The landscape of industrial cybersecurity is evolving at a rapid pace, and recent advisories from authoritative bodies like CISA are crucial reading for any stakeholder in operational technology or critical infrastructure. Among the latest updates is a significant alert concerning vulnerabilities in ABB’s MV Drives, which rely on the widely used CODESYS runtime system. The scale, sophistication, and potential impacts of these flaws present an exemplary case for examining the broader risks facing connected industrial environments, as well as the ongoing challenges of vulnerability management in operational technology (OT).
'Critical Cybersecurity Alert: Protecting Industrial Drives from ABB and CODESYS Vulnerabilities'
A Wake-Up Call from CISA: ABB MV Drives and CODESYS RTS​
ABB’s MV Drives are common sights in facilities from manufacturing plants to utilities worldwide. These powerful pieces of equipment are core components—regulating motors and process automation—and are typically expected to run reliably for years on end. However, this illusion of permanence and security can be shattered with the disclosure of vulnerabilities that can be exploited remotely and with low attack complexity. Such is the case highlighted in CISA’s recent alert, where a suite of vulnerabilities—ranging from improper restriction of operations within memory buffers to out-of-bounds writes—have been discovered in various versions of ABB’s MV Drives employing the CODESYS RTS (Runtime System).
According to ABB’s own reporting, affected products include the ACS6080, ACS5000, and ACS6000 series (spanning specific firmware versions). Successful exploitation could allow an attacker to gain full control, disrupt operations, or provoke a denial-of-service (DoS) condition. Given the widespread deployment of these drives and their presence in critical infrastructure, the stakes are undeniably high.
CVEs, Scores, and the Anatomy of the Flaws​
The CVEs assigned to these vulnerabilities (such as CVE-2022-4046 and a range of closely related CVEs in the CVE-2023-37545 to CVE-2023-37559 series) tell a story of both individual threat and systemic risk. Examining the technical details, several recurring issues emerge:
  • Improper Restriction of Operation within the Bounds of a Memory Buffer: This classic but dangerous flaw permits attackers with authenticated access to manipulate memory, potentially gaining full device control.
  • Improper Input Validation: Flaws in how data is handled can lead to memory corruption or the processing of dangerous requests.
  • Out-of-Bounds Write: Buffer overflows allow writing past the intended memory space, often resulting in a system crash or code execution.
Remarkably, most of these issues require only low complexity to exploit and are achievable remotely, provided the attacker can achieve successful authentication. The CVSS (Common Vulnerability Scoring System) base scores—for both v3.1 and the more granular v4—range from 6.5 to 8.8, underscoring that these are not mere theoretical risks.
In practice, flaws in the processing of network requests by compromised components such as CmpApp, CmpAppBP, and CmpAppForce could allow a threat actor to read from invalid internal addresses or overwrite buffers, culminating in persistent DoS attacks.
Risk Evaluation and Real-World Implications​
While cybersecurity advisories often focus on theoretical possibility, the real-world impact here is apparent. Industrial drives are foundational to automated processes—and interruptions can halt production lines, disrupt energy delivery, or affect water treatment operations. The adversarial focus on OT and ICS (Industrial Control System) targets is well-documented. Flaws that can be weaponized for remote code execution or operational disruption are especially highly prized by both financially motivated cybercriminals and advanced persistent threats.
It is worth highlighting an important nuance: Each of these vulnerabilities requires the attacker to possess legitimate credentials or otherwise achieve a successful login. While that mitigates opportunistic attack scenarios to an extent, credential theft and abuse attacks are rising sharply, and the presence of such flaws expands the potential blast radius should initial access be achieved through phishing, social engineering, or exploitation of other weaknesses.
Many industrial environments operate under the assumption of air-gapping or limited network exposure, but time and again, breaches have demonstrated that defense-in-depth strategies must be backed up with technical controls, vigilant monitoring, and a culture of security hygiene.
ABB’s Response: Mitigations and Workarounds​
ABB, to its credit, has acted with urgency and transparency. The company is urging all affected customers to upgrade immediately to firmware version LAAAB v5.07 or higher. This update addresses the CODESYS runtime vulnerabilities in the following ways:
  • Disabling IEC Online Programming Communication by Default: With this configuration, CODESYS programming sessions between the drive and ABB development tools (like Automation Builder or Drive Application Builder) are blocked unless specifically allowed.
  • Allowing On-Demand Debugging with Explicit User Action: Should communication with the CODESYS RTS be required (for instance, to debug), users must interactively unlock this function by changing specific drive parameters. The company stresses that this access should be promptly re-disabled post-maintenance or debugging tasks.
ABB also outlines a set of granular workaround procedures for scenarios where immediate updating is not feasible. Chief among these is setting parameters that disable file download capability, thereby preventing attackers from uploading malicious or malformed programs. Notably, enabling or disabling such functions is multi-step and must be carefully managed, with stern warnings about safeguards (such as the criticality of retaining passcodes for user locks, as loss could inhibit even ABB from restoring access).
A forthcoming firmware update is anticipated to further reinforce the CODESYS library, illustrating ABB’s recognition that the secure lifecycle of industrial devices must be ongoing—not “set and forget.”
