CVE-2025-37951 Demystified: Azure Linux Attestation and Artifact Verification
Microsoft’s brief MSRC note that “Azure Linux includes this open‑source library and is therefore potentially affected” is an accurate, product‑scoped attestation — but it is not a proof that only Azure Linux can contain the vulnerable kernel component for CVE‑2025‑37951.
Neon blue cloud with the Linux Tux sits above server racks, linked to DRM V3D and GPU Scheduler gears.Background / Overview​
CVE‑2025‑37951 is a Linux‑kernel vulnerability in the DRM v3d driver (the VideoCore / v3d GPU scheduler path) that was fixed upstream in 2025. The flaw is a correctness/memory‑management issue: when a CL/CSD job times out, the scheduler can remove the job from the pending list and then, if the reset is skipped because the GPU made progress, the job never gets re‑queued and ultimately never freed — producing a memory leak. Distributors and tracking databases catalog the issue and the stable‑tree fixes. Microsoft’s Security Response Center (MSRC) published an attestation covering Azure Linux (Microsoft’s Linux distribution family for Azure images), saying those images include the open‑source component that contains the vulnerable code and are therefore potentially affected. Microsoft also documented a phased rollout of machine‑readable CSAF/VEX attestations that began with Azure Linux in October 2025 and promised to update CVE entries if additional Microsoft products are later found to include the same upstream component. That procedural context explains why Azure Linux appears in MSRC’s mapping first. This article explains what MSRC’s statement actually means, summarizes the technical root of CVE‑2025‑37951, evaluates whether Azure Linux is the only Microsoft product that could be affected, and provides concrete verification, mitigation, and detection steps for operators and security teams.
The vulnerability in plain language​
What the code problem is​
  • Component: Linux kernel DRM v3d scheduler (drivers/gpu/drm/v3d).
  • Fault: On a job timeout, the scheduler removes the job from the pending list. If the code decides to skip a hardware reset because the GPU made progress, the timed‑out job is left running but not re‑inserted into the pending list. When that job later completes, it is not freed — resulting in a memory leak. The upstream patch changes behavior to put the job back on the pending list when timeout is extended.
Impact, attack surface, and severity​
  • Attack vector: local. A local process (for example a compositor, an unprivileged program with access to DRM device nodes, or a container with device passthrough) can exercise GPU scheduler paths.
  • Typical effect: memory leak leading to resource exhaustion, kernel warnings, driver instability or oops; this is a robustness/availability issue rather than an immediately obvious remote code execution or privilege‑escalation hole.
What Microsoft actually said — and what that wording means​
Microsoft’s short product mapping for the CVE reads (paraphrase): “Azure Linux includes this open‑source library and is therefore potentially affected,” and Microsoft added that it began publishing CSAF/VEX attestations for Azure Linux in October 2025 and will update CVE records if additional Microsoft products are found to ship the component. That phrasing contains two separate facts:
  • Microsoft has completed an inventory for the Azure Linux product family and found the implicated upstream component in those images. The MSRC VEX/CSAF output is therefore an authoritative, machine‑readable attestation for Azure Linux customers.
  • Microsoft’s attestation is phased and product‑scoped. The company explicitly committed to expanding VEX coverage to additional products over time, which means absence of a VEX entry for a different Microsoft product is absence of attestation, not positive proof the product is unaffected.
Put simply: the MSRC sentence should be read as “we have checked Azure Linux and found the component there”, not as “we have checked all Microsoft artifacts and nothing else contains the component.” Multiple independent analyses and distribution trackers emphasize that distinction and recommend per‑artifact verification for other Microsoft‑distributed kernels and images.
Is Azure Linux the only Microsoft product that includes the library (and could therefore be affected)?​
Short answer: No — Azure Linux is the only Microsoft product Microsoft has publicly attested so far, but that attestation is not an exclusivity claim. Any Microsoft product or image that ships a Linux kernel built with the v3d/drm scheduler code and that predates the upstream fix could, in principle, be affected until inventory or VEX entries show otherwise.
Why that matters technically:
  • The vulnerable code lives in the Linux kernel, not a standalone userland library. Whether a given product is vulnerable depends on the actual kernel binary shipped/used by that product: kernel version, which drivers and modules were compiled in, and whether the vendor applied the upstream fix or backport.
  • Microsoft publishes and manages multiple Linux kernel artifacts: Azure Linux images, “linux‑azure” / Azure‑tuned kernel builds used for some VM SKUs, the WSL2 kernel distributed with Windows (the source of which Microsoft publishes on GitHub), Marketplace images and partner appliances, and container/AKS node images. Each of those artifacts is built independently and can therefore differ in which drivers and fixes they include.
