nehoma
Honorable Member
According to my CPU frequency monitors (Z and Aida64) my CPU frequency is stuck at 800Mhz..
A test of the CPU shows it reaches 3,5 Mhz But it does not go up and down under different loads.
any Ideas please.
CPU intel i74407K. 3500MHz Haswell
Mother Board MSI Z87-GD65
Windows 7
Hi Pete,
try checking the CPU using this app HWinfo64:
http://www.hwinfo.com/download.php
When it opens click the sensors checkbox. If you then watch the figures and open something like the control panel, grab it and move it around. You should see the speed rise and fall. If you don't then check under the advanced power options via the control panel. Usual settings for a cpu is 5% idle and 100% at load.
Hi Pete,
Pauli
Fantastic Member
CPU-Z is a nice program, http://www.cpuid.com/softwares/cpu-z.html
You don't have anything in the BIOS? Underclocking? Voltages? Go and make "Preferred defaults", and check it. Clear CMOS, take out the battery, unplug your computer from any current. Take some fifteen minutes of patience. Perhaps get a new battery for CMOS? Then try a ride.
You haven't overclocked your system, at a point of time? That may cause damage.
Mike
Windows Forum Admin
According to my CPU frequency monitors (Z and Aida64) my CPU frequency is stuck at 800Mb..
any Ideas please.
Windows 7
Check CPU temps as it could be throttling down to avoid a CPU overheat condition.
Pauli
Fantastic Member
Our mentality is strongly attached to updating and upgrading. Quite often I have noticed that the path to original was the salvation. Basics may be the soil.
Mike
Windows Forum Admin
Hmm... any luck on this @nehoma? Looking forward to your feedback and results.
Annotation
(The title of this thread was moderator edited to correct the error of describing "GHZ" as "MB" FYI)
