CVE-2025-62453 Security Bypass in Copilot and VS Code AI Output
Microsoft has published an advisory for CVE-2025-62453 describing a security feature bypass in GitHub Copilot and Visual Studio Code where improper validation of generative AI output can allow a low‑privileged, authorized user to manipulate AI suggestions and circumvent built‑in safeguards — a local, user‑interaction‑required attack that Microsoft has patched on the vendor side.
Neon blue brain and shield glow over a code window labeled CVE-2025-62, signaling cybersecurity.Background​
The arrival of AI assistants inside IDEs has changed how developers work: tools such as GitHub Copilot and the Copilot Chat extension for Visual Studio Code (VS Code) read repository context and can produce or edit code, configuration and even workspace settings. That convenience creates a new attack surface where model output becomes an active part of developer workflows. The vulnerability recorded as CVE‑2025‑62453 is a direct result of that shift: the underlying issue is improper validation of generative AI output, tracked under a generative‑AI‑specific CWE, and judged to allow a local attacker to bypass a security control by shaping what the assistant suggests. This is not the first set of incidents in this space. In 2025 security researchers disclosed multiple prompt‑injection and exfiltration techniques targeting Copilot and Copilot Chat — including hidden PR comments and proxy chaining that let an attacker trick the assistant into revealing or transmitting sensitive content. Those earlier investigations show the practical ways AI assistants can be coerced into unsafe actions and why vendors have been making rapid iterative changes to VS Code and Copilot behavior.
Overview of CVE‑2025‑62453​
What the advisory says (high level)​
  • The vulnerability is described as improper validation of generative AI output inside GitHub Copilot and Visual Studio Code that permits an authorized local user to bypass a security feature. The MSRC/aggregated advisory entry summarizes the impact and notes a vendor patch is available.
  • The CVSS v3.1 vector published by aggregators indicates a local attack vector, low privileges required, user interaction required, and an emphasis on integrity impact (malicious code suggestions could change program behavior or disable safeguards).
  • The vulnerability was published to vendor feeds on November 11, 2025; Microsoft is listed as the vendor that provided the update details.
Classification and root cause​
  • The entry is associated with a generative‑AI validation weakness, aligned with the emergent CWE class for model output validation (CWE‑1426 in some trackers). The core problem: the client (IDE + extension) accepted or acted on model‑produced suggestions without adequate validation or user confirmation, enabling an attacker with local, low‑privilege access to weaponize those suggestions.
Technical analysis — how the bypass could work​
The precise exploit code for CVE‑2025‑62453 is not public in authoritative feeds at the time of publication; however, the vulnerability pattern maps onto a set of well‑documented attack primitives that have been used against Copilot and similar assistant integrations:
1) Prompt injection and context poisoning​
AI assistants ingest context (open files, PR text, hidden comments, etc.. If an attacker can place attacker‑controlled content into that context, the model may interpret those instructions as authoritative and produce code or configuration changes that perform malicious actions or remove checks.
  • Example vectors: hidden markdown comments in pull requests (remote prompt injection) and hidden metadata in files that assistants consume. Those techniques were used in prior exfiltration research (CamoLeak) and remain relevant to validation bypasses.
2) Auto‑apply or write‑to‑disk semantics​
If Copilot or an extension writes suggestions directly (or assists in creating files that are then saved without sturdy review), a model suggestion can alter configuration files such as .vscode/settings.json or tasks.json. That can flip permissive flags (for example, auto‑approve settings for tools), introduce new MCP endpoints, or change fetch/remediation gating — effectively escalating what the assistant is allowed to do. Several past disclosures demonstrated how modifying per‑workspace config can lead to local code execution or persistence.
3) Trusted‑domain / fetch tool logic flaws​
One concrete class of attack revolves around trusted domains and the #fetch tool in Chat sessions. Researchers found how malformed domain globs or inadequate input validation made certain URLs effectively appear trusted, and if an attacker can make an assistant fetch a URL (via prompt injection), the assistant would do so without a confirmation dialog — enabling remote payload retrieval or data exfiltration. Microsoft changed the behavior for Chat fetches to require confirmations and removed remote image rendering to reduce this class of risk.
4) Proxy hijack and token capture (adjacent risk)​
A separate but related risk observed in prior work was the ability to route Copilot traffic through a malicious proxy and capture authentication tokens, allowing downstream abuse of OpenAI/GitHub APIs. While token capture is a different CVE class, it demonstrates how an attacker can combine local manipulation plus infrastructure abuse to extend impact beyond the local host.
Confirming what is known and what is not​
  • Known: Microsoft and public vulnerability trackers list CVE‑2025‑62453 as a security feature bypass tied to improper validation of generative AI output in Copilot / VS Code, and vendor patches were released on or around Nov 11, 2025. Aggregators show a medium base score and list local attack, low privileges required, and integrity impact.
