ismael2022
when my Primary DC fails or shutdown Exchange serve stopped
how can i make exchange connect to Secndary DC after Primary Failed
Neemobeer
Windows Forum Team
Do you have a static DC set for exchange?
Should be able to tell from the Exchange Powershell module.
Get-ExchangeServer
ismael2022
DC in exchange as you said its static defined.
How to change it to be dynamic?.
In case of Primary DC failed or stopped, exchange redirect to secondary DC
Neemobeer
Windows Forum Team
I don't believe you can tell it to not be static; however, you can assign it multiple DCs with the Set-ExchangeServer command
Neemobeer
Windows Forum Team
Set-ExchangeServer -StaticGlobalCatalogs GCDC01.example.com, GCDC02.example.com -StaticDomainControllers DC01.example.com, DC02.example.com -StaticConfigDomainController DC01.example.com, DC02.example.com
