CVE-2025-2915: HDF5 Heap Overflow in H5F_accum_free Triggers DoS
A heap‑based buffer overflow in the HDF5 library — specifically in the H5F__accum_free function inside src/H5Faccum.c and tracked as CVE‑2025‑2915 — has been publicly disclosed, includes a reproducible proof‑of‑concept and affects HDF5 releases up to and including 1.14.6; the immediate, reliable impact is application crash and denial‑of‑service, while escalation to code execution remains environment‑dependent and unproven in the wild.
Illustration of an HDF5 CVE-2025-2915 memory-buffer overflow vulnerability.Background / Overview​
HDF5 (Hierarchical Data Format version 5) is the de facto binary container and C library used across scientific computing, engineering, machine learning, and large‑scale data pipelines. It is commonly embedded or linked into command‑line tools, Python/R bindings, vendor appliances, and server‑side ingestion pipelines. Memory‑safety defects in HDF5 therefore have broad downstream implications: a single library bug can translate into crashes or data corruption across many products and services that accept or process .h5 files.
CVE‑2025‑2915 was first recorded in late March 2025 and is publicly tracked by mainstream vulnerability databases and vendor advisories; canonical records list HDF5 up to 1.14.6 as the affected upstream release and identify the faulty routine as H5F__accum_free in src/H5Faccum.c. Why this matters in practice:
  • HDF5 is often directly linked into application binaries and language bindings; an unpatched runtime means widely distributed consumers carry the risk.
  • Services that accept uploaded .h5 files (previewers, ingestion pipelines, automated converters) can effectively transform a local attack vector into a remotely triggerable denial‑of‑service.
  • Multiple independent trackers and the upstream project include a publicly available test harness or PoC that reproduces crashes under AddressSanitizer, shortening attacker lead time.
Technical anatomy: what goes wrong in H5F__accum_free​
The vulnerable code path (concise)​
Within HDF5’s metadata accumulation logic, the function H5F__accum_free adjusts an in‑memory metadata accumulator when a file block is freed. The relevant code computes an overlap size between the freed block and the accumulator and then attempts to slide bytes within the accumulator buffer to remove that freed region. In the vulnerable version the code calculates:
  • overlap_size = (addr + size) - accum->loc
  • new_accum_size = accum->size - overlap_size
  • memmove(accum->buf, accum->buf + overlap_size, new_accum_size)
If overlap_size is not properly validated against accum->size, the arithmetic and subsequent memmove can attempt to operate on out‑of‑bounds memory and trigger a heap buffer overflow / invalid read. The issue and the offending line are documented in the upstream GitHub issue and reproduced with an AddressSanitizer harness.
Why a single arithmetic/validation miss matters​
Two typical failure modes make this bug exploitable for crashing the process:
  • If overlap_size is larger than accum->size, new_accum_size underflows (as an unsigned size_t) and produces a large value, causing memmove to read or write well beyond the intended buffer.
  • If pointer arithmetic yields a pointer outside the mapped buffer, the memmove read will hit protected memory and produce a crash that sanitizers (ASan) will label as an invalid read.
Either outcome reliably produces process instability or termination — the primary, immediate risk is availability loss. The upstream PoC demonstrates these conditions under sanitizers and provides a practical reproduction path.
Evidence, scope and corroboration​
Multiple independent sources corroborate the vulnerability details and scope:
  • The HDFGroup’s public issue that contains the code excerpt, line numbers and the PoC harness (build with AddressSanitizer).
  • National vulnerability indexes and tracker entries (NVD, Ubuntu, Debian, SUSE) list CVE‑2025‑2915 and map the affected upstream release to HDF5 ≤ 1.14.6. These vendor pages also document the attack vector as local (but note practical remote triggerability where services process uploaded files).
  • Commercial and independent vulnerability aggregators (Snyk, cvefeed, Wiz) echo the same technical description and reference the upstream GitHub issue and PoC artifacts.
Cross‑referencing the upstream issue and at least two vendor trackers is important because packaging and backport timelines vary: an upstream repository fix does not automatically mean downstream packages or language bindings have been updated. Debian and Ubuntu trackers explicitly list package statuses and advise verification of changelogs before declaring hosts remediated.
