File Deletion Without Event Viewer Entry: Seeking Insights and Solutions
techquest
Well-Known Member
got file deleted,no entry in eventviewer,did anyone faced similar kind of issue?
system not connected to internet since longtime,if someone knows password there will be entry in the eventviewer
You're absolutely right that any logon to your Windows account—especially with a correct password—should typically generate an Event Viewer entry (under Security > Audit Success/Failure) if auditing is enabled. If your system is not connected to the internet and you haven't seen unauthorized logins, a mysterious file deletion with no Event Viewer trace can still have non-malicious explanations, though rare.
Common causes for files moving to Recycle Bin without an Event Viewer entry:​
  • Accidental Deletion by User or Software:
  • Some applications delete files silently or manage temporary files, and these deletions aren't always logged unless you have File System auditing enabled via Group Policy.
  • Built-in...
  • Built-in Windows file audits are not enabled by default—it takes custom configuration.
  • Scheduled Tasks or System Maintenance:
  • Built-in maintenance or cleanup operations can sometimes delete or move files.
  • Third-Party Tools or Scripts:
  • Utility software or batch scripts might delete files (e.g., disk cleanup tools, optimizers).
  • Explorer Glitches or User Error:
  • Drag-and-drop mishaps or even double-clicking [Del] can move files to the Recycle Bin without obvious notice.
Security/Auditing Facts​
  • Default Windows logs do NOT record every file delete action.
  • They record authentication/logon, but file operations (like delete) require explicit “Object Access” auditing to be set up in Group Policy. If not configured, standard file deletions don’t show in logs.
  • If someone logs in with your account, it is usually logged under Windows Security events.
  • If you see no extra logins or failed attempts, it’s unlikely (though not impossible) someone bypassed things entirely and deleted a file.
  • Physical access:
  • Anyone with physical access can circumvent many protections; using boot media, they can alter or delete files without any trace in the Event Viewer, especially if they use tools that do not boot the normal OS.
Community Experience​
  • You're not alone: Other users have reported files disappearing or being deleted without explanatory logs, often due to odd bugs or maintenance tools rather than malicious access.
  • In enterprise or domain setups, group policies or software restrictions can affect Recycle Bin behavior, but for standalone systems not on a domain and offline, this is much less likely.
Practical Suggestions
  • Review what software you have installed: Look for cleanup utilities or tools you've used recently.
  • Audit Settings: If you want future deletes audited:
  • Open gpedit.msc > Computer Configuration > Windows Settings > Security Settings > Advanced Audit Policy Configuration > Object Access > Audit File System.
  • Enable “Success” and “Failure” for detailed file delete logs (note: can flood logs if overused).
  • Antivirus scan: Glitches or unwanted programs might misbehave.
  • Check for scheduled tasks or scripts: Review Task Scheduler for anything that might have acted on your files.
Bottom line:
For most home users, accidental deletion or (if unattended/guest access is possible) human error is the usual cause. True undetected hacking without leaving a trace on a disconnected, offline machine is nearly impossible without physical access or inside help.
If you want to harden your system, you might consider enabling file-level auditing and reviewing your local user accounts for any changes.
If you still suspect foul play (especially if files vanish repeatedly), a hardware keylogger or direct disk access is possible—but quite rare. Let us know if you notice further oddities!
You’re right—and here’s how to make deletions show up reliably​
By default, Windows won’t log file deletions unless Object Access auditing is enabled and the target folders/files have an audit rule (SACL). Do this:
1) Verify prerequisites
  • Drive format: ensure the volume is NTFS (auditing doesn’t work on exFAT/FAT32).
  • If the files live on a network share, the logs will be on the file server, not the client.
2) Enable the right audit subcategories (local or via GPO)
Run in an elevated PowerShell/Command Prompt:
auditpol /set /subcategory:"File System" /success:enable /failure:enable
auditpol /set /subcategory:"Handle Manipulation" /success:enable /failure:enable
auditpol /set /subcategory:"Detailed File Share" /success:enable /failure:enable (if using SMB shares)
auditpol /get /category:* (verify)
3) Add a SACL on the folder you care about
  • Right‑click folder > Properties > Security > Advanced > Auditing > Add.
  • Principal: Everyone (or the group of interest).
  • Type: Success and Failure.
  • Applies to: This folder, subfolders and files.
  • Permissions: check Delete and Delete subfolders and files.
4) Correlate the events
  • Security log: 4663 (access attempt with “Accesses: DELETE”), 4660 (object deleted), 4656 (handle requested).
  • Also enable process lineage to identify the deleter:
    • Turn on “Audit Process Creation” (success) and enable “Include command line in process creation events.”
    • Then correlate 4688 (process created) with the Subject/Process ID in 4663/4660.
5) Optional but highly effective: Sysmon
  • Install Sysmon with a reputable config (e.g., SwiftOnSecurity). You’ll get:
    • Event ID 23: FileDelete
    • Event ID 26: FileDeleteDetected (for captured/deferred deletes)
      This makes spotting and attributing deletions much easier.
6) Quick triage commands
  • Recent delete attempts (last 24h):
    Get-WinEvent -LogName Security -FilterHashtable @{Id=4663; StartTime=(Get-Date).AddDays(-1)} |
    Where-Object {$_.Message -match "Accesses:\s+.*DELETE"} |
    Select-Object TimeCreated,
    @{n='Object';e={($_.Message -split "Object Name:\s+")[1] -split "`r?`n" | Select-Object -First 1}},
    @{n='Process';e={($_.Message -split "Process Name:\s+")[1] -split "`r?`n" | Select-Object -First 1}},
    @{n='Account';e={($_.Message -split "Account Name:\s+")[1] -split "`r?`n" | Select-Object -First 1}}
  • Signs of tampering/bypass:
    • 1102 (audit log cleared), 4719 (audit policy changed), unusually small Security log, or deletion performed offline/with boot media (no logs on the OS).
7) Best practices
  • Increase Security log size and set retention to “Do not overwrite” or a long retention window.
  • Limit who can clear logs; forward Security logs to a SIEM/Event Collector so local tampering is less effective.
Note: The fitness tool mention is off-topic for this thread, so keeping focus on the Windows side.
If you can share a bit more:
  • What version/edition of Windows?
  • Local disk or SMB share/OneDrive/Dropbox sync folder?
  • Do deletes happen interactively or via a scheduled task/service?
  • Any relevant event IDs you’re already seeing?
