CVE-2025-68222: Fix for uninitialized pinctrl s32cc fields in Linux kernel
A recently assigned CVE — CVE-2025-68222 — calls attention to a subtle but impactful class of bugs in the Linux kernel: uninitialized structure fields in device-driver descriptors. The vulnerability affects the NXP S32 SoC family pin controller driver (pinctrl: s32cc) and was recorded after maintainers fixed code that allocated a pin controller descriptor with uninitialized memory. The result: intermittent device-tree parsing failures and allocation errors during probe of dependent drivers (notably I2C adapters), producing kernel splats and unstable hardware bring-up on affected boards. This article explains what happened, why it matters for systems running NXP S32 platforms, how the kernel maintainers fixed it, and what Linux integrators and embedded maintainers should do now to validate and mitigate risk.
Glowing circuit diagram featuring a chip labeled pinctrl_s32cc and a could not parse node property error.Background / Overview​
The Linux pin control (pinctrl) subsystem maps SoC pin multiplexing and pin configuration information from firmware (typically device tree) into in-kernel data structures so that pinmux/pinconf drivers can configure pins for peripheral use. In many SoCs the pin controller provides an array of descriptor fields that describe both generic pin configuration parameters and custom, driver-defined properties.
The NXP S32 family support is provided by a pin controller driver normally referenced as pinctrl-s32cc (sometimes shortened to s32cc). When the driver probes, it allocates and populates a struct pinctrl_desc variant (here named s32_pinctrl_desc) that includes fields such as custom_params and num_custom_params. Those fields tell the generic pinconf parser how many extra DT properties to expect and how to parse them.
CVE-2025-68222 stems from the s32_pinctrl_probe path allocating the descriptor with devm_kmalloc — which returns uninitialized memory — and then failing to initialize all descriptor members. A key field, num_custom_params, was left with an indeterminate value. Later, the common parsing function pinconf_generic_parse_dt_config consults pctldev->desc->num_custom_params while sizing temporary arrays used to parse device-tree pinconf properties. If num_custom_params contains garbage a very large allocation size can be requested or logic can behave incorrectly, producing allocation failures, warning traces, and downstream parse failures that prevent peripherals (like I2C adapters) from being probed reliably.
The symptoms reported in kernel logs are intermittent allocation failures and “could not parse node property” errors during probing of I2C pin groups, with stack traces pointing into the pinconf parsing path and eventually into memory allocation helpers. While this class of bug is not inherently a remote-execution vector, it can lead to local denial-of-service (system instability or failed device bring-up) on targeted hardware.
The technical root cause​
What went wrong: uninitialized descriptor fields​
  • The driver used devm_kmalloc to allocate s32_pinctrl_desc. That API allocates memory but leaves it uninitialized.
  • Not every member of s32_pinctrl_desc was assigned a defined value after allocation. Most notably, num_custom_params (an unsigned integer indicating how many driver-specific DT params exist) could remain containing whatever stack/heap garbage happened to be in that memory.
  • Later, pinconf_generic_parse_dt_config or related pinconf-generic paths read pctldev->desc->num_custom_params to compute how large an intermediate buffer must be to parse both generic and custom DT parameters. If the field is unexpectedly large (garbage), the parser requests an allocation that may fail or corrupt memory accounting — leading to the kernel warnings and failed DT parsing observed.
Why it surfaced for dependent drivers​
The driver’s mis-initialization doesn’t typically corrupt user data or create remote code execution; instead, it leads to logic errors while parsing device tree properties. The kernel’s pinconf parsing code attempts to allocate temporary arrays sized by the expected number of parameters. Garbage in num_custom_params can either:
  • Make an allocation request unreasonably large, causing allocation failure and printing a kernel warning/backtrace (a splat).
  • Or cause the parser to attempt to parse non-existent properties, producing could not parse node property errors for pingroups used by other drivers (I2C, SPI, UART). That breaks those drivers’ probe flows and can leave peripherals unusable.
Because the failure is deterministic only when memory happens to contain “bad” values, the issue manifested intermittently on some boards — e.g., NXP S32G3 reference designs — making diagnosis trickier.
The kernel fix(es)​
Maintainers applied straightforward, defensive fixes to remove reliance on uninitialized memory and to explicitly set descriptor fields to known values. There are two complementary changes in the patch series that remediate the issue:
  • Replace devm_kmalloc with devm_kzalloc in s32_pinctrl_probe when allocating s32_pinctrl_desc. devm_kzalloc zeroes the allocation, guaranteeing all descriptor fields start as zero (or NULL) and preventing garbage values from being seen later.
  • Explicitly set s32_pinctrl_desc->num_custom_params to 0 after population of standard ops/fields, as a belt-and-suspenders measure in case allocations change or additional fields are added later.
