: 2011, Week: 37
  Module Manufacturing Location:          84
  SDRAM Manufacturer:                     Unknown
  Number Of Banks:                        8
  Number Of Ranks:                        2
  Bus Width:                              64 bits
 [Module timing]
 [Features]
  Auto Self Refresh (ASR):                Supported
Bus -----------------------------------------------------------------------
PCI Bus #0 ----------------------------------------------------------------
Intel Clarksfield IIO - DMI Host Bridge [B1] ------------------------------
  Device Name:                            Intel Clarksfield IIO - DMI Host Bridge [B1]
  Original Device Name:                   Intel Clarksfield IIO - DMI Host Bridge [B1]
  Device Class:                           Host-to-PCI Bridge
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          0
  Function Number:                        0
  PCI Latency Timer:                      0
  Hardware ID:                            PCI\VEN_8086&DEV_D132&SUBSYS_1449103C&REV_11
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
  Bus Mastering:                          Disabled
  Running At 66 MHz:                      Not Capable
  Fast Back-to-Back Transactions:         Not Capable
 [Driver Updates]
Intel Lynnfield/Clarksfield IIO - PCI Express Root Port 1 (x16/x8) [B1] ---
  Device Name:                            Intel Lynnfield/Clarksfield IIO - PCI Express Root Port 1 (x16/x8) [B1]
  Original Device Name:                   Intel Lynnfield/Clarksfield IIO - PCI Express Root Port 1 (x16/x8) [B1]
  Device Class:                           PCI-to-PCI Bridge
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          3
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_D138&SUBSYS_00000000&REV_11
 [PCI Express]
  Version:                                2.0
  Maximum Link Width:                     16x
  Current Link Width:                     16x
  Maximum Link Speed:                     5.0 Gb/s
  Current Link Speed:                     5.0 Gb/s
  Device/Port Type:                       Root Port of PCI Express Root Complex
  Slot Implemented:                       Yes
  Hot-Plug:                               Not Capable
  Hot-Plug Surprise:                      Not Capable
  Active State Power Management (ASPM) Support: L0s and L1
  Active State Power Management (ASPM) Status: L0s and L1 Entry
 [System Resources]
  Interrupt Line:                         IRQ16
  Interrupt Pin:                          INTA#
 [Features]
  Bus Mastering:                          Enabled
 [Driver Updates]
PCI Express x16 Bus #1 ----------------------------------------------------
ATI Mobility RADEON HD 5650 [HP] ------------------------------------------
  Device Name:                            ATI Mobility RADEON HD 5650 [HP]
  Original Device Name:                   ATI Mobility RADEON HD 5650 (MADISON PRO/LP / Capilano PRO/LP/CE)
  Device Class:                           VGA Compatible Adapter
  Revision ID:                            0
  Bus Number:                             1
  Device Number:                          0
  Function Number:                        0
  Hardware ID:                            PCI\VEN_1002&DEV_68C1&SUBSYS_1449103C&REV_00
 [PCI Express]
  Version:                                2.0
  Device/Port Type:                       Legacy PCI Express Endpoint
  Slot Implemented:                       No
 [System Resources]
  Interrupt Line:                         N/A
  Memory Base Address 0                   C0000000
  Memory Base Address 2                   D4000000
  I/O Base Address 4                      4000
 [Features]
 [Driver Updates]
ATI Redwood/Madison/Capilano - High Definition Audio Controller -----------
  Device Name:                            ATI Redwood/Madison/Capilano - High Definition Audio Controller
  Original Device Name:                   ATI Redwood/Madison/Capilano - High Definition Audio Controller
  Device Class:                           Mixed mode device
  Revision ID:                            0
  Bus Number:                             1
  Device Number:                          0
  Function Number:                        1
  Hardware ID:                            PCI\VEN_1002&DEV_AA60&SUBSYS_1449103C&REV_00
 [PCI Express]
  Version:                                2.0
 [System Resources]
  Interrupt Line:                         IRQ17
  Interrupt Pin:                          INTB#
  Memory Base Address 0                   D4020000
 [Features]
 [Driver Updates]
Intel Lynnfield/Clarksfield IIO - Address Mapping/VT-d/System Management Control [B1]
  Device Name:                            Intel Lynnfield/Clarksfield IIO - Address Mapping/VT-d/System Management Control [B1]
