CVE-2025-14174: Patch ANGLE memory safety in Chromium Chrome and Edge updates
CVE-2025-14174 patching in a browser UI with GPU shield and progress bar.
Google’s Chromium project patched a dangerous graphics-layer bug — tracked as CVE‑2025‑14174 — that allows an out‑of‑bounds memory access in the ANGLE (Almost Native Graphics Layer Engine) translation layer, and that upstream fix (Chrome 143.0.7499.110 and later) has been ingested by downstream vendors. Microsoft lists the CVE in its Security Update Guide to show Microsoft Edge’s exposure status and to announce which Edge builds include the ingestion that removes the vulnerability; administrators and users should verify their browser build strings (chrome://version or edge://version) and update immediately if their installed build predates the patched release.
Background / Overview​
ANGLE is the compatibility layer Chromium uses to convert WebGL/OpenGL ES calls into native platform graphics APIs (Direct3D on Windows, Metal on macOS, OpenGL on Linux). Because ANGLE processes untrusted input from web pages and WebGL contexts, memory‑safety issues inside it are high‑value targets for attackers; an out‑of‑bounds memory access can be the first step toward memory corruption, crashes, or remote code execution. The flaw tracked as CVE‑2025‑14174 was patched in the Chrome 143 release family and has been elevated in operational priority after evidence of active exploitation and inclusion in policy catalogs.
Chromium is upstream open‑source software consumed by many commercial browsers and runtimes (Google Chrome, Microsoft Edge, Brave, Vivaldi, Opera, Electron apps, WebView and WebView2 embedded runtimes). When Chromium receives a security fix, each downstream vendor must ingest the upstream change, validate it against their product and platform, and then ship an updated binary; that downstream process is why vendors like Microsoft publish Security Update Guide entries for upstream Chromium CVEs — to tell customers whether Microsoft‑shipped products remain vulnerable or are already patched.
What CVE‑2025‑14174 is — a technical summary​
  • Vulnerability class: Out‑of‑bounds memory access inside ANGLE (memory‑safety violation).
  • Component: ANGLE / LibANGLE (Chromium’s WebGL/OpenGL ES translation layer).
  • Attack vector: Remote — a crafted HTML page or web content that exercises the affected ANGLE code path can trigger the defect.
  • Privileges required: None — attacker only needs the victim to render the malicious content in the browser.
  • Upstream remediation boundary: Chrome/Chromium 143.0.7499.110 (or later).
An out‑of‑bounds access means code attempts to read or write memory outside of an allocated buffer. In a complex rendering stack that interacts with GPU drivers and performs format translations, such bugs can produce exploitable primitives — information disclosure, arbitrary reads/writes, or even code execution — depending on available mitigations (sandboxing, ASLR, hardened allocators) and how reliably an attacker can control memory layout. Because ANGLE is a graphics mediator, exploitation sometimes leverages interactions with drivers and platform backends, which can complicate both exploitation and mitigation.
Why Microsoft included this Chromium CVE in the Security Update Guide​
Microsoft’s Security Update Guide (SUG) is intended to show Microsoft‑shipped products’ exposure to known vulnerabilities and to record the status of Microsoft updates that remediate those issues. When a CVE originates upstream in Chromium, Microsoft tracks it and documents the Edge builds that include the upstream ingestion — not because Microsoft authored the bug, but because Edge consumes Chromium code. The SUG entry therefore functions as a downstream status indicator: it tells Edge administrators whether the specific Edge build they run still contains the vulnerable upstream code or whether it has been patched by Microsoft’s ingestion and update process. This downstream tracking is essential because an upstream Chrome fix does not automatically protect every Chromium‑based product until each vendor ships an update.
Two operational drivers make SUG entries important:
  • Transparency and verification: Enterprises need authoritative confirmation that the vendor’s shipped build contains the remediation, and SUG entries supply that record.
  • Actionability: Security operations teams prioritize and schedule patching based on vendor advisories and SUG statuses rather than assuming parity with upstream Chromium builds.
How to see your browser version (quick, authoritative checks)​
Knowing the exact browser build string is the single most reliable way to determine whether a client has received the ingestion that fixes CVE‑2025‑14174. Use the steps below to view the version on Windows desktops.
