CVE-2024-57974: Azure Linux attestation and risk to other Microsoft products
Cloud server with a Linux penguin on stacked hardware, CSAF/VEX shield, checklist, magnifier, and CVE-2024-57974.
Microsoft’s MSRC entry for CVE-2024-57974 correctly states that Azure Linux includes the upstream open‑source component and is therefore potentially affected, but that wording is an inventory attestation — not proof that other Microsoft products cannot contain the same vulnerable code. Azure Linux is the only Microsoft product Microsoft has publicly attested as including the component so far; however, other Microsoft Linux artifacts (WSL kernels, linux-azure builds, CBL‑Mariner-based images, Marketplace appliances and custom images) may also include the same upstream code depending on build-time choices and kernel configuration.
Background / Overview​
Microsoft’s recent vulnerability guidance for CVE-2024-57974 follows a now‑familiar, phased approach: publish machine‑readable CSAF/VEX attestations for product families once inventory mapping is complete (Azure Linux was an early target), and update those attestations if additional product SKUs are later found to ship the implicated upstream component. That means the MSRC statement that Azure Linux “includes this open‑source library and is therefore potentially affected” is an authoritative, product‑scoped signal for Azure Linux customers — and nothing more.
To unpack why this nuance matters, it helps to understand two facts about Linux kernel components and large vendor product lines:
  • Kernel code inclusion is a build‑time artifact: whether a given driver or subsystem (for example, net/kcm or a netfilter/ctnetlink path) is present in a shipped kernel depends on configuration flags (CONFIG_*), whether the code is built-in or modular, and which upstream commit range the vendor backported or included. Different Microsoft artifacts are separate builds and can diverge.
  • A VEX/CSAF attestation is an inventory mapping that tells you what the vendor has validated for that product family at the time of publication. It is deliberately scoped and machine‑readable to facilitate automation. It is not a universal negative assertion about every binary or image the vendor has ever shipped.
Putting these together: the MSRC note is actionable for Azure Linux, but it does not by itself guarantee that WSL kernels, linux‑azure images, Marketplace appliances, or other Microsoft‑distributed kernels are unaffected.
What Microsoft actually said — and why the wording is deliberate​
Microsoft’s security update guide language — the sentence quoted by the user — is a concise inventory statement: “Azure Linux includes the open‑source library and is therefore potentially affected.” That phrasing serves two operational purposes:
  • It gives Azure Linux customers a clear, machine‑readable signal to triage and remediate via CSAF/VEX automation.
  • It documents the scope of Microsoft’s completed inventory work and commits Microsoft to expand that inventory and update CVE/VEX records should additional Microsoft products be discovered to ship the component.
This is a pragmatic rollout model used by large vendors: start with a product family you can inventory end‑to‑end (Azure Linux) and publish deterministic attestations, then grow coverage as internal inventories complete. The trade‑off is that until Microsoft finishes inventorying other SKUs you cannot rely on silence (lack of attestation) as evidence of absence.
Short answer to the user’s question​
  • Is Azure Linux the only Microsoft product that includes the open‑source library and is therefore potentially affected by CVE‑2024‑57974?
    • Short, precise answer: No — not necessarily. Azure Linux is the only Microsoft product Microsoft has publicly attested to include the component at the time of the advisory, but that attestation does not prove other Microsoft products are free of the component. Other Microsoft kernel artifacts could include the same upstream code depending on build/version/configuration.
Technical explanation — why the distinction matters​
Kernel components and vulnerabilities are artifact‑level properties. Whether a given Microsoft image or binary carries the vulnerable code depends on:
  • Kernel version and upstream commit range (which commits were merged or backported).
  • Kernel configuration (CONFIG_* flags that enable/disable subsystems or drivers).
  • Packaging choices (is the driver compiled in, built as a module, or trimmed out entirely?.
  • Whether the vendor applied the upstream fix or backported surgical patches to the stable kernel tree used for that product.