  Original Device Name:                   Intel Lynnfield/Clarksfield IIO - Address Mapping/VT-d/System Management Control [B1]
  Device Class:                           Unknown Peripheral Device
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          8
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_D155&SUBSYS_0049003C&REV_11
 [PCI Express]
  Version:                                2.0
  Current Link Width:                     Not negotiated
  Device/Port Type:                       Root Complex Integrated Endpoint
  Active State Power Management (ASPM) Status: Disabled
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel Lynnfield/Clarksfield IIO - Semaphore and Scratchpad Control [B1] ---
  Device Name:                            Intel Lynnfield/Clarksfield IIO - Semaphore and Scratchpad Control [B1]
  Original Device Name:                   Intel Lynnfield/Clarksfield IIO - Semaphore and Scratchpad Control [B1]
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          8
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_D156&SUBSYS_0049003C&REV_11
 [PCI Express]
  Version:                                2.0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel Lynnfield/Clarksfield IIO - System Control/Status [B1] --------------
  Device Name:                            Intel Lynnfield/Clarksfield IIO - System Control/Status [B1]
  Original Device Name:                   Intel Lynnfield/Clarksfield IIO - System Control/Status [B1]
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          8
  Function Number:                        2
  Hardware ID:                            PCI\VEN_8086&DEV_D157&SUBSYS_0049003C&REV_11
 [PCI Express]
  Version:                                2.0
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel Lynnfield/Clarksfield IIO - Miscellaneous Control [B1] --------------
  Device Name:                            Intel Lynnfield/Clarksfield IIO - Miscellaneous Control [B1]
  Original Device Name:                   Intel Lynnfield/Clarksfield IIO - Miscellaneous Control [B1]
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          8
  Function Number:                        3
  Hardware ID:                            PCI\VEN_8086&DEV_D158&SUBSYS_0049003C&REV_11
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel Lynnfield/Clarksfield IIO - QuickPath Interconnect Link [B1] --------
  Device Name:                            Intel Lynnfield/Clarksfield IIO - QuickPath Interconnect Link [B1]
  Original Device Name:                   Intel Lynnfield/Clarksfield IIO - QuickPath Interconnect Link [B1]
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          16
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_D150&SUBSYS_0049003C&REV_11
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel Lynnfield/Clarksfield IIO - QuickPath Interconnect Routing and Protocol [B1]
  Device Name:                            Intel Lynnfield/Clarksfield IIO - QuickPath Interconnect Routing and Protocol [B1]
  Original Device Name:                   Intel Lynnfield/Clarksfield IIO - QuickPath Interconnect Routing and Protocol [B1]
  Revision ID:                            11
  Bus Number:                             0
  Device Number:                          16
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_D151&SUBSYS_0049003C&REV_11
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel 5 Series/34x0 Chipset PCH - Host Embedded Controller Interface 1 (HECI1) [B3]
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - Host Embedded Controller Interface 1 (HECI1) [B3]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - Host Embedded Controller Interface 1 (HECI1) [B3]
  Device Class:                           Unknown Communication Device
  Revision ID:                            6
  Bus Number:                             0
  Device Number:                          22
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_3B64&SUBSYS_1449103C&REV_06
 [System Resources]
  Memory Base Address 0                   D4104000
 [Features]
 [Driver Updates]
Intel 5 Series/34x0 Chipset PCH - USB 2.0 EHCI Controller #2 [B2] ---------
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - USB 2.0 EHCI Controller #2 [B2]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - USB 2.0 EHCI Controller #2 [B2]
  Device Class:                           Universal Serial Bus (USB)
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          26
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_3B3C&SUBSYS_1449103C&REV_05
 [System Resources]
  Memory Base Address 0                   D410A000
 [Features]
  Fast Back-to-Back Transactions:         Capable
 [Driver Updates]
Intel 5 Series/34x0 Chipset PCH - High Definition Audio Controller [B2] ---
