polare
Got some problems with the DPI om my MSI GE70 notebook (win 64-bit). When I open a program with non-expanding window, boxes cut off text/buttons/fields to the right and bottom.
I have already tried Adjust screen resolution / Adjust font size / Adjust DPI / Adjust clear type but no luck there. And I have tried Change color scheme, no luck there either..
This is how it looks like when I open the program, as you can see here on the right there are some buttons missing like "Open Video File button", "Output Folder button" because the File Info is overlapping the buttons. And this problem is on EVERY program i open!
It seems like you're facing display scaling issues on your MSI GE70 notebook running Windows 64-bit. When programs with non-expanding windows display cut off text, buttons, or fields, it's likely due to the DPI scaling settings being misconfigured. Here are a few additional steps you can try to resolve this issue: 1. Compatibility Settings: - Right-click on the program's shortcut or executable file. - Select "Properties" and go to the "Compatibility" tab. - Check the box next to "Disable display scaling on high DPI settings." - Click "Apply" and then "OK." 2. Check Advanced Scaling Settings: - Go to Settings > System > Display. - Scroll down to the "Scale and layout" section. - Click on "Advanced scaling settings." - Toggle...
It seems like you're facing display scaling issues on your MSI GE70 notebook running Windows 64-bit. When programs with non-expanding windows display cut off text, buttons, or fields, it's likely due to the DPI scaling settings being misconfigured. Here are a few additional steps you can try to resolve this issue: 1. Compatibility Settings: - Right-click on the program's shortcut or executable file. - Select "Properties" and go to the "Compatibility" tab. - Check the box next to "Disable display scaling on high DPI settings." - Click "Apply" and then "OK." 2. Check Advanced Scaling Settings: - Go to Settings > System > Display. - Scroll down to the "Scale and layout" section. - Click on "Advanced scaling settings." - Toggle on the "Let Windows try to fix apps so they're not blurry" option. 3. Custom Scaling Level: - Go to Settings > System > Display. - Under "Scale and layout," try adjusting the percentage to a custom value rather than the recommended one. 4. Update Graphics Drivers: - Ensure that your graphics drivers are up to date. Visit the MSI support website to download and install the latest drivers for your specific model. 5. Reset Display Settings: - In the "Display" settings, under "Scale and layout," try changing the scaling to a different value, apply the changes, and then revert back to the original setting. 6. Check for Windows Updates: - Make sure your system is up to date by checking for and installing any pending Windows updates. Give these steps a try and see if any of them help resolve the display scaling issues you're experiencing. Let me know if you need further assistance!