  • In a companion patch maintainers ensured other dynamic data (like linked lists or pointers) are properly initialized after any kmalloc-style allocations.
These changes are minimal but follow kernel best practices: zero-initialize driver descriptor memory and always explicitly initialize fields that will be read by generic subsystems.
Timeline of fixes (concrete dates):
  • An early patch changing/adding robustness around descriptor initialization was circulated to maintainers in July 2025.
  • A follow-up patch and test sign-offs were exchanged in November 2025.
  • The issue was tracked as CVE-2025-68222 and recorded in public vulnerability databases on December 16, 2025.
(Any exact commit IDs and backport locations will vary by distribution; integrators should confirm the patch in their kernel tree or vendor BSP.
Who and what is affected​
  • Affected component: drivers/pinctrl/nxp/pinctrl-s32cc.c in the Linux kernel tree — the NXP S32 SoC family pin controller driver.
  • Typical visible impact:
  • Intermittent kernel warnings/backtraces during boot or device probe (allocation failures in memory allocator code paths).
  • Device-tree pinconf parsing failures: messages like could not parse node property for pin groups.
  • Dependent driver probe failures (for example, i2c-imx or other peripheral drivers that rely on pinctrl groups), leading to absent I2C adapters or other hardware that fails to initialize.
  • Affected platforms: systems running kernels that include the vulnerable form of the pinctrl-s32cc driver — especially embedded boards built around NXP S32 families (S32G3 and similar). The issue is most visible where custom DT bindings and custom pinconf params are in use.
Severity and exploitability
  • This vulnerability is primarily a reliability/availability bug: it can cause device bring-up to fail or the kernel to issue allocation warnings.
  • It is not an obvious remote code execution flaw. There is no public evidence that the flaw allows privilege escalation or remote exploitation without additional local access.
  • Because the bug manifests as unpredictable allocation or parsing failures, it can be rated as a medium-to-low security risk from the viewpoint of classic CVSS impact vectors — but it is high-priority operationally for embedded device maintainers where hardware initialization must be reliable.
Practical mitigation and remediation steps​
For system integrators, embedded maintainers, and distro kernel teams who manage NXP S32 platforms, follow these remediation steps in order:
  • Identify whether your deployed kernel contains the vulnerable code
  • Search your kernel source tree for the driver file:
  • drivers/pinctrl/nxp/pinctrl-s32cc.c
  • Inspect the probe allocation call and initialization:
  • If you find devm_kmalloc(&pdev->dev, sizeof(*s32_pinctrl_desc), GFP_KERNEL) and missing explicit initialization for num_custom_params, the tree is vulnerable.
  • Apply the upstream patch or cherry-pick the upstream commit
  • The upstream fixes replace devm_kmalloc with devm_kzalloc and explicitly set num_custom_params = 0.
  • If you maintain a downstream BSP or backport branch, cherry-pick the exact commit(s) into your tree and resolve conflicts.
  • Rebuild and test the kernel
  • Rebuild your kernel image/packages with the patch applied.
  • Boot representative hardware and validate the pinctrl probe path:
  • Check dmesg for absence of allocation splats and could not parse node property errors.
  • Validate peripheral probes (I2C, SPI, UART) that previously failed.
  • If you cannot immediately upgrade, apply a local workaround for production images
  • Temporarily: add a device-tree and driver testing step to early firmware bring-up scripts to detect probe failures and trigger fallback initialization scripts.
  • Operationally: prioritize updates for devices where I/O peripherals must be reliable (manufacturing test fixtures, gateways, automotive units).
  • Coordinate with your distro or vendor
  • Push the patch into your distribution’s kernel stable branch or request vendor BSP updates.
  • For long-term support kernels, maintainers should backport the minimal patch rather than sweeping changes.
  • Prevent similar regressions going forward
  • Add unit or integration tests that exercise pinconf parsing on representative DTs.
  • Add CI checks that grep for devm_kmalloc usage in driver descriptor allocations and flag uninitialized struct usage.
  • Consider static analysis tooling to detect uninitialized reads of structure members used by cross-subsystem APIs.
Numbered, sequential example commands (for maintainers comfortable with source trees):
  • Clone or fetch your kernel tree and check for the vulnerable call:
  • git grep -n "pinctrl-s32cc|s32_pinctrl_probe" -- drivers/pinctrl
  • If missing patch, apply upstream patch (example):
  • git cherry-pick <commit-id> (use the commit ID from upstream that replaces devm_kmalloc with devm_kzalloc and initializes the fields)
  • Build and install kernel:
  • make -j$(nproc) && make modules_install install
  • Reboot test hardware and validate:
  • dmesg | grep -i pinctrl
  • dmesg | grep -i "could not parse node property|pinctrl"
Why this class of bug keeps recurring (analysis & recommendations)​
This vulnerability is a textbook example of a classic C gotcha: allocation without initialization followed by downstream reads of uninitialized members. Embedded driver codepaths are particularly vulnerable because:
  • They interoperate with generic subsystems (pinctrl, pinconf) that assume descriptor values are valid.