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - High Definition Audio Controller [B2]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - High Definition Audio Controller [B2]
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          27
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_3B56&SUBSYS_1449103C&REV_05
 [PCI Express]
  Version:                                1.0
  Active State Power Management (ASPM) Support: None
 [System Resources]
  Interrupt Line:                         IRQ22
  Memory Base Address 0                   D4100000
 [Features]
 [Driver Updates]
Intel 5 Series/34x0 Chipset PCH - PCI Express Root Port #1 [B2] -----------
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - PCI Express Root Port #1 [B2]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - PCI Express Root Port #1 [B2]
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          28
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_3B42&SUBSYS_00000000&REV_05
 [PCI Express]
  Version:                                2.0
  Maximum Link Width:                     1x
  Current Link Width:                     1x
  Maximum Link Speed:                     2.5 Gb/s
  Current Link Speed:                     2.5 Gb/s
  Hot-Plug:                               Capable
  Hot-Plug Surprise:                      Capable
  Slot Power Limit:                       10.000 W
 [System Resources]
 [Features]
 [Driver Updates]
PCI Express x1 Bus #2 -----------------------------------------------------
Ralink RT3090 802.11n 1T/1R PCI-E Wireless Network Adapter ----------------
  Device Name:                            Ralink RT3090 802.11n 1T/1R PCI-E Wireless Network Adapter
  Original Device Name:                   Ralink RT3090 802.11n 1T/1R PCI-E Wireless Network Adapter
  Device Class:                           Unknown Network Adapter
  Revision ID:                            0
  Bus Number:                             2
  Device Number:                          0
  Function Number:                        0
  Hardware ID:                            PCI\VEN_1814&DEV_3090&SUBSYS_1453103C&REV_00
 [PCI Express]
  Version:                                2.0
  Device/Port Type:                       PCI Express Endpoint
 [System Resources]
  Interrupt Line:                         N/A
  Memory Base Address 0                   D3000000
 [Features]
 [Driver Updates]
Intel 5 Series/34x0 Chipset PCH - PCI Express Root Port #2 [B2] -----------
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - PCI Express Root Port #2 [B2]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - PCI Express Root Port #2 [B2]
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          28
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_3B44&SUBSYS_00000000&REV_05
 [PCI Express]
  Version:                                2.0
  Hot-Plug:                               Capable
  Active State Power Management (ASPM) Status: L1 Entry
 [System Resources]
 [Features]
 [Driver Updates]
PCI Express x1 Bus #3 -----------------------------------------------------
Intel 5 Series/34x0 Chipset PCH - USB 2.0 EHCI Controller #1 [B2] ---------
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - USB 2.0 EHCI Controller #1 [B2]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - USB 2.0 EHCI Controller #1 [B2]
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          29
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_3B34&SUBSYS_1449103C&REV_05
 [System Resources]
  Interrupt Line:                         IRQ21
  Memory Base Address 0                   D4109000
 [Features]
 [Driver Updates]
Intel 82801xxM Mobile I/O Controller Hub ----------------------------------
  Device Name:                            Intel 82801xxM Mobile I/O Controller Hub
  Original Device Name:                   Intel 82801xxM Mobile I/O Controller Hub
  Revision ID:                            A5
  Bus Number:                             0
  Device Number:                          30
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_A5
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [ICH Configuration]
  High Priority PCI:                      Disabled
  15-16MB Hole:                           Disabled
  Discard Timer Mode [ICH2]:              128 PCICLKs (4 us)
  32-Clock Retry [ICH2]/12-Clock Retry [ICH3/4]: Disabled
 [Multi-Transaction Timer]
  Multi-Transaction Timer Count Value:    0 PCICLKs
 [Error Command]
  SERR# On Target Abort Receive:          Disabled
  SERR# On Delayed Transaction Timeout:   Disabled
 [Driver Updates]
PCI Bus #4 ----------------------------------------------------------------
Intel HM55 Express Chipset - LPC Interface Controller [B2] ----------------
  Device Name:                            Intel HM55 Express Chipset - LPC Interface Controller [B2]
