CVE-2024-58251: BusyBox Netstat Escape Sequences Lock Terminal (DoS)
BusyBox’s netstat utility has a low‑scored but real weakness: CVE‑2024‑58251 allows a local attacker to craft an application name (argv[0]) containing ANSI terminal escape sequences that, when viewed by an unsuspecting user running BusyBox netstat, can lock up the victim’s terminal and cause a denial‑of‑service until the terminal is reset.
Laptop screen shows a netstat graphic with security locks and a warning icon.Background​
BusyBox is a compact suite of Unix utilities commonly embedded in minimal Linux distributions, initramfs images, containers, and many IoT devices. Its small size makes it a default choice for constrained environments, but that same ubiquity means a class of otherwise minor issues can show up broadly across distributions and images.
The issue CVE‑2024‑58251 was published on April 23, 2025 and is tracked by NVD and multiple distro and security trackers. It affects BusyBox builds up to and including version 1.37.0. The root cause is insufficient neutralization of control/escape sequences when netstat puts process names into its display cache, allowing an attacker with the ability to run a local network application to embed ANSI escape sequences in argv[0]. When a user later runs netstat on the same host or container, those escape sequences can manipulate terminal state and produce a locked or unusable terminal until recovery commands are issued.
How the vulnerability works — technical overview​
The vector: argv[0] and terminal escapes​
Unix processes advertise themselves using argv[0] (the value name the process uses for its own command). That value is often copied or displayed by system utilities. If argv[0] contains printable characters only, it’s harmless. If argv[0] contains ANSI escape sequences (control sequences like ESC [ … m or other C0/C1 controls), displaying that string directly to an interactive terminal can cause the terminal emulator to change modes, move the cursor, change colors, hide or show text, or — in some cases — leave the terminal in a non‑functional state until it’s reset.
BusyBox’s netstat historically cached and printed program names without adequately sanitizing control characters; the CVE specifically calls out netstat’s handling through BusyBox 1.37.0. A local attacker who can launch a networked process whose argv[0] contains escape sequences can therefore leave embedded escape codes visible to any user who later runs netstat against sockets owned by that process.
Impact model: denial‑of‑service (terminal lockup)​
This is an availability issue, not a code‑execution or privilege‑escalation bug. The practical impact is a locked terminal session: the victim’s terminal can appear frozen, display garbled characters, or refuse to accept input until reset. The severity scoring reflects this: most trackers assign a low CVSS base score (e.g., 2.5 with vector CVSS:3.1/AV:L/AC:H/PR:N/UI:R/S:U/C:N/I:N/A:L), because exploitation requires local access and some interaction.
Exploitability and attacker model — what an attacker needs​
  • Local access: the attacker must be able to run code on the same host or container. This is not a remote network attack.
  • Ability to control argv[0]: the attacker needs to start a process whose argv[0] can be set to a string containing ANSI escapes. Many languages and shells allow this (for example, via execve or argv manipulation in C, or via wrapper utilities).
  • A victim who runs netstat afterwards: the attack relies on the victim invoking BusyBox’s netstat; the escape becomes effective when printed to an interactive terminal. That requirement means an attacker typically must prepare or wait for the right moment — this is not an instantaneous remote exploit.
Because the exploit demands local execution and relies on a victim running a diagnostic command, successful exploitation usually requires either a misconfigured multi‑user environment (shared shell servers, multi‑tenant devices) or social engineering to coax the victim to run netstat in the presence of the malicious process. These realistic constraints are why the vulnerability is scored low but still practically useful to attackers who want nuisance‑level denial of service in shared environments.
Who and what is affected​
Software and versions​
  • BusyBox builds up to and including 1.37.0 are listed as affected upstream. Distribution packaging and backports vary — some distros list it as vulnerable until fixed upstream or deferred for minor‑severity issues. Always consult your distribution’s tracker for the exact status for the BusyBox package you run.
Typical exposed deployments​
  • Minimal Linux/container images used in CI, containers, and edge devices where BusyBox is the userland provider. Container images that include BusyBox netstat and run multiple container users or allow exec of additional processes are particularly at risk.
  • Multi‑user application servers or build hosts where untrusted users can launch processes.
  • IoT and embedded devices that expose local shells or basic service consoles.