Impact and exploitability: practical assessment​
Primary impact — Availability (DoS)​
The most reliable outcome of the flaw is a crash or persistent instability in any process that parses a crafted .h5 file. Automated ingestion services, conversion daemons, or previewers that automatically open uploaded files are particularly vulnerable because an unauthenticated actor can upload a malicious .h5 and trigger the vulnerable path. The upstream PoC demonstrates deterministic crashes under ASan; real‑world processes without sanitizer instrumentation will still typically crash, producing service outages.
Integrity and confidentiality​
Heap corruption arising from the overflow can cause silent data corruption in long‑running processes or corrupt files written after the corruption occurs. Memory disclosure (information leak) is less likely from the reported behavior: the bug is a write/read out‑of‑bounds condition rather than a controlled read primitive. Public advisories emphasize availability and integrity consequences foremost and treat claims of memory disclosure as secondary and context‑dependent.
Remote code execution (RCE): speculative, environment‑dependent​
Heap overflows are a classic route to code‑execution in exploit development, but turning this specific single‑byte/size arithmetic bug into reliable RCE requires several additional conditions:
  • predictable allocator behavior or heap‑grooming opportunities,
  • information leaks to defeat ASLR, or
  • weaker platform hardening (no RELRO/PIE, old allocators).
Public reports and vendor trackers caution that RCE remains possible in theory but not demonstrated as a trivial outcome for CVE‑2025‑2915; treat RCE claims as speculative until independent exploit chains are published that concretely demonstrate it on modern hardened systems.
Severity scoring nuance​
Different sources assign different scores (CVSS v3.1 and v4.0 variations are visible across trackers). This disparity reflects differing threat models:
  • some vendors emphasize the local attack vector and assign a lower base score (e.g., CVSS 3.3 / Low in certain vendor pages),
  • others raise the priority because PoC code exists and HDF5’s ubiquity increases practical exposure.
Operationally, treat this as a high priority for systems that automatically process untrusted .h5 files and a medium priority for isolated desktop users or closed HDF5 deployments.
Upstream and vendor status: patches, backports and packaging​
The HDFGroup issue includes the vulnerability report and reproducer; upstream maintainers acknowledged and routed fixes through the project’s PR workflow. However, the presence of an upstream commit does not guarantee immediate remediation across all distributions, packaged wheels, containers, or statically linked appliances.
Key operational facts:
  • Upstream: issue and PoC are public; follow the HDFGroup repository and the linked PR(s) for the authoritative fix commits.
  • Distributions: Debian, Ubuntu and SUSE trackers have entries for CVE‑2025‑2915 and indicate varied statuses (some mark the package as vulnerable or in evaluation); operators must verify their specific distribution’s changelog for the fix commit or a patched package version.
  • Language bindings and wheels: prebuilt Python wheels (e.g., h5py) and conda packages commonly embed a bundled HDF5 runtime. Even if a system’s OS package is updated, wheel or container images may still carry the vulnerable library; verifying embedded library versions is essential.
This mismatch between upstream commits and downstream availability is the most common operational risk: many operators assume a fix exists once an upstream PR is merged, but remediation requires vendor packages or rebuilds of statically linked artifacts.
Recommended mitigation and remediation playbook​
Patch‑first is best, but the operational reality means staged mitigations are necessary for many organizations. The following checklist prioritizes correctness and practicality.
Immediate actions (first 24–72 hours)​
  • Inventory where HDF5 is present:
  • System packages (hdf5, libhdf5) on servers and desktops.
  • Embedded copies in Python wheels (h5py, others) and conda packages.
  • Container images, orchestration manifests, CI runners and firmware that may include HDF5.
  • Statically linked vendor appliances and custom builds.
  • Identify services that automatically process uploaded .h5 files (ingest pipelines, preview/thumbnailing workers) and isolate them from internet‑facing endpoints.
  • If possible, block or require authentication for .h5 uploads until patched processing is in place.
Patch and rebuild (preferred)​
  • Apply vendor updates where available. Confirm the package changelog references CVE‑2025‑2915 or the upstream fix commit/PR.
  • If a vendor update is not available, pull the upstream fix into your build tree, rebuild HDF5, and rebuild/redeploy any statically linked binaries or container images that embed the library.
  • Rebuild language bindings and wheels that bundle the runtime (for example, rebuild h5py wheels against a patched HDF5 and reissue them to your internal registries).