  Original Device Name:                   Intel HM55 Express Chipset - LPC Interface Controller [B2]
  Device Class:                           PCI-to-ISA Bridge
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          31
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_3B09&SUBSYS_1449103C&REV_05
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel 5 Series Chipset-M PCH - SATA AHCI 4-port Controller [B2] -----------
  Device Name:                            Intel 5 Series Chipset-M PCH - SATA AHCI 4-port Controller [B2]
  Original Device Name:                   Intel 5 Series Chipset-M PCH - SATA AHCI 4-port Controller [B2]
  Device Class:                           Serial ATA Controller
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          31
  Function Number:                        2
  Hardware ID:                            PCI\VEN_8086&DEV_3B29&SUBSYS_1449103C&REV_05
 [System Resources]
  Interrupt Line:                         IRQ19
  I/O Base Address 0                      5048
  I/O Base Address 1                      5054
  I/O Base Address 2                      5040
  I/O Base Address 3                      5050
  I/O Base Address 4                      5020
  Memory Base Address 5                   D4108000
 [Features]
  Running At 66 MHz:                      Capable
 [Driver Updates]
Intel 5 Series/34x0 Chipset PCH - SMBus Controller [B2] -------------------
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - SMBus Controller [B2]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - SMBus Controller [B2]
  Device Class:                           SMBus (System Management Bus)
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          31
  Function Number:                        3
  Hardware ID:                            PCI\VEN_8086&DEV_3B30&SUBSYS_1449103C&REV_05
 [System Resources]
  Interrupt Line:                         IRQ10
  Memory Base Address 0                   D4106000
  I/O Base Address 4                      5000
 [Features]
 [Driver Updates]
Intel 5 Series/34x0 Chipset PCH - Thermal Sensor [B2] ---------------------
  Device Name:                            Intel 5 Series/34x0 Chipset PCH - Thermal Sensor [B2]
  Original Device Name:                   Intel 5 Series/34x0 Chipset PCH - Thermal Sensor [B2]
  Device Class:                           Unknown Data Acquisition/Signal Processing Controller
  Revision ID:                            5
  Bus Number:                             0
  Device Number:                          31
  Function Number:                        6
  Hardware ID:                            PCI\VEN_8086&DEV_3B32&SUBSYS_1449103C&REV_05
 [System Resources]
  Interrupt Line:                         N/A
  Memory Base Address 0                   0
 [Features]
 [Driver Updates]
PCI Bus #127 --------------------------------------------------------------
Intel QuickPath Architecture - Generic Non-core (Uncore) Registers --------
  Device Name:                            Intel QuickPath Architecture - Generic Non-core (Uncore) Registers
  Original Device Name:                   Intel QuickPath Architecture - Generic Non-core (Uncore) Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          0
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_2C52&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Architecture - System Address Decoder (SAD) ---------------
  Device Name:                            Intel QuickPath Architecture - System Address Decoder (SAD)
  Original Device Name:                   Intel QuickPath Architecture - System Address Decoder (SAD)
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          0
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_2C81&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Interconnect - QPI Link 0 Control -------------------------
  Device Name:                            Intel QuickPath Interconnect - QPI Link 0 Control
  Original Device Name:                   Intel QuickPath Interconnect - QPI Link 0 Control
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          2
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_2C90&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Interconnect - QPI Physical 0 Control ---------------------
  Device Name:                            Intel QuickPath Interconnect - QPI Physical 0 Control
  Original Device Name:                   Intel QuickPath Interconnect - QPI Physical 0 Control
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          2
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_2C91&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller -----------------------------------------
  Device Name:                            Intel QuickPath Memory Controller