Google Chrome (desktop)​
  1. Open Chrome.
  2. Type chrome://version in the address bar and press Enter.
  3. Note the version string (for example: 143.0.7499.110). Compare it against the remediation boundary.
Alternatively: Settings → Help → About Google Chrome — this page not only shows the current version but triggers an update check and will display the post‑update build after a restart.
Microsoft Edge (Chromium‑based)​
  1. Open Microsoft Edge.
  2. Type edge://version in the address bar and press Enter.
  3. Note the version string and confirm whether Microsoft’s SUG/Edge release notes list that build as containing the ingestion for CVE‑2025‑14174.
Alternatively: Settings and more → Help & feedback → About Microsoft Edge. Edge will check for updates and install if available; record the build string after restart. Confirming the build string against Microsoft’s published Edge release information is the authoritative downstream check.
Embedded runtimes, Electron apps or WebView deployments​
  • For Electron or embedded Chromium, check the application’s About window, vendor release notes, or use automation/inventory tools that extract the packaged Chromium revision. Do not assume the host OS Chrome/Edge build equals the embedded runtime’s revision — they often lag and may remain vulnerable until the application vendor updates.
How to confirm whether your browser is patched for CVE‑2025‑14174​
  1. Check the browser’s version string (chrome://version or edge://version).
  2. For Chrome, ensure the build is 143.0.7499.110 or later. For Edge, confirm that the Edge build string is listed in Microsoft’s Security Update Guide or Edge release notes as containing the ingestion for CVE‑2025‑14174. Do not infer Edge protection solely from Chrome’s fixed build number — verify the actual Edge release string because ingestion and shipping are a distinct step.
  3. If the installed build predates the patched builds, update the browser and restart it to ensure the new binary is running (some update systems replace files but only apply fixes after a process restart).
Practical, step‑by‑step remediation checklist (for administrators and power users)​
  1. Inventory:
    • Enumerate all endpoints and catalog every Chromium runtime: Google Chrome, Microsoft Edge, Brave, Opera, Vivaldi, Electron apps, WebView/WebView2 instances, kiosk appliances, embedded devices and headless servers. Use endpoint management tools or scripts to collect build strings.
  2. Prioritize:
    • Patch internet‑facing, high‑privilege and developer workstations first. Treat the KEV listing and active exploitation reports as signals to accelerate remedial action for exposed assets.
  3. Patch:
    • Deploy vendor updates for Chrome and Edge (or vendor‑supplied patches for embedded apps). Enforce immediate browser restarts to activate updated binaries. Validate post‑update build strings with chrome://version and edge://version.
  4. Temporary mitigations (if immediate patching is impossible):
    • Disable hardware acceleration in browser settings to reduce exposure to the ANGLE renderer path (a stopgap with limited completeness).
    • Restrict privileged accounts to hardened browsing profiles or alternative browsers that have confirmed fixes.
    • Apply network egress filtering and web proxies to restrict access to high‑risk sites.
  5. Detection and hunting:
    • Look for correlated renderer process crashes, GPU/renderer restarts, or anomalous outbound connections from browser processes. Preserve memory dumps from crashes (observing privacy and legal constraints) for vendor incident response when needed.
  6. Vendor engagement:
    • For Electron apps and embedded runtimes, request a vendor statement confirming the packaged Chromium revision and remediation plan. If the vendor does not respond quickly, treat the software as an elevated risk and consider compensating controls or temporary restrictions.
Detection, forensics and evidence collection​
Because the attack vector is web content, indicators can be subtle. Useful signals include:
  • Sudden, correlated renderer crashes across multiple machines.
  • Browser processes terminating with memory‑corruption or access‑violation exceptions.
  • Unexpected network connections from browser processes shortly after a rendering event.
  • Web proxy logs showing visits to obscure pages or rapid redirects coinciding with crash telemetry.
Preserve relevant logs and, where feasible, process memory dumps for analysis and vendor triage. These artifacts assist both incident response and upstream vendor diagnostics.
Cross‑platform and downstream risk: why the exposure window persists​
Even when Google ships a Chrome patch, many products that rely on Chromium do not automatically become safe. The supply chain includes:
  • Microsoft Edge and other commercial browsers that must ingest upstream changes and ship updates.
  • Electron‑based desktop apps that package a specific Chromium revision until an app vendor intentionally updates it.
  • Embedded WebView and appliance/UIs that ship static browser runtimes and may never auto‑update.