Notably, many distribution security trackers — Debian, Ubuntu, Alpine, Amazon Linux — have indexed the CVE, but upstream fixes and distro backports differ by vendor and release. For example, Ubuntu’s tracker shows the vulnerability published on April 23, 2025 and lists the fix status as deferred for multiple releases as of October 20, 2025; Alpine, Debian and others have their own timelines for packaged fixes. Administrators must consult their distro advisory page for the authoritative remediation guidance and fixed package numbers.
Verification and cross‑checks​
Multiple independent vulnerability trackers and security vendors reproduce the same basic description and scoring for CVE‑2024‑58251:
  • The NVD entry documents the netstat/argv[0] ANSI escape lockup and lists CWE‑150 (improper neutralization of escape/control sequences).
  • Security vendors and trackers (Snyk, Aqua, Wiz, Enginsight and others) echo the description and published CVSS vector and note the local, user‑interactive nature of the attack.
  • Distribution trackers (Debian, Ubuntu, Alpine) have active bug/issue entries and package status notes; Debian’s tracker links back to BusyBox’s bug report and marks the fix as pending in upstream packages.
Cross‑referencing NVD with at least two independent trackers (for example Snyk and Ubuntu) confirms the core facts: the affected component (BusyBox netstat), the exploitation mechanism (ANSI escape sequences in argv[0]), and the practical impact (terminal lockup / DoS). Where distribution status or packaged fixes differ, the distro tracker is the authoritative mapping for that vendor.
Patches, fixes, and vendor responses​
As of public advisories and tracker data aggregated through late 2025, the upstream BusyBox project had been notified (bugzilla entry referenced as id 15922) and the defect is discussed on relevant security mailing lists. BusyBox maintainers and third‑party contributors have proposed sanitization patches that replace control characters with safe placeholders before caching or printing process names; a concrete patch discussion and example sanitization change was posted to BusyBox mailing lists in August 2025. Administrators should watch upstream BusyBox releases and their distribution’s security packages for an official fixed BusyBox release or a distribution backport. Important operational notes:
  • Some distributions may defer a fix for minor‑severity issues if upstream doesn’t provide a safe backport path; distribution trackers capture those policy decisions and the fixed package version when released. Confirm your distribution’s package advisory rather than assuming an immediate upstream release.
  • For container images and minimal appliances, the only practical fix may be to rebuild images with an updated BusyBox binary once an upstream patch or distro backport is published.
Short‑term mitigations and operational workarounds​
Because exploitation is local and interactive, defenders can apply operational controls immediately that reduce risk while awaiting packaged fixes:
  • Harden local execution:
  • Restrict who can run arbitrary binaries on shared systems. Use suEXEC, restricted shells, or container runtime policies to limit untrusted process launches.
  • Apply discretionary access controls and file‑system quotas to prevent untrusted users from placing or executing arbitrary programs.
  • Sanitize output in shared tooling:
  • Replace BusyBox netstat in interactive session kits with alternatives that sanitize or escape control characters before printing (for example, full GNU netstat or ss from iproute2 which have different rendering behaviors).
  • Wrap netstat output through a sanitizing filter (for example, remove non‑printable/control characters before printing) if you must keep BusyBox netstat in place.
  • Container image hygiene:
  • Rebuild container images to remove or restrict BusyBox netstat from interactive shells where possible.
  • Where BusyBox is required for size reasons, pin images and plan rebuilds when a fixed BusyBox package becomes available. Several container security trackers highlight BusyBox as a frequent vector for minor, but pervasive, display/escape issues.
  • Recovery if the terminal is locked:
  • Common recovery commands for a misbehaving terminal are reset, stty sane, or opening a fresh terminal session. These are operational tips rather than fixes; educate support staff about these commands and about not rebooting a device unnecessarily. (These are standard Unix administrative commands; consult your local environment or man pages for their exact behavior.
Caveats: none of these mitigations is a substitute for applying the vendor fix; they are risk‑mitigating measures appropriate for constrained or legacy environments while patching is scheduled.
Recommended remediation steps (practical playbook)​
  • Inventory and prioritise
  • Identify all systems (hosts, containers, embedded devices) that include BusyBox and specifically those exposing BusyBox netstat to interactive users. Container image scanners and package inventories are useful here.
  • Prioritise multi‑user and multi‑tenant systems where an untrusted local account could be used to launch the malicious argv[0] string.
  • Check vendor/distro advisories
  • Consult your distribution’s security tracker for the exact BusyBox package version and the fixed package name (Ubuntu, Debian, Alpine, Amazon Linux and other trackers each maintain per‑release mappings). Do not rely on upstream version numbers alone for distro‑packaged artifacts.