  Original Device Name:                   Intel QuickPath Memory Controller
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          3
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_2C98&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Target Address Decode -----------------
  Device Name:                            Intel QuickPath Memory Controller - Target Address Decode
  Original Device Name:                   Intel QuickPath Memory Controller - Target Address Decode
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          3
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_2C99&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Test Registers ------------------------
  Device Name:                            Intel QuickPath Memory Controller - Test Registers
  Original Device Name:                   Intel QuickPath Memory Controller - Test Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          3
  Function Number:                        4
  Hardware ID:                            PCI\VEN_8086&DEV_2C9C&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel0 Control Registers ------------
  Device Name:                            Intel QuickPath Memory Controller - Channel0 Control Registers
  Original Device Name:                   Intel QuickPath Memory Controller - Channel0 Control Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          4
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_2CA0&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel0 Address Registers ------------
  Device Name:                            Intel QuickPath Memory Controller - Channel0 Address Registers
  Original Device Name:                   Intel QuickPath Memory Controller - Channel0 Address Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          4
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_2CA1&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel0 Rank Registers ---------------
  Device Name:                            Intel QuickPath Memory Controller - Channel0 Rank Registers
  Original Device Name:                   Intel QuickPath Memory Controller - Channel0 Rank Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          4
  Function Number:                        2
  Hardware ID:                            PCI\VEN_8086&DEV_2CA2&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel0 Thermal Control --------------
  Device Name:                            Intel QuickPath Memory Controller - Channel0 Thermal Control
  Original Device Name:                   Intel QuickPath Memory Controller - Channel0 Thermal Control
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          4
  Function Number:                        3
  Hardware ID:                            PCI\VEN_8086&DEV_2CA3&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel1 Control Registers ------------
  Device Name:                            Intel QuickPath Memory Controller - Channel1 Control Registers
  Original Device Name:                   Intel QuickPath Memory Controller - Channel1 Control Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          5
  Function Number:                        0
  Hardware ID:                            PCI\VEN_8086&DEV_2CA8&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel1 Address Registers ------------
  Device Name:                            Intel QuickPath Memory Controller - Channel1 Address Registers
  Original Device Name:                   Intel QuickPath Memory Controller - Channel1 Address Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          5
  Function Number:                        1
  Hardware ID:                            PCI\VEN_8086&DEV_2CA9&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel1 Rank Registers ---------------
  Device Name:                            Intel QuickPath Memory Controller - Channel1 Rank Registers
  Original Device Name:                   Intel QuickPath Memory Controller - Channel1 Rank Registers
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          5
  Function Number:                        2
  Hardware ID:                            PCI\VEN_8086&DEV_2CAA&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Intel QuickPath Memory Controller - Channel1 Thermal Control --------------
  Device Name:                            Intel QuickPath Memory Controller - Channel1 Thermal Control
  Original Device Name:                   Intel QuickPath Memory Controller - Channel1 Thermal Control
  Revision ID:                            4
  Bus Number:                             127
  Device Number:                          5
  Function Number:                        3
  Hardware ID:                            PCI\VEN_8086&DEV_2CAB&SUBSYS_1449103C&REV_04
 [System Resources]
