Microsoft Excel for Mac users have long voiced their desire for feature parity with the Windows version, particularly when it comes to multitasking and data management. One of the most requested functions—the ability to view multiple worksheets side by side—has finally arrived, albeit with a few caveats. This article examines the rollout of this much-anticipated feature, details its usage, and evaluates its implications for productivity and the broader Microsoft Excel ecosystem. Drawing on verifiable sources and hands-on documentation, we weigh the strengths, limitations, and potential future developments surrounding Excel for Mac’s new multitasking capabilities.
A laptop displaying colorful bar and pie charts alongside a cup of coffee on a white desk.
A Long-Awaited Update: Bridging the Productivity Gap​
The lack of side-by-side worksheet viewing in Excel for Mac has historically limited the workflow for power users, accountants, analysts, and anyone regularly juggling complex datasets. Windows users have enjoyed this feature for years, leading to a familiar refrain in Apple-oriented forums and feedback channels: When will Mac catch up?
The update, announced in a recent Microsoft 365 Insider blog post, directly addresses this gap. According to Microsoft, the latest Excel for Mac now supports viewing multiple worksheets simultaneously, not only from the same workbook but also from separate files. This enhancement, while seemingly subtle, promises significant boosts in productivity and accuracy for Mac users who rely on Excel for serious data manipulation.
Critically, as of this writing, this new side-by-side worksheet view is only available to users enrolled in the Microsoft 365 Insider Program and requires Excel for Mac Version 16.97 (Build 25041535) or later. There is no official announcement for general availability yet. Multiple sources, including Windows Report and the Microsoft 365 Insider blog, confirm these requirements, and users are encouraged to update their software and enroll in the Insider channel to gain early access.
Hands-On: How to Use the Side-by-Side Worksheet Feature​
Activating the side-by-side worksheet view in Excel for Mac is designed to be intuitive but might not be immediately apparent to all users—especially as the feature isn’t currently accessible via the in-app Search. Microsoft outlines the following workflow:
  • Open a Worksheet: Start by opening your desired worksheet in Excel for Mac.
  • Pop Out a Sheet: Select the sheet you wish to view in a separate window. Navigate to the ‘View’ tab and choose ‘New Window.’ This opens the current worksheet in an additional window.
  • Open Across Workbooks: For comparison across different files, select ‘New Window’ in one workbook, then go to File > Open to bring up a second sheet in another workbook.
  • Arranging Windows: To activate the feature, select the ‘View Side by Side’ icon, which stacks the worksheet windows for easy comparison.
  • Additional Controls:
  • Reset Window Position: If you rearrange the windows, you can reset them to their default side-by-side orientation using the ‘Reset Window Position’ option.
  • Synchronous Scrolling: When ‘View Side by Side’ is active, ‘Synchronous Scrolling’ lets you scroll both worksheets simultaneously—a boon for row-by-row comparison.
It’s important to note that because the feature is still under Insider testing, there may be minor inconsistencies or interface quirks. According to user feedback and the official documentation, the ‘View Side by Side’ button isn’t found via Excel's Search feature—a limitation users should be aware of during this preview period.
Major Strengths: Enhanced Workflow and Data Integrity​
1. Seamless Comparison and Analysis​
For professionals working with large datasets, comparing figures, formulas, or trends across sheets is now substantially more efficient. Previously, users needed to repeatedly switch tabs, copy data into temporary sheets, or use cumbersome workarounds like splitting data across separate monitor windows. With side-by-side viewing, context is maintained, reducing mental load and the risk of errors.
2. Faster, More Accurate Data Entry​
Data verification and entry gain new efficiencies. For example, finance teams tracking changes, cross-referencing totals, or reconciling ledgers can now see both the source and destination data in a single glance. This enhanced visibility aids in catching discrepancies before they propagate throughout a workbook or project.
3. Improved Workflow for Collaborative Environments​
Many organizations, especially those standardizing remote or hybrid work, depend on real-time collaboration within Excel. The new multitasking capability, when paired with co-authoring tools, can streamline meetings, reviews, and group editing sessions—provided participants use compatible versions and channels.
4. Professional Consistency Across Platforms​
By closing the feature gap with Windows, Microsoft helps unify the Excel experience. This may reduce training costs and friction when teams use mixed-device environments—a frequent scenario in modern enterprises.
Limitations and Risks: What Mac Users Should Know​
1. Restricted to Microsoft 365 Insider Program​
As of mid-2024, only users who opt into the Microsoft 365 Insider Program and update to the required version can access side-by-side worksheet viewing. This limitation effectively gates the feature behind a willingness to run preview builds, which may be less stable than production releases. IT administrators, especially in enterprise or education settings, should weigh the risks of adopting Insider builds against the urgency of this feature.
2. Learning Curve and Discoverability​
Given that the 'View Side by Side' feature isn’t currently indexed by Excel’s Search, new users may struggle to find it without consulting release notes or external guides. This makes documentation and in-app onboarding all the more critical.
