musiclover2000
Well-Known Member
Hello everyone,
I'm trying to install the latest version of Zorin on a Toshiba Tecra A9 s9015x laptop it currently has windows vista. I'm getting this error EDD: Error 2000 reading sector 750555 No default or UI configuration directive found.
I've attempted this twice with to diffrerent DVD burners and getting the same error. I was using those cheap memorex DVD+R disks don't know if that may have something to to with it. I'm using a program called ImgBurn and using the slowest burning supported by by burners.
Any help on this would be very much appreciated.
Thanks
Sounds like it cant read the media. Do you have a usb you can make bootable?
Yes I do. I'll give that a try and see what happens.
Thanks