Compensating controls if patching is delayed​
  • Sandbox HDF5 processing: run file parsing in ephemeral, least‑privilege containers with strict resource limits, seccomp/AppArmor/SELinux profiles, and restricted network access.
  • Move automatic processing of untrusted files to isolated worker pools that are easy to restart and monitor.
  • Enforce file input constraints (size, allowed object types) and introduce a manual review step for suspicious files.
Detection and verification​
  • Enable and monitor crash telemetry on HDF5‑linked processes (repeated segmentation faults, OOMs, or unusual exit codes).
  • In staging, run the upstream PoC/harness against patched and unpatched builds under AddressSanitizer to confirm that the crash path is closed in patched builds. The upstream issue includes an ASan reproducer and test zip. Run PoCs only in an isolated test environment.
  • Verify package changelogs and, where possible, the presence of the exact commit SHA from upstream in your build.
Detection example: how to confirm a host is fixed​
  • For packaged systems: check the installed hdf5 package version and the vendor advisories/changelogs; expect entries that explicitly reference CVE‑2025‑2915 or the upstream fix commit.
  • For builds from source: inspect src/H5Faccum.c in your build tree. The patched code will include added bounds checks around overlap calculations and will avoid the unchecked memmove path.
  • Functional validation: run the supplied fuzzer harness and the PoC file in a sandboxed environment with ASan; a patched build should no longer crash on the PoC input.
Strengths of the response and notable fixes​
  • Upstream transparency: the HDFGroup issue includes a detailed code excerpt, an ASan trace and a reproducible test harness — this is high‑quality disclosure that enables rapid verification and patching.
  • Cross‑ecosystem tracking: major distributions and vulnerability databases have indexed the CVE and created tracking entries, which helps administrators map vulnerable package versions across releases.
  • Practical mitigations exist: because the primary risk is DoS, containment and sandboxing substantially reduce the blast radius while patches are prepared.
Remaining risks and caveats​
  • Packaging lag: downstream package maintainers and third‑party wheel/container authors may take days to weeks to publish patched artifacts or to backport fixes. This gap leaves many deployments exposed even after upstream merges. Operators must verify timelines per vendor rather than assume automatic patch propagation.
  • Static linking: products that statically embed HDF5 require rebuild and redeployment; there is no runtime patch for such cases.
  • RCE uncertainty: while heap overflows are powerful primitives, there is no widely accepted, public exploit demonstrating reliable remote code execution for CVE‑2025‑2915 as of public disclosure. Treat any claims of RCE as unverified until multiple independent exploit writeups demonstrate a usable chain on modern hardened systems.
  • False sense of security from version numbers: some ecosystems ship older stable HDF5 releases (e.g., the 1.10.x line). Vulnerability exposure depends on the actual library binary in use, not only the OS package metadata; check embedded runtimes in wheels and containers.
Practical checklist for Windows and Linux system administrators​
  • Inventory (immediate): locate hdf5 binaries, Python wheels (h5py), conda environments, Docker/OCI images that include libhdf5, and any vendor appliances that mention HDF5.
  • Prioritize (24–48 hours): isolate and harden any public‑facing services that accept .h5 uploads (move to authenticated queues or disable automatic parsing).
  • Patch (72 hours+): apply vendor package updates or rebuild with the upstream fix; rebuild static artifacts and republish patched images/wheels.
  • Verify (post‑patch): run the upstream ASan reproducer in an isolated test harness and confirm the crash is resolved; check vendor changelogs for the upstream commit SHA if available.
  • Monitor (ongoing): enable process crash alerts, scan for exploitation attempts in file upload telemetry, and watch vendor advisories for any follow‑up fixes or related CVEs in the 1.14.6 release window.
CVE‑2025‑2915 is a concrete, reproducible heap‑based overflow in HDF5’s metadata accumulator routine that can reliably crash processes that parse crafted .h5 files. For organizations that process untrusted HDF5 input — particularly server‑side ingestion or preview systems — this vulnerability is a practical denial‑of‑service hazard and should be triaged with urgency: inventory artifacts, sandbox processing, apply patches or rebuilds that include the upstream fix, and verify remediation using the supplied PoC in safe test environments. While the leap from crash to remote code execution is not established as trivial for this CVE, the combination of HDF5’s ubiquity and public proof‑of‑concept material means defenders should err on the side of caution and prioritize containment and patching for high‑exposure services.
