CPU Usage Meter Problem
Henry
Hello,
I have a problem with my CPU Usage Meter gadget in my Windows Sidebar. The numbers in it (such as 58%) seems to be missing. Here is the picture of my problem:
Also, every time I load up my PC, there is a RunDLL error message that says: Error loading winllk32.rom - The specified module cannot be found. Could this be my problem? Any comments and feedback would be greatly appreciated. :)
Note: I am using Windows Vista Home Premium
Thanks in advance,
Henry
Celestra
Former Moderator
Hi! I think it means you had a recent infection. Have you? I'm not sure about the meter, perhaps some files were damaged ? Maybe you should re-install your meter and see what happens... ? Here is a link you can look at: rundll error loading C:\windows\system32\bridge.dll - Windows XP Support If you had an infection, your anti virus-spy ware removed the malware files, but not the reference that loads it- my thought. (Boy it's shaking and rolling in these parts here tonight- Earthquake) The problem on the link is close to yours..... I believe it's the same thing in Vista. Maybe you should run a scan!
Henry
Hello,
Thanks for the answer! I've ran a full scan with Norton AntiVirus 2009 and found the following:
8 Tracking Cookies
1 Trojan.Dropper
1 Downloader
Anyway, thanks for your time and I'll check out the link. :)