Because each Microsoft product (for example, Azure Linux images, linux‑azure kernels on certain VM families, the WSL2 kernel builds, and internal CBL‑Mariner artifacts) is a separately assembled artifact, inclusion or exclusion of a kernel subsystem is determined independently for each artifact. That’s why the Azure Linux VEX/CSAF mapping only proves the presence of the component in Azure Linux images — it doesn’t prove its absence elsewhere.
Operational impact: what teams should do now​
Microsoft’s attestation for Azure Linux is an authoritative starting point — treat it as a definitive “yes” for Azure Linux images and act immediately if you run those images. At the same time, don’t assume other Microsoft artifacts are safe. The operational checklist below helps field teams verify exposure and remediate across mixed estates.
Immediate triage (first 90 minutes)​
  1. Ingest Microsoft’s CSAF/VEX attestation for CVE‑2024‑57974 into your vulnerability automation pipeline and list all Azure Linux images in scope.
  2. Identify hosts/VMs running Azure Linux images and prioritize patching and rebooting those hosts according to standard change control.
  3. If you run high‑risk workloads (multi‑tenant nodes, NFV/packet processing, CI runners, WSL on developer machines), isolate or schedule them for a maintenance window while you validate kernels.
Artifact‑level verification (next few hours)​
  • On running Linux hosts (VMs or bare metal):
    • Check kernel version: uname -r
    • Inspect the kernel config: zgrep CONFIG_* /proc/config.gz or check /boot/config-$(uname -r)
    • Search for the presence of the vulnerable subsystem or driver (lsmod, modinfo, /sys, /proc entries).
    • Review kernel package changelogs for CVE mentions or referenced upstream commits.
  • For WSL2:
    • Check the WSL kernel version (wsl --status and /proc/version inside the WSL instance) and whether a custom WSL kernel is in use. Verify the WSL kernel repo/config used to build the shipped kernel if necessary.
  • For Azure Marketplace/partner VM images and custom appliances:
    • Treat them as distinct artifacts; do not assume Microsoft’s attestation covers these. Inventory their kernels and images and contact the image vendor for patch status.
Remediation (patch-and-validate)​
  • Apply the vendor-supplied kernel update that lists the CVE as fixed. For Azure Linux, consume Microsoft’s updates; for distributions, use your distro’s kernel packages. Reboot into the patched kernel.
  • After patching:
    • Validate kernel logs are free of OOPS/WARN traces related to the subsystem.
    • Run representative workload tests for packet processing, I/O paths, or the affected driver’s functionality.
Short-term mitigations (if you cannot patch immediately)​
  • Restrict access to the affected functionality: limit unprivileged users, restrict capabilities (CAP_BPF, CAP_NET_RAW), and confine packet‑processing workloads to trusted, isolated hosts.
  • For multi‑tenant cloud nodes: avoid scheduling untrusted workloads that can exercise the vulnerable subsystem on shared hosts.
  • Consider temporary configuration changes to disable the affected kernel subsystem if feasible (careful: this may break dependent workloads).
How to verify whether other Microsoft products are affected​
You must verify per artifact — a checklist to perform that verification:
  • For each Microsoft‑supplied image or kernel you operate (linux-azure, Azure Marketplace image, WSL kernel, CBL‑Mariner-based image):
    1. Confirm the exact kernel binary and version shipped with that artifact.
    2. Inspect kernel configuration to check if the subsystem/driver is compiled in.
    3. Check the vendor’s published changelogs, KB articles, or CSAF/VEX attestation for that product. If Microsoft has not published an attestation for that SKU, treat it as not yet validated rather than proven safe.
    4. If you cannot determine inclusion from the artifact, contact your Microsoft product support or open a Microsoft support ticket requesting an explicit inventory confirmation for that SKU.
  • For Windows environments with Linux components (WSL, Hyper‑V VMs):
    • Remember that the guest kernel (or WSL kernel) is the relevant element for this CVE; updating container images won’t fix a vulnerable host kernel. Validate and patch guest/WSL kernels too.