  Interrupt Line:                         N/A
  Interrupt Pin:                          N/A
 [Features]
 [Driver Updates]
Video Adapter -------------------------------------------------------------
ATI Mobility RADEON HD 5650 (MADISON PRO/LP / Capilano PRO/LP/CE) ---------
 [Video chipset]
  Video Chipset:                          ATI Mobility RADEON HD 5650 (MADISON PRO/LP / Capilano PRO/LP/CE)
  Video Memory:                           1024 MBytes of GDDR3 SDRAM
 [Video Card]
  Video Card:                             ATI Mobility RADEON HD 5650 [HP]
  Video Bus:                              PCIe v2.0 x16 (5.0 Gb/s) @ x16 (5.0 Gb/s)
  Video BIOS Version:                     012.019.000.013.038421
 [Performance]
  Processor Clock:                        550.0 MHz
  Memory Clock:                           796.5 MHz (Effective 1593.0 MHz)
  Memory Bus Width:                       128-bit
  Number Of Pixel Pipelines:              16
  Number Of Unified Shaders:              400
 [Driver Updates]
Monitor -------------------------------------------------------------------
LG Philips [Unknown Model: LGD027A] ---------------------------------------
  Monitor Name:                           LG Philips [Unknown Model: LGD027A]
  Monitor Name (Manuf):                   LP173WD1-TLC3
  Date Of Manufacture:                    Week: 0, Year: 2009
  Monitor Hardware ID:                    Monitor\LGD027A
  Max. Vertical Size:                     21 cm
  Max. Horizontal Size:                   38 cm
 [Advanced parameters]
  Input Signal:                           Digital
  Display Type:                           RGB color
  Gamma Factor:                           2.20
 [DPMS Modes]
  Standby:                                Not Supported
  Suspend:                                Not Supported
  Active Off:                             Not Supported
  Standard Colour Space:                  Not Supported
  Preferred Timing Mode:                  Supported
  Default GTF Supported:                  Not Supported
  DFP 1.x Compatible:                     No
 [Supported Video Modes]
  1600 x 900                              382 x 215 mm, Pixel Clock 97.75 MHz
Drives --------------------------------------------------------------------
Floppy Drives -------------------------------------------------------------
(S)ATA/ATAPI Drives -------------------------------------------------------
WDC WD10TPVT-65HT5T0 ------------------------------------------------------
  Drive Controller:                       Serial ATA 3Gb/s
  Drive Model:                            WDC WD10TPVT-65HT5T0
  Drive Revision:                         01.01A01
  Drive Capacity:                         953,869 MBytes (1000 GB)
  Drive Capacity [MB]:                    953869
  Media Rotation Rate:                    5200 RPM
 [Drive Geometry]
  Number of Cylinders:                    16383
  Number of Heads:                        16
  Sectors Per Track:                      63
  Bytes Per Sector:                       Unknown
  Bytes Per Track:                        Unknown
  Number Of ECC Bytes:                    50
  Number of Sectors:                      16514064
  Total 32-bit LBA Sectors:               268435455
  Total 48-bit LBA Sectors:               1953525168
  Cache Buffer Size:                      8192 KBytes
  Controller Type:                        Not Specified
 [Transfer Modes]
  Sectors Per Interrupt:                  Total: 16, Active: 0
  Max. PIO Transfer Mode:                 4
  Multiword DMA Mode:                     Total: 2, Active: 0
  Singleword DMA Mode:                    Total: -, Active: -
  Ultra-DMA Mode:                         Total: 6 (ATA-133), Inactive
  Max. Multiword DMA Transfer Rate:       16.7 MBytes/s
  Max. PIO with IORDY Transfer Rate:      16.7 MBytes/s
  Max. PIO w/o IORDY Transfer Rate:       16.7 MBytes/s
  Transfer Width:                         16-bit
  Native Command Queuing:                 Supported, Max. Depth: 32
  TRIM Command:                           Not Supported
 [Device flags]
  Fixed Drive:                            Present
  Removable Drive:                        Not Present
  Magnetic Storage:                       Present
  LBA Mode:                               Supported
  DMA Mode:                               Supported
  IORDY:                                  Supported
  IORDY Disableable:                      Supported
 [Features]
  Write Cache:                            Present, Active
  S.M.A.R.T. Feature:                     Present, Active
  Security Feature:                       Present, Inactive
  Removable Media Feature:                Not Present, Disabled
  Power Management:                       Present, Active
  Advanced Power Management:              Present, Active