Defense-in-Depth: Network Isolation and Hardening​
Beyond software updates, ABB and CISA’s recommendations follow best practices for ICS environments. The core message: these devices must not be soft targets. Key points include:
  • Network Isolation: Drives should reside on their own isolated networks—segregated from general-purpose IT systems, office networks, and especially from the public internet. Any remote management or development work should occur from computers dedicated solely to that environment.
  • Physical Security: Only authorized staff should have physical or network-layer access to drives and bridging systems.
  • Operational Discipline: Never connect programming computers to untrusted networks. Only run well-audited software on these devices, and keep all components updated with operating system and cybersecurity patches.
  • Attack Surface Minimization: Disable unnecessary services and features. Enforce strong authentication for all control and maintenance activities.
  • Monitoring and Threat Detection: Operators should deploy network monitoring capable of catching malformed traffic or excessive communications that could presage an attack or ongoing exploit attempt.
Social Engineering and the Insider Threat​
While the vulnerabilities discussed are technical in nature, the requirement for valid authentication underscores the persistent risk from both insider threats and credential compromise via phishing. CISA reiterates fundamental advice—do not open unsolicited emails, attachments, or links, and invest in continuous security training for all staff with access to critical systems.
For high-value targets like ICS and OT, attackers only need one successful social engineering link to bridge air-gaps or gain the necessary foothold. Thus, technical controls must be layered atop robust human processes.
The Challenge with Industrial Patch Management​
One of the often-overlooked complications in ICS/OT environments is the practical reality of patch management. Unlike consumer or enterprise IT, where system restarts or patches may be rapidly deployed with minimal business impact, industrial environments may have restricted change windows. Drives and other OT devices are frequently expected to operate night and day, and unplanned downtime can result in six-figure losses or greater.
This challenge can lead to a delay between vulnerability disclosure and widespread patch deployment—effectively creating a window of vulnerability that motivated attackers can exploit. Consequently, compensating controls (such as network zone segmentation, enhanced monitoring, and strict configuration management) remain essential even after vulnerabilities are publicly disclosed.
No Evidence of Exploitation—For Now​
As of the advisory’s publication, both ABB and CISA affirm that there is no known evidence of public exploitation targeting these particular vulnerabilities. However, history suggests that such assurances have a limited shelf life once technical details are widely known. The pattern, whether with Stuxnet or more recent ICS attacks, is that threat actors move quickly to capitalize on gaps between patch availability and deployment. This makes it all the more urgent for asset owners to act decisively and comprehensively.
Broader Implications for the OT Supply Chain​
ABB is not unusual in its reliance on CODESYS—a common runtime environment used broadly in industrial automation. This episode is a microcosm of a systemic challenge: vulnerabilities in shared ICS software stacks can have a cascading impact across countless OEMs and manufacturer-specific devices. Supply chain attacks, where adversaries exploit weaknesses in third-party code or development environments, are on the rise.
This becomes a critical concern when the vulnerabilities reside not just in the code shipped by ABB, but in libraries utilized across multiple vendors. Thus, responsible vulnerability disclosure, rapid communications, and cross-industry collaboration become essential for meaningful risk reduction.
The Road Ahead: Investing in Industrial Cyber Resilience​
Ultimately, the lessons from this episode echo beyond ABB or any single product class. Industrial cybersecurity is not a checkbox exercise but a multidimensional challenge—with technical, operational, and human layers. From rigorous access control and promptly applying security updates to ensuring that network architectures reflect “zero trust” principles, the onus on industrial operators has never been greater.
There is, however, reason for cautious optimism. The transparency displayed by ABB in working with CISA, the specificity of mitigation guidance provided, and the proactive steps to update and strengthen platform security are all hallmarks of a maturing industrial cybersecurity sector. Asset owners who act on this advice—rather than waiting for the next incident—will be best positioned to defend their operations in an increasingly contested digital landscape.
Action Items for Windows and OT Practitioners​
For those managing Windows-based infrastructure integrated with OT systems, several immediate actions are recommended:
  • Review all deployments of ABB MV Drives and identify affected firmware versions.
  • Coordinate with procurement and engineering teams to plan and schedule firmware upgrades.
  • Audit network topology and fortify isolation measures, ensuring drives are not bridged to broader IT networks.
  • Update security policies to reflect the advisory, ensuring compliance with recommended access control, patch management, and monitoring protocols.
  • Invest in staff training to reinforce vigilance against phishing, social engineering, and credential theft.
Conclusion: Security is a Journey, Not a Destination​
Industrial environments are inherently high-value targets for cyber adversaries. The ABB/CODESYS vulnerability advisory, with its detailed technical breakdown, scoring transparency, and prescriptive mitigation, represents a best-in-class example of both responsible disclosure and constructive guidance. But ultimately, security cannot be any stronger than the weakest link—be it a forgotten software update, an unwatched network port, or a single compromised credential.
As more industrial devices become connected and programmable, the surface area for attackers will only grow. Continuous vigilance, investment in security best practices, and a commitment to rapid, enterprise-wide patch deployment are the only reliable defenses. Those who learn from these advisories—and move from reactive to proactive defense—will safeguard not only their own operations but the broader stability and safety of the communities and industries they serve.
Source: www.cisa.gov ABB MV Drives | CISA