  • Apply patches or rebuild images
  • When a fixed BusyBox package appears in your distro’s repositories, apply it to the affected systems and reboot containers (or re‑deploy container images) as required.
  • For immutable images or appliances, rebuild images with the updated BusyBox binary and redeploy them in a controlled maintenance window.
  • Implement compensating controls where immediate patching is impossible
  • Limit interactive shell access and restrict who can run arbitrary commands.
  • Replace BusyBox netstat in user‑facing toolkits with alternatives that sanitize output, or wrap netstat output through a sanitizing filter.
  • Educate and monitor
  • Inform helpdesk and administrators about symptoms (garbled terminal, lack of input response) and recovery steps (reset, stty sane, open a new terminal).
  • Monitor for suspicious local process launches and for repeated netstat usage that might indicate an adversary is attempting to trigger or probe the condition.
Why defenders should care (risk assessment)​
On paper, CVE‑2024‑58251 is a low severity availability issue; in practice, the impact is contextual.
  • For a single‑user workstation, the most likely outcome of exploitation is a nuisance (a locked terminal that the user can recover). This has limited operational severity.
  • For multi‑user systems, build servers, or shared development infrastructure, the vulnerability becomes more practical. An attacker with a low‑privilege account can deliberately interfere with other users’ ability to administer hosts (e.g., DOSing monitoring sessions or terminal‑based workflows). That operational impact can be significant in high‑availability or tightly scheduled build/test environments.
  • In container‑orchestrated environments, the defect increases the operator burden because many container images and toolkits use BusyBox for minimal userland. Even if each impact is small, the cumulative management cost across many images can be nontrivial. Security scanning vendors flagged BusyBox as a recurring maintenance vector for exactly these small but widespread defects.
The combination of ubiquity and the relative ease of local exploitation in shared contexts is why operations teams should treat the issue as deserving a planned remediation rather than an ignorable curiosity.
Developer and upstream considerations​
Fixing the bug correctly requires disciplined sanitization: upstream patches proposed in public mailing lists aim to replace non‑printable and control characters with safe placeholders before storing them in the display cache or printing. A robust fix should:
  • Normalize or escape control sequences rather than merely stripping them, to avoid confusing output.
  • Sanitize both C0 and C1 controls (not just the common ESC [ sequences) because terminals interpret many control ranges.
  • Consider a policy that always renders process names through a safe escape function before display.
These are implementation details that BusyBox maintainers and contributors have discussed publicly; follow upstream commit logs and mail archives for the final accepted patch and the date it lands in official releases.
Final assessment and guidance​
CVE‑2024‑58251 is a concise example of a low‑severity vulnerability that nonetheless matters due to BusyBox’s broad footprint. The exploitation model is local and interactive, making the immediate risk small for isolated desktops but materially higher for shared, multi‑user, or multi‑tenant environments and for container fleets built from minimal BusyBox images.
Administrators should:
  • Inventory BusyBox usage quickly.
  • Consult distro advisories for fixed package versions and apply patches or image rebuilds when available.
  • Implement short‑term mitigations (restrict local execution, sanitize output, replace BusyBox netstat in critical interactive toolkits).
  • Educate support staff on terminal recovery procedures as an operational stopgap.
Finally, watch for upstream BusyBox releases and distribution backports. Where maintainers provide a sanitized netstat or a patched BusyBox package, test and deploy those builds in your environment. Treat the issue as operational technical debt: the low CVSS does not mean “no action” — the wide attack surface of BusyBox makes even small defects worth tracking until they are fully resolved.
Appendix — quick references (dates and identifiers)​
  • CVE identifier: CVE‑2024‑58251 (published April 23, 2025).
  • Affected component: BusyBox netstat up to 1.37.0 (per upstream/NVD disclosure).
  • Typical CVSS vector reported: CVSS:3.1/AV:L/AC:H/PR:N/UI:R/S:U/C:N/I:N/A:L (Base score 2.5, Low).
  • Upstream bug reference: BusyBox bug tracker entry referenced as id 15922 and discussed on OSS security lists.
  • Public patch discussion: BusyBox mailing list patch/sanitization thread (example sanitization patch posted Aug 2025). Administrators should confirm the final upstream commit and/or distribution package that contains it.
Conclusion: this is a low‑impact but actionable vulnerability — fix via standard patch management and treat BusyBox usage in shared or containerised contexts as a recurring maintenance point for operations and security teams.