  Packet Interface:                       Not Present, Disabled
  Look-Ahead Buffer:                      Present, Active
  Host Protected Area:                    Not Present, Disabled
  Power-Up In Standby:                    Not Suppported, Inactive
  Automatic Acoustic Management:          Not Suppported, Inactive
  48-bit LBA:                             Supported, Active
 [Self-Monitoring, Analysis and Reporting Technology]
  Raw Read Error Rate:                    200/51, Worst: 200
  Spin Up Time:                           199/21, Worst: 196 (Data = 3050)
  Start/Stop Count:                       100/Always OK, Worst: 100 (Data = 477)
  Reallocated Sector Count:               200/140, Worst: 200
  Seek Error Rate:                        200/Always OK, Worst: 198
  Power-On Hours/Cycle Count:             96/Always OK, Worst: 96 (Data = 3560)
  Spin Retry Count:                       100/Always OK, Worst: 100
  Calibration Retry Count:                100/Always OK, Worst: 100
  Power Cycle Count:                      100/Always OK, Worst: 100 (Data = 463)
  Power-Off Retract Count:                200/Always OK, Worst: 200 (Data = 37)
  Load/Unload Cycle Count:                199/Always OK, Worst: 199 (Data = 4251)
  Temperature                             118/Always OK, Worst: 101 (Data = 32.0 °C)
  Reallocation Event Count:               200/Always OK, Worst: 200
  Current Pending Sector Count:           200/Always OK, Worst: 200
  Off-Line Uncorrectable Sector Count:    100/Always OK, Worst: 253
  UltraDMA/SATA CRC Error Rate:           200/Always OK, Worst: 200
  Write Error Rate:                       100/Always OK, Worst: 253
hp BD-ROM BC-5501H --------------------------------------------------------
  Drive Model:                            hp BD-ROM BC-5501H
  Drive Revision:                         2.88
  Drive Type:                             BD-ROM
  Drive Controller:                       Serial ATA 1.5Gb/s
 [Transfer Modes]
  Multiword DMA Mode:                     Total: 2, Active: -
  Ultra-DMA Mode:                         Total: 5 (ATA-100), Active: 5 (ATA-100)
 [Device flags]
  Removable Drive:                        Present
  Magnetic Storage:                       Not Present
  LBA Mode:                               Supported
  DMA Mode:                               Supported
  IORDY:                                  Supported
 [Device capabilities]
  Drive can read:                         CD-R, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL, BD
  Drive can write:                        CD-R, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
hp BD ROM BC-5501H --------------------------------------------------------
  Drive Model:                            hp BD ROM BC-5501H
  Device Type:                            BD-ROM
__RAID__ _DUMMYDEVICE____ -------------------------------------------------
  Drive Model:                            __RAID__ _DUMMYDEVICE____
  Drive Revision:                         ____
  Device Type:                            DVD-RAM Writer
  Drive can read:                         CD-R, DVD-RAM
  Drive can write:                        CD-R, DVD-RAM
VXDV BD-HD-DVDRAM S15 -----------------------------------------------------
  Drive Model:                            VXDV BD-HD-DVDRAM S15
  Drive Revision:                         10.0
  Device Type:                            BD-RE
  Drive can read:                         CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL, BD, BD-RE
  Drive can write:                        CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL, BD, BD-RE
Audio ---------------------------------------------------------------------
  Audio Adapter:                          Intel 5 Series/34x0 Chipset PCH - High Definition Audio Controller [B2]
  Audio Controller Hardware ID:           PCI\VEN_8086&DEV_3B56&SUBSYS_1449103C&REV_05
  High Definition Audio Codec:            IDT 92HD81B1X
  Audio Codec Hardware ID:                HDAUDIO\FUNC_01&VEN_111D&DEV_7605&SUBSYS_00000000
 [Driver Updates]
  Audio Adapter:                          ATI Redwood/Madison/Capilano - High Definition Audio Controller
  Audio Controller Hardware ID:           PCI\VEN_1002&DEV_AA60&SUBSYS_1449103C&REV_00
  High Definition Audio Codec:            ATi RADEON HDMI
  Audio Codec Hardware ID:                HDAUDIO\FUNC_02&VEN_1002&DEV_AA01&SUBSYS_00000000
 [Driver Updates]
Network -------------------------------------------------------------------
  Network Card:                           Ralink RT3090 802.11n 1T/1R PCI-E Wireless Network Adapter
  Vendor Description:                     Microsoft
  MAC Address:                            E0-2A-82-18-82-A3
 [Capabilities]
  Maximum Link Speed:                     300 Mbps
