You made that change in the settings?Chrome
I'm not quite sure you're in the right place. Following out lined path from above.....when in the default apps there is only 6 apps listed. The last one is browser click that and then choose what browser you want as the default.Did as rec...- menu sez -- modify or uninstall. modify grey. do not wish to uninstall.