  • Server side headless Chromium instances used in CI pipelines, rendering workers, PDF generation services, or document scanners.
This ingestion lag is the single largest practical risk: attackers can exploit downstream deployments that remain unpatched long after an upstream fix exists. That is precisely why downstream vendors and Microsoft publish SUG entries — to close the loop and let administrators know which shipped builds are safe.
Critical analysis — strengths, limitations and residual concerns​
Strengths​
  • Rapid upstream patching: Google released a fix in the Chrome 143 family, limiting the upstream window of exposure.
  • Operational signaling: The CVE’s addition to policy catalogs and Microsoft’s Security Update Guide provides clear operational signals and encourages prioritized remediation.
  • Practical mitigations available: Temporary mitigations (hardware acceleration disablement, network controls) can reduce exposure pending vendor updates.
Limitations and risks​
  • Downstream ingestion lag: The most consequential weakness is that embedded Chromium runtimes (Electron apps, WebView, device firmware) may remain vulnerable until vendors ship updates, and many of these targets do not auto‑update.
  • Limited public exploit detail: Vendor advisories often withhold deep technical details while patches roll out; this protects users but complicates defenders’ ability to write precise detections. Treat exploit claims as operational signals but continue to seek corroborating technical analysis.
  • False assumptions about version parity: Administrators sometimes assume that because Chrome is patched, all Chromium derivatives are safe. That assumption is unsafe: always verify the actual product build string.
Residual exposure scenarios to worry about​
  • Legacy kiosks, embedded device UIs and appliances that ship static Chromium binaries and are rarely updated.
  • Vendor‑managed Electron apps used on privileged seats (developer machines, admin consoles).
  • Headless Chromium services in CI/CD or server‑side rendering that process untrusted content.
Recommended timeline for enterprise remediation (practical playbook)​
  1. Immediate (0–24 hours)
    • Inventory internet‑facing and privileged endpoints.
    • Patch Chrome and Edge on exposed endpoints; enforce restart.
    • Block or restrict high‑risk embedded apps pending vendor confirmation.
  2. Short term (24–72 hours)
    • Roll updates to standard user devices.
    • Implement compensating network controls and disable hardware acceleration where feasible.
    • Hunt for suspicious renderer crashes and collect evidence where present.
  3. Medium term (72 hours +)
    • Validate vendor responses for embedded runtimes and schedule updates.
    • Update server‑side headless Chromium workers and test workloads for regressions.
    • Document incident actions and monitor for vendor technical writeups.
Practical checklists you can copy/paste​
  • Quick user checklist (single machine)
    1. Open browser.
    2. Enter chrome://version or edge://version.
    3. If build < patched build, go to Settings → Help → About and apply updates.
    4. Restart browser and verify build string again.
  • IT admin checklist (fleet)
    • Run inventory script to gather chrome/edge version strings.
    • Push vendor updates via corporate update channels (SCCM, Intune, Jamf).
    • Enforce restart and validate post‑update build strings.
    • Quarantine or restrict apps with embedded Chromium until vendors confirm ingestion.
Final assessment and practical takeaway​
CVE‑2025‑14174 is a serious memory‑safety vulnerability in ANGLE with real operational urgency: it is remotely triggerable by web content and has been linked to active exploitation signals that prompted authoritative listings. Microsoft includes the CVE in the Security Update Guide not to claim ownership of the defect but to communicate the downstream status for Microsoft Edge and to provide customers with an authoritative way to verify whether their Microsoft‑shipped Edge build includes the upstream ingestion that removes the vulnerability. The single best immediate action is to check your browser’s build string (chrome://version or edge://version), update to the patched build or later, and verify that the browser process has been restarted to activate the patch.
Operationally, prioritize patching internet‑facing systems and privileged workstations, inventory all Chromium runtimes (including embedded and server‑side), and apply compensating mitigations where vendor updates cannot be applied quickly. The upstream patch is necessary but not sufficient — downstream ingestion and vendor updates are the final step that makes any particular product safe.
Treat CVE‑2025‑14174 as an immediate prioritization signal: verify browser build strings now, update and restart affected browsers, and accelerate remediation for any downstream Chromium consumers in your environment. The Security Update Guide entry exists to make that verification simple and actionable for Microsoft Edge users; use it — and chrome://version / edge://version — as the authoritative way to confirm that your deployed Edge or Chrome instance is no longer vulnerable.