Why Microsoft’s approach is strong — and where it falls short​
Strengths​
  • Deterministic automation: Publishing CSAF/VEX attestations for a product family (Azure Linux) provides a machine‑readable, authoritative input for automation, vulnerability triage, and compliance pipelines. This is a significant step toward scalable transparency.
  • Process clarity: Microsoft’s commitment to update CVE/VEX records if more products are discovered demonstrates a procedural promise to expand coverage and correct mappings over time. That improves trust when Microsoft follows through.
Limitations and risks​
  • Scope misinterpretation risk: Many teams will see Microsoft’s attestation and assume a global “only Azure Linux is affected” conclusion — a dangerous inference. Absence of a VEX entry for other Microsoft SKUs is not evidence of absence. Operators must verify other artifacts.
  • Inventory lag: Large vendors ship thousands of artifacts. Inventorying each one and producing VEX attestations takes time; until those attestations exist, customers must perform artifact-level checks themselves. This creates a window of residual uncertainty.
  • Third‑party and Marketplace images: Many Azure Marketplace images are published by third parties; Microsoft’s attestation for Azure Linux does not automatically cover marketplace publisher images. Operators must treat those images as separate supply-chain items.
Practical recommendations for Windows‑centric estates​
  • Do not conflate Microsoft’s Azure Linux attestation with an all‑clear for other Microsoft products. Verify kernels shipped in WSL, linux‑azure, and any Microsoft-provided images you run.
  • Automate ingestion of Microsoft’s CSAF/VEX artifacts and set alerts for updates. When Microsoft publishes a new attestation for additional SKUs you will receive machine‑readable signals to accelerate triage.
  • Ensure operations run a robust kernel inventory pipeline:
    • Collect uname/kernel config across all Linux guests and hosts.
    • Map each running kernel to the vendor CVE lineage and apply patches in prioritized rings.
    • Maintain a list of Microsoft images you run and treat each as a distinct artifact until attested otherwise.
Caveats and unverifiable claims (transparency)​
  • The MSRC attestation definitively ties Azure Linux to the upstream component for the CVE. That is verifiable in the published advisory and Microsoft’s CSAF/VEX outputs.
  • The presence of the same upstream component in other Microsoft products (for example, a Windows SKU that embeds a Linux kernel binary, or a Marketplace VM image distributed by a partner) cannot be inferred from the Azure Linux attestation alone. Determining whether those other artifacts include the component requires artifact inspection or a Microsoft VEX attestation for that product. This absence‑of‑evidence caveat is important: it is not possible to prove a negative without inventory data. Treat that as an operational constraint rather than a vendor failure.
  • When Microsoft updates the CVE/VEX mapping to name additional products, that will remove ambiguity for those specific SKUs. Until then, internal verification is the only definitive route to determine exposure for non‑attested artifacts.
Conclusion — a practical, risk‑based posture​
Microsoft’s statement that Azure Linux includes the open‑source library and is therefore potentially affected is accurate and useful: it gives Azure Linux customers a direct, machine‑readable attestation to act on now. However, the statement is intentionally scoped and does not imply that Azure Linux is the only Microsoft product that could include the same vulnerable upstream code. Kernel inclusion is a per‑artifact property; WSL kernels, linux‑azure builds, CBL‑Mariner artifacts, Marketplace images and other Microsoft‑distributed kernels are all plausible carriers until specifically inventoried and attested. Administrators should treat the Azure Linux VEX/CSAF output as authoritative for Azure Linux, but perform artifact‑level verification across all Microsoft images they operate, automate ingestion of Microsoft’s attestations, and prioritize patch‑and‑reboot across high‑risk, multi‑tenant, or packet‑processing hosts.
Microsoft’s attestation model improves transparency and automation, but it places the onus on operators to verify their entire estate rather than to assume that one product‑level statement covers everything. Follow the verification checklist above, ingest CSAF/VEX outputs, and prioritize remediation for attested images while you inventory and validate other Microsoft artifacts.