  • Not proven / unverifiable at present: There is no publicly available proof‑of‑concept (PoC) widely published in authoritative sources at the time of writing, and public evidence of active exploitation in the wild has not been established in mainstream vulnerability databases. Some community reports suggest PoC techniques similar to known prompt‑injection vectors, but those are derivative rather than canonical exploit code for this CVE. Treat such community proofs cautiously until a vendor or respected researcher publishes a full, verified PoC.
  • Aggregator discrepancies: Third‑party feeds sometimes annotate CVE entries with different severity numbers, or conflate separate Copilot/VS Code CVEs. Administrators should always validate affected product versions and KB/patch IDs directly against Microsoft’s Security Update Guide or the official Visual Studio Code security advisories rather than relying solely on aggregator summaries.
Impact — who is at risk and what could go wrong​
This class of issue affects environments where Copilot or Copilot Chat is enabled and actively consumes repository or workspace context. Specifically:
  • Individual developers running VS Code with Copilot enabled on their local machines can be targeted by an attacker who can persuade or coerce them to open malicious content (a crafted PR, malicious repo, compromised dependency, or a repo with hidden comments). Because the attack requires user interaction (opening or querying content), purely remote silent exploitation is less likely, but social engineering and supply‑chain vectors make it practical.
  • Build and CI hosts that allow lesser‑privileged processes to run interactive tools or accept arbitrary workspace content may be exploited to produce unsafe suggestions, inject build‑time changes, or alter signed artifacts — making CI an attractive lateral target if Copilot features are enabled in non‑interactive scripts. This is one reason why many organizations lock down extension installation in shared CI and build agents.
  • Enterprises with a large Copilot deployment have an elevated attack surface because attackers can weaponize AI suggestions to remove safeguards in code or deliver privileged configuration changes indirectly. Historical research has flagged similar attack chains as high impact precisely because a single leaked secret or config change can catalyze significant downstream compromise.
Consequences range from integrity failures (unsafe code generated or security checks bypassed) to operational disruption (malicious tasks added to automated workflows), and — in chained attacks — exfiltration or privilege escalation through configuration manipulation.
Vendor response and immediate mitigation​
Patches and product changes​
  • Microsoft has released updates addressing this category of issue; vendors changed Chat‑related behaviors (for example, requiring confirmations for #fetch calls and disabling remote image rendering in Chat) and introduced input validation for trusted domains and repository URLs in VS Code. These changes are reflected in GitHub advisories and the VS Code security advisory stream. Administrators should ensure VS Code (and the Copilot Chat extension) are updated to the patched version levels published by Microsoft.
Short‑term mitigations (for all users)​
  • Install vendor patches immediately. If updating the IDE fleet is operationally complex, prioritize developer workstations and build hosts. Aggregators and vendor advisories concur that the patch was issued; apply it as your first step.
  • Temporarily disable Copilot/Copilot Chat in high‑risk environments. Where Copilot is not essential, disabling the extension reduces risk until you can apply and validate vendor fixes.
  • Disable remote image rendering and any auto‑apply or auto‑write features that would allow AI suggestions to be persisted without human review.
  • Tighten extension installation policies and limit who can install/enable extensions on corporate developer images. Only allow signed, vetted extensions for build and CI hosts.
  • Harden network egress rules on developer and CI hosts — for example, restrict arbitrary outbound proxy usage or require certificate pinning for Copilot/GitHub endpoints where possible to mitigate proxy hijack risks.
Medium‑term operational controls​
  • Enforce mandatory code review for AI‑generated changes. Treat AI suggestions the same as any PR from an external contributor: require peer review and CI validation gates.
  • Rotate potentially exposed secrets (API keys, tokens) if you find signs of exposure or if developer machines were in a risky state prior to patching.
  • Add detection and monitoring use cases for unusual patterns: spikes in Copilot API activity, unexpected file writes to .vscode or workspace config files, or anomalous outbound requests from developer workstations.
Practical mitigation checklist for enterprise defenders​
  • Identify developer endpoints and build/CI hosts that have Copilot / Copilot Chat installed.
  • Apply the vendor patch to all VS Code instances and Copilot extensions immediately.
  • Disable Copilot Chat features that auto‑render remote content (images, fetches) until you confirm patch behavior.
  • Enforce extension policy via MDM / endpoint management; restrict extension installation to a controlled catalog.
  • Ensure developers understand the risk of opening PRs or repos from untrusted sources; institute compulsory review for AI suggestions.
  • Monitor logs for unusual file writes to workspace config files (.vscode/) and for rapid model‑querying patterns that deviate from baseline.
  • Rotate credentials and secrets exposed to suspect machines; enforce vault usage for secret management.
  • Conduct targeted threat hunts on build hosts and CI for signs of modified build definitions or unexpected network egress.
Why this matters — strategic analysis​
AI integrations into developer tools accelerate productivity but blur the line between suggestion and action. When an assistant becomes capable of editing configs, fetching remote content, or persisting files, model output transforms into an actuator in the development lifecycle. The CVE‑2025‑62453 advisory is a concrete example of that transformation producing a security weakness.
Notable strengths of the vendor and ecosystem response:
  • Rapid hardening of client UX decisions — Microsoft changed Chat features to require more explicit confirmation and removed risky rendering behaviors, reflecting pragmatic risk reduction in client interactions.