  Transmit Buffer Size:                   6201344 Bytes
  Receive Buffer Size:                    6201344 Bytes
 [Driver Updates]
Ports ---------------------------------------------------------------------
Serial Ports --------------------------------------------------------------
Parallel Ports ------------------------------------------------------------
USB -----------------------------------------------------------------------
Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
USB Hub -------------------------------------------------------------------
[Port1] : No Device Connected ---------------------------------------------
[Port2] : USB Input Device ------------------------------------------------
  Device Manufacturer:
  Product Name:
  USB Version Supported:                  2.00
  Driver Description:                     USB Input Device
  Hardware ID:                            USB\VID_046D&PID_C06C
[Port3] : Ralink Motorola BC4 Bluetooth 3.0+HS Adapter --------------------
  Product Name:
  Driver Description:                     Ralink Motorola BC4 Bluetooth 3.0+HS Adapter
  Hardware ID:                            USB\VID_148F&PID_1000
[Port4] : No Device Connected ---------------------------------------------
[Port5] : No Device Connected ---------------------------------------------
[Port6] : No Device Connected ---------------------------------------------
[Port2] : No Device Connected ---------------------------------------------
[Port3] : No Device Connected ---------------------------------------------
Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
[Port1] : USB Composite Device --------------------------------------------
  Device Manufacturer:                    HUAWEI
  Product Name:                           HUAWEI Mobile
  Driver Description:                     USB Composite Device
  Hardware ID:                            USB\VID_12D1&PID_1C05
[Port3] : Validity Sensor (VFS301) ----------------------------------------
  Product Name:
  USB Version Supported:                  1.10
  Driver Description:                     Validity Sensor (VFS301)
  Hardware ID:                            USB\VID_138A&PID_0005
[Port5] : USB Composite Device --------------------------------------------
  Product Name:
  Hardware ID:                            USB\VID_0BDA&PID_5801
[Port7] : No Device Connected ---------------------------------------------
[Port8] : No Device Connected ---------------------------------------------
Smart Battery -------------------------------------------------------------
Battery #0 ----------------------------------------------------------------
 [General Properties]
  Device Name:                            Primary
  Manufacturer Name:                      Hewlett-Packard
  Unique ID:                               Hewlett-PackardPrimary
  Chemistry:                              Lithium Ion
  Designed Capacity:                      48038 mWh
  Full Charged Capacity:                  48038 mWh
  Wear Level:                             0.0 %
 [Current Power Status]
  Power Status:                           Charging On AC Power
  Current Capacity:                       38707 mWh (80.6 %)
  Current Voltage:                        12.175 V
The overheating occurs while running Microsoft Update in VMware Workstation on two virtual systems. Also, my entire disk is encrypted using TrueCrypt, so all read-write operations are CPU-intensive.
I cannot access my BIOS as it is protected with a password. That's the way I got it when I bought it. Will removing the mainboard battery make it forget the password or not? How long should I keep the battery removed?
Why is the GPU overheating, also, and not just the CPU?
Solved. I placed two 8 - 9 mm planks beneath the laptop and now the temperature is usually 70-something °C. When I ran an AES, AES-Twofish, Serpent, AES-Twofish, Serpent-AES, Twofish-Serpent, AES-Twofish-Serpent, and Serpent-Twofish-AES encryption and decryption benchmark with TrueCrypt on 1 GiB of data, the temperature of core 2 (numbering starting with 0) reached 97 °C before the benchmark was completed.
Also, the laptop is very fast now; perhaps twice as fast as it was before I installed 1,333 MHz memory and placed planks below it. I estimate that it was operating at 80-something or 90-something °C before, but I never checked the temperature because it didn't cause any problems obviously related to the temperature, such as emergency hibernation.
Ok, I'm still having problems. It overheats sometimes even with the planks. It has been overheating since I bought it; however, it never shut down due to overheating before I inserted 1,333 MHz memory modules.
How hot are your CPUs and GPUs? Mine are around 80 °C while working normally.
