I have tried numerous times in both Command Prompt and Power Shell to set the Environment Variable for "Path" and it will not stick. I have tried running as admin as well.
If I test it in the open CMD or Powershell Window it seems to stick, but if I open a new window it is gone. If I go through System Properties and add it manually that way, it works just fine. Unfortunately I need it to work through a batch file or script.
I am running Windows 7 Pro 64-bit.
CMD code I have tried:
Power Shell code I have tried:
Set Path = C:\Program Files\Java\jdk1.7.0\bin;%Path%
Set Path = C:\Program Files\Java\jdk1.7.0\bin\;%Path%
Set Path = "C:\Program Files\Java\jdk1.7.0\bin";%Path%
Set Path = "C:\Program Files\Java\jdk1.7.0\bin\";%Path%
$Env:Path = $Env:Path + ";C:\Program Files\Java\jdk1.7.0\bin"
$Env:Path = $Env:Path + ";C:\Program Files\Java\jdk1.7.0\bin\"