3. Potential for Bugs and Feature Inconsistencies​
Public preview features carry an inherent risk of bugs or interface inconsistencies. Early testers have occasionally reported UI glitches—such as misaligned window positions or scrolling desynchronizations—though these are generally addressed in subsequent Insider updates.
4. No Timeline for General Release​
At the time of writing, Microsoft has not communicated a firm schedule for the general rollout beyond the Insider program. Enrolled users gain immediate access and can provide feedback that may accelerate public release, but mainstream Mac users will need patience or an opt-in strategy.
5. Compatibility and System Requirements​
This update requires Excel for Mac Version 16.97 (Build 25041535) or newer. Users on perpetual-license versions (such as Office 2019 or 2021) or legacy Office suites will not receive this capability. To enable it, users must ensure their Microsoft 365 subscription and update channels are correctly configured.
Comparing Excel for Mac to the Windows Experience​
While this update brings Excel for Mac closer to feature parity with Windows, differences remain. Power Query, certain VBA features, and advanced Add-Ins still favor the Windows ecosystem. However, Microsoft’s release cadence and focus on the Mac platform have accelerated in recent years, partly in response to the rapid transition of business and educational environments to Apple hardware—especially with the advent of Apple Silicon.
Some additional nuances exist around window management: macOS and Windows handle application windows and tiling differently, which might affect how users organize their Excel sheets, especially on smaller screens.
Security and Privacy Considerations​
From a cybersecurity perspective, the introduction of side-by-side worksheet viewing presents minimal new risk. The feature simply manages window arrangement and presentation, not data access or sharing. However, Insider builds may occasionally introduce bugs or regressions that could affect reliability or expose minor glitches in file handling.
Microsoft’s Insider channel practices and feedback loops are transparent and have a proven record of gradually delivering high-demand features to stable branches. Prospective testers are urged to back up important work and regularly monitor the Microsoft 365 Insider Blog for issue reports and progress updates.
Productivity Tips: Making the Most of Side-by-Side Viewing​
  • Use Multiple Monitors: Combine Excel’s new feature with macOS’s built-in window management (such as Mission Control or Split View) for ultra-productive setups, especially when working on large financial models.
  • Leverage Synchronous Scrolling: This is particularly handy when comparing rows or auditing formula changes across structurally identical sheets.
  • Reset Window Position: If window arrangements become cluttered, this button instantly restores order—a subtle, time-saving touch.
  • Stay Updated: Since the Side by Side feature is currently evolving, frequent updates ensure better performance and feature completion.
Observations and Outlook: What’s Next for Mac Excel?​
Microsoft’s shift toward cross-platform feature parity is evident not just in Excel, but across the Office suite. Regular updates, user-centric releases, and a robust Insider testing ecosystem indicate the company’s commitment to bringing Mac experience ever closer to the much-praised Windows version.
Critically, the rollout of side-by-side worksheet viewing on Mac is not merely a matter of checking off a long-standing community request. It reflects a broader trend: business and academic institutions, which increasingly use Mac hardware, are demanding consistent, high-productivity tools regardless of platform.
Insider-only features can sometimes indicate longer periods of user feedback and bug squashing, which tend to lead to more polished stable releases. Still, the absence of a firm public release date may frustrate some Mac users, especially those working in environments where IT policies restrict preview software installations.
Final Analysis: A Substantial Step Forward—With Caveats​
The introduction of side-by-side worksheet viewing in Excel for Mac is a clear win for productivity, accuracy, and professional consistency. It closes a long-standing gap between Mac and Windows Excel, delivering tangible benefits for anyone managing or comparing complex datasets. Its strengths—seamless analysis, reduced errors, faster data entry, and enhanced collaboration—are well-documented and readily verifiable through official Microsoft sources and independent user feedback.
However, these advantages must be balanced against current limitations: restricted availability, the need for Insider participation, minor discoverability issues, and dependency on up-to-date software. While public interest and user demand suggest that a general release is likely, those who want access now must navigate the risks and responsibilities associated with running preview builds.
For most Excel for Mac users, especially those in data-driven professions, the new side-by-side feature will prove invaluable—once it becomes generally available. Until then, the steady march toward cross-platform parity continues, powered by community feedback, Insider enthusiasm, and Microsoft’s evolving cloud-first strategy.
Mac users seeking up-to-the-minute multitasking muscle in Excel should consider joining the Insider program—for early access, a direct line to product feedback channels, and a front-row seat to upcoming productivity enhancements. For everyone else, patience is advised: based on past trends, features that debut in the Insider program often reach the mainstream within a matter of months.
In conclusion, Excel for Mac’s newfound multitasking prowess signals more than incremental progress; it represents an ongoing commitment to productivity, flexibility, and user-centric innovation across platforms. As the feature matures, careful monitoring, community engagement, and responsive development will determine how quickly and smoothly it reaches all users—ensuring that, someday soon, “feature gap” is a phrase of the past for Excel users, no matter their device.
Source: Windows Report Microsoft Excel for Mac now allows viewing mutiple worksheets side by side