  • Fast issuance of vendor patches — public feeds show Microsoft released updates on the same publishing date as the CVE, indicating coordinated response.
However, systemic risks remain:
  • Model‑centric threats are multi‑vector: successful exploitation often overlaps prompt injection, configuration manipulation, and infrastructure abuse (proxy/token theft). Defenders must consider chains rather than single‑point fixes.
  • Visibility and detection are difficult: attackers can exfiltrate small, high‑value items (API keys, tokens) with covert channels — for example, via proxied image fetches — and such activity may appear as legitimate traffic through trusted infrastructure. Prior research and PoCs demonstrate stealthy exfiltration techniques that are easy to miss without tailored telemetry.
  • Patch‑and‑pray is insufficient: updates change the attack surface but do not remove the fundamental tension between convenience and control. Long‑term defenses require architecture and policy changes (separation of duties in workspace access, stricter confirmation semantics, stronger vetting of model context inputs).
Known related incidents and context (brief case studies)​
  • CamoLeak: researchers abused hidden PR comments plus GitHub’s Camo image proxy to covertly exfiltrate secrets by mapping characters to signed image fetches. GitHub mitigated by disabling image rendering in Copilot Chat and blocking the Camo proxy for chat content. This illustrates how seemingly innocuous rendering features can enable exfiltration channels.
  • Affirmation Jailbreak & Proxy Hijack: earlier reports described techniques to coerce Copilot into ignoring guardrails (through cleverly constructed prompts) and to redirect traffic through malicious proxies to steal tokens. Though not the exact same vulnerability as CVE‑2025‑62453, these incidents demonstrate the same class of threat: model output plus client behavior leads to security bypass.
  • Trusted‑domain glob handling in VS Code: a previously disclosed issue in VS Code’s trusted domain logic allowed maliciously crafted URLs to be treated as trusted, enabling fetches with reduced confirmation. Microsoft changed the Chat logic to reduce reliance on the trusted domains service for Chat features. This matches the mitigation pattern now recommended for developers.
Caveats and cautionary notes​
  • Several community posts and third‑party aggregators have reported companion CVEs and similar incidents — some of those posts include severity scores or impact narratives that differ slightly from Microsoft’s advisory. Administrators should always confirm exact affected versions and patch identifiers from Microsoft’s Security Update Guide or the official VS Code security advisories before applying targeted remediations. Overreliance on secondary aggregators can cause mismatch in patch targeting.
  • Some community claims (for example, broad percentages about Copilot adoption in Fortune 500 firms or assertions about large scale exploitation) are not independently verified in vendor advisories and should be treated as context‑building commentary rather than factual progressions of the CVE itself. Flag and verify such numbers before taking action predicated on them.
Longer‑term recommendations for developers and product teams​
  • Treat AI‑provided changes as untrusted input: adopt the same policy for AI suggestions that you have for external contributions (mandatory PR review, CI checks, secret scanning).
  • Apply the principle of least privilege to developer tools: limit what local tools and extensions can do, prevent auto‑write to workspace configurations in high‑risk installations, and isolate build agents into hardened images with minimal interactive features.
  • Improve observability for AI‑tool interactions: log assistant requests and rendered outputs, monitor for spikes in model queries or unusual pattern of remote fetches, and correlate with file writes to workspace config paths.
  • Institute secure defaults in IDEs: by default require explicit confirmation before the assistant may write files, fetch remote URLs, or execute any action that changes local system state.
  • Vendor collaboration: continue to pressure IDE and assistant vendors to treat model output as a new class of input that requires input‑sanitization, provenance tracking, and client‑side guardrails that are robust against context poisoning.
CVE‑2025‑62453 is a striking reminder that the integration of generative AI into development environments transforms assistant output into an active attack surface. The root of this CVE is a failure to validate and treat AI output with the same adversarial caution applied to other untrusted inputs. Microsoft and the community have moved quickly to issue patches and client‑side hardenings (for example, requiring confirmations for fetches and disabling risky rendering behaviors), and those updates should be applied as a priority. At the same time, defenders must think beyond patching: institute operational controls (review gates for AI suggestions, restricted extension policies, stronger endpoint telemetry) and treat developer environments as high‑value targets that deserve the same rigorous security posture as production systems. The intersection of prompt‑injection, config manipulation, and infrastructure abuse will continue to produce novel attack chains unless both vendors and enterprise teams adapt policies and tooling to the new reality of model‑driven workflows.
For Windows and developer administrators responsible for fleets, the practical next steps are simple and non‑negotiable:
  • Update Visual Studio Code and Copilot/Copilot Chat extensions to the patched versions immediately.
  • Enforce mandatory human review of AI‑produced code or config changes.
  • Harden developer endpoints and CI hosts, restrict extension installation, and monitor for anomalous model activity.
These actions will close the immediate window of exposure and buy time while the industry develops more robust validation, provenance, and runtime safeguards for generative AI inside development tools.