Concretely: Microsoft’s attestation gives Azure Linux customers a clear, machine‑readable signal to prioritize remediation. It does not mean other Microsoft artifacts are guaranteed clean; those must be checked individually.
Where Microsoft artifacts might include the vulnerable code (what to check)​
Treat the following classes of artifacts as in scope for verification until confirmed otherwise:
  • Azure Linux VM images and node images (attested by MSRC for Azure Linux). High priority.
  • Windows Subsystem for Linux (WSL2) kernels: Microsoft publishes the WSL2 kernel source on GitHub; that source contains the drivers/gpu/drm tree, so a WSL kernel build could include DRM driver code. Whether a WSL2 binary for a given Windows host is vulnerable depends on its kernel version and whether Microsoft shipped the fix. This is an artifact‑level question.
  • linux‑azure or Azure‑tuned kernel builds used for some VM SKUs or Marketplace images — these are separate artifacts from Azure Linux images and need verification.
  • Marketplace images and partner appliances (third‑party publishers are responsible for those images; Microsoft’s attestation covers only MS‑published Azure Linux artifacts until VEX coverage expands).
  • AKS node images and container host node OS images — if they run an affected kernel, containers scheduled there are at risk via the host.
How to verify whether an artifact (image, VM, WSL instance) includes the vulnerable code​
Verify at the artifact or host level; vendor‑level statements alone are insufficient until the product is attested. Suggested verification steps:
  • Gather kernel identity
  • Run: uname -a
  • Check kernel package version and changelogs (for packaged systems: apt/dpkg, rpm/yum/zypper). Cross‑reference with distro/security advisories that list fixed package versions.
  • Check kernel configuration for v3d/DRM
  • If available: zgrep CONFIG_DRM_V3D /proc/config.gz or grep CONFIG_DRM_V3D /boot/config-$(uname -r).
  • If the driver is built as a module, look for CONFIG_DRM_V3D=m and check lsmod | grep v3d or modinfo v3d.
  • If the driver is not present in the config or modules, that artifact likely does not include the v3d code path. If present, proceed to kernel version checks.
  • Compare against upstream fix commits / distro backports
  • Use the NVD/OSV/distro advisory entries for CVE‑2025‑37951 to identify the upstream commit(s) and which stable kernel branches received the fix. If your kernel predates the fix and includes the driver, treat it as vulnerable.
  • For WSL2
  • Check your WSL kernel version with uname inside the WSL instance and compare to Microsoft’s WSL kernel release notes or published WSL updates. Microsoft may publish WSL kernel updates separately from Windows updates.
  • If you operate large fleets, automate:
  • Use configuration management / CMDB to pull uname and kernel config presence.
  • Automate checks for CONFIG_DRM_V3D or for loaded v3d module and correlate with package versions and VEX/CSAF feeds where available.
If you cannot determine presence from packages or config, treat the artifact as unverified and escalate for artifact‑level inspection or rebuild.
Immediate mitigations and remediation priorities​
  • Apply vendor patches (primary remediation). For Azure Linux customers, MSRC’s VEX/CSAF attestation makes Azure Linux the canonical, immediate priority — apply Microsoft’s published kernel updates or image updates as soon as they are available. For other distributions, apply the fixed kernel packages listed in distro advisories (Ubuntu, Debian, SUSE, etc..
  • If you cannot patch immediately, apply short‑term compensating controls:
  • Restrict access to DRM device nodes (for example /dev/dri/*). Enforce group membership and tighten udev rules so untrusted users and containers cannot access GPU device nodes.
  • Avoid passing /dev/dri into untrusted containers or CI runners.
  • Isolate GPU hosts and avoid running untrusted or multi‑tenant workloads on GPU nodes until patched.
  • Blacklist or unload the v3d module on systems where you can safely disable the driver and where GPUs are not required. Note that this is not suitable for hosts that require GPU functionality.
  • Monitor for symptoms and log signs:
  • Kernel oopses referencing v3d lines, memory leak warnings, repeated GPU reset or scheduler warnings in dmesg/syslog.
  • Unexpected Out‑Of‑Memory events or gradual degradation on GPU nodes.
Detection: practical hunting targets​
  • Search dmesg / journalctl for strings like v3d, drm, gpu scheduler warnings, “timedout_job”, or obvious kernel oops backtraces referencing drivers/gpu/drm/v3d.
  • Check telemetry for processes that frequently exercise GPU code (compositors, rendering jobs, ML workloads) and correlate with host instability or increased memory usage.
  • Look for containers or workloads that mount /dev/dri from hosts; these are higher risk because an unprivileged process in a container could exercise the driver.
