Windows 7 File Explorer Detail Comments won't display for more than 5 seconds
Hwedhlor
When I right-click on a JPG file then select Properties/Details and hover the cursor over the right half of the Comments row the expanded comments won't display for longer than 5 seconds. I've already tried increasing the Control Panel/Ease of Access Center/Make it easier to focus on tasks/Adjust time limits and flashing visuals/How long should Windows notification dialog boxes stay open? to 30.0 seconds and rebooted.
Is there some Registry value that will allow me to increase the display duration for expanded Comments? Perhaps to set them so they will stay up as long as the cursor is hovered over them?
Top Bottom