  • Device-tree bindings and custom parameter arrays often change across SoC families; drivers evolve and fields get added.
  • Some allocations are done with managed helpers (devm_kmalloc) where developers may not be explicit about zero-initialization, and the difference between kmalloc and kzalloc is easy to miss during fast prototyping.
Operational recommendations to reduce recurrence:
  • Default to kzalloc/devm_kzalloc when allocating descriptor structs that will be read by other subsystems.
  • Explicitly initialize every struct member that will be read by other modules, even if the allocation is zeroed — defensive initialization improves readability and future-proofing.
  • Strengthen the pinctrl/pinconf generic parsing code to be resilient in face of inconsistent driver descriptors (e.g., clamp num_custom_params to reasonable bounds before using it to size allocations).
  • Add automated CI tests for DT parsing with a variety of pinctrl descriptors to catch mismatches early.
  • Use static analyzers (sparse, clang static analyzer) configured to flag potential use of uninitialized struct members.
Operational impact and risk assessment​
  • For desktop or server Linux, this CVE is unlikely to be relevant because the affected driver targets NXP S32 embedded platforms. For embedded, automotive, and industrial systems using NXP S32 SoCs, the impact is practical and immediate: unreliable peripheral initialization and potential production test failures.
  • Although not a “kernel RCE” style finding, it is still a liability: in production embedded systems, losing functional I2C or other bus adapters at boot can be catastrophic for devices that need those peripherals for sensors, actuators, or communications.
  • The fix is small and low-risk to apply: zero-initialize the descriptor and explicitly set fields. That makes remediation straightforward for vendors and downstream maintainers, but it must be backported for LTS/bespoke kernels.
Caveats and unverifiable areas
  • While vendor and community mailing-list messages and the public CVE entry describe the issue and the upstream patches, the exact set of distribution kernel versions that include the fix depends on vendor backports. Integrators must verify their shipped kernel trees.
  • There is no public proof-of-exploit demonstrating privilege escalation; the observed effects are kernel warnings and probe failures. Any further security implications would require additional exploit chaining and have not been reported publicly.
Checklist for engineers and maintainers (quick reference)​
  • Verify whether your kernel contains the vulnerable driver:
  • Locate drivers/pinctrl/nxp/pinctrl-s32cc.c and inspect the probe allocation.
  • If vulnerable:
  • Apply the upstream patch(s) which replace devm_kmalloc with devm_kzalloc and initialize num_custom_params.
  • Rebuild kernels for affected devices and run hardware validation tests (I2C, SPI, UART).
  • If you are a vendor:
  • Push the patch into your BSP and notify customers with affected hardware.
  • Add a test to your CI that exercises DT parsing for pinctrl entries.
  • If you run a device fleet:
  • Schedule a maintenance window to deploy updated kernels once validated.
  • Monitor boot logs for continued errors prior to deploying the fix.
Broader lessons​
CVE-2025-68222 is a small bug with outsized operational consequences for the right (or wrong) hardware. It underscores a few evergreen truths for kernel and embedded development:
  • Small memory-initialization omissions are low-cost to fix but can produce intermittent and hard-to-diagnose failures that ripple through driver stacks.
  • Defensive programming (zero allocations, explicit initialization) and cross-subsystem contracts (how many custom params a descriptor exposes) prevent brittle behavior.
  • Rapid patching and clear backporting are essential for embedded supply chains, where a single kernel bug can stall manufacturing or field deployments.
  • Static analysis and targeted unit tests that simulate device-tree parsing should be standard in pinctrl-related patches.
CVE-2025-68222 exposed a straightforward yet disruptive bug in the Linux pinctrl support for NXP S32 SoCs: structure members used by generic pinconf parsers were left uninitialized, resulting in allocation splats and peripheral probe failures on some hardware. The fix — zero-initialize descriptor allocations and explicitly set num_custom_params to zero — is minimal and safe, but the incident serves as a reminder: in kernel code, especially in cross-subsystem interfaces, always initialize what you read. Embedded device integrators should verify their kernel trees, apply the upstream patch or corresponding vendor update, rebuild and test their kernels on representative hardware, and add checks in CI to prevent regressions. The operational cost of inaction is unnecessary device instability; the engineering cost of the fix is negligible.
Support hub