Short command examples (run on hosts):
  • grep -i v3d /var/log/kern.log /var/log/messages /var/log/syslog
  • dmesg | grep -E 'v3d|drm|timedout_job|gpu'
  • lsmod | grep v3d
  • zgrep CONFIG_DRM_V3D /proc/config.gz
Operational analysis — strengths, gaps, and risk tradeoffs​
Strengths of Microsoft’s approach​
  • Publishing machine‑readable CSAF/VEX attestations is a meaningful transparency and automation win. For Azure Linux customers it reduces ambiguity and speeds triage by providing a deterministic product‑level decision signal.
Risks and coverage gaps​
  • Phased rollout creates interim inventory blind spots. Microsoft’s initial VEX coverage started with Azure Linux; until the company expands attestations, other MS artifacts remain unverified and organizations must perform their own artifact‑level checks. Treat absence of a VEX entry for a product as “not yet attested,” not evidence of absence.
  • Kernel artifact variance: different kernel builds (WSL2 kernel, linux‑azure kernel, Marketplace images) may enable different drivers or include different backports, so one Microsoft product’s attestation doesn’t automatically apply to another product that sounds similar.
Real‑world consequence model​
  • This class of DRM scheduler bugs is a local DoS/availability risk. For multi‑tenant GPU hosts, a single misbehaving process or untrusted workload could destabilize the host and affect other tenants; for high‑value GPU servers (inference, rendering, ML training) even a memory leak that gradually consumes resources is operationally significant.
What to tell your SOC / patching squad — a prioritized checklist​
  • Treat MSRC’s Azure Linux VEX attestation as canonical for Azure Linux images and patch those first.
  • Inventory Microsoft images and kernels in your estate that are not covered by Azure Linux VEX (WSL2, linux‑azure, Marketplace images, AKS nodes). Automate kernel config and module checks.
  • Apply vendor‑provided kernel updates (distro patches, Microsoft image updates) where available. Cross‑check changelogs for the upstream commit IDs referenced by OSV/NVD entries.
  • Implement short‑term mitigations for unpatched hosts: restrict /dev/dri access, avoid untrusted workloads on GPU hosts, or unload the v3d module where acceptable.
  • Subscribe to MSRC VEX/CSAF feeds and your distro security feeds and configure automated ingestion into your vulnerability management platform — Microsoft has committed to updating CVE attestations should they find additional affected products.
Caveats, uncertainties, and unverifiable claims​
  • The only authoritative Microsoft statement currently published about this specific CVE is the product‑scoped attestation for Azure Linux and the overarching VEX rollout blog; Microsoft’s wording explicitly promises to update product mappings if more Microsoft artifacts are found to ship the component. Absence of attestations for other Microsoft products is therefore not a confirmed negative — it is an incomplete inventory until Microsoft expands the VEX coverage. Flag any claim that “only Azure Linux could be affected” as a misreading of the attestation model.
  • Whether any particular Microsoft product (for example, a specific WSL2 kernel binary shipped with a particular Windows build or a particular Marketplace image) contains the v3d code can only be determined by per‑artifact inspection (kernel config, module presence, package changelog, or an SBOM/VEX entry). That is an operational fact — it cannot be reliably inferred from product names or vendor statements alone. If you need confirmation for a specific SKU or image, perform the artifact checks outlined above or request the SBOM/VEX attestation for that product edition from your vendor contact.
Microsoft’s MSRC attestation that Azure Linux “includes this open‑source library and is therefore potentially affected” is a precise, actionable inventory statement for that product family — and it should be treated as such by Azure Linux customers. At the same time, it is not a categorical guarantee that no other Microsoft product could contain the same vulnerable kernel component for CVE‑2025‑37951. Any Microsoft product or image that ships a Linux kernel built with the v3d scheduler code and a kernel version predating the upstream fix remains a candidate for exposure until verified or patched. Operators should prioritize applying vendor patches (Azure Linux first, per MSRC), inventory and verify other Microsoft artifacts (WSL2, linux‑azure, Marketplace images, AKS nodes), and, where patching is delayed, use compensating controls (restrict /dev/dri, isolate GPU hosts, blacklist v3d where safe). The machine‑readable VEX/CSAF model Microsoft is rolling out will reduce ambiguity over time, but until VEX coverage expands beyond Azure Linux, per‑artifact verification remains a necessary part of a robust remediation program.
Summary of key references used in this analysis:
  • Upstream CVE entries and distribution advisories documenting the v3d scheduler fix and remediation mappings.
  • Microsoft’s MSRC blog announcing the phased CSAF/VEX rollout starting with Azure Linux (October 2025).
  • Independent operational analyses and practical guidance explaining that the MSRC Azure Linux attestation is product‑scoped (not an exclusivity statement).
This guidance is written to support immediate operational decision‑making: patch Azure Linux images first, verify other Microsoft artifacts in your environment, and apply compensating controls where patch deployment will take time.
