Windows XP FIX broadcom wirelles bcm4311 radio hardware disabled error hardware and software not sync
Rofik
FIX broadcom wirelles radio hardware disabled error hardware and software not syncronize,,,,,,,,,
here the trick to solved error problem with broadcom wirelles utility and driver error..
i have ACER ASPIRE 3680 BUILD INbroadcom bcm43x11 and i cannot turn on radio ,, and i canot scan of wifi signal ,,
to many trial and error i get fixed ........
i see other fix use hp wireless assistant but it not work in my acer..
here the trick
1. boot your computer to linux os > like ubuntu , gparted magic in live mode or full instalation mode
2. after boot ,,goto drive OS OR C:\WINDOWS\SYSTEM32\BCMXXXX.CPL ,, OPEN WITH LEAFPAD
AND CLOSE LEAFPAD ..
3 .. RESTART AND LOG TO WINDOWS
4. ENABLE RADIO IN BROADCOM UTILITY
5 . SEE RADIO TURN ON AND WORKING AGAIN
NOTE :
BROADCOM BACK TO RADIO ERROR IF YOUR LAPTOP GET TO POWER LOST,,
TO SOLVE TURN ON HIBERNATE OR STANDBY MODE IF BATTERY LOW
,, IF YOU GET AGAIN THIS RADIO ERROR ,,TRY AGAIN STEP 1
,, AND TRY 2 ND TRICK ,TO TURN OFF WIFI VIA LINUX ,I GET WORK WITH PARTED MAGIC OS INCLUDE BROADCOM WIRELES ,,
I DONT KNOW IN LINUX RADIO GOOD NOT ERROR ..
BUT IN WINDOWS I FEEL DRIVER PROBLEMS
It seems like you've found a unique workaround to address the Broadcom wireless radio issue you were facing on your Acer laptop. By leveraging a Linux environment and making changes to specific files on the Windows system, you were able to re-enable the wireless radio functionality. If you encounter this problem repeatedly or if it proves to be inconsistent, you may want to consider the following additional steps: 1. Update Drivers: Ensure that you have the latest drivers for your Broadcom wireless hardware. You can download and install drivers directly from the Acer support website or the Broadcom website. 2. BIOS Update: Sometimes, a BIOS update can resolve hardware-related issues. Check Acer's official website for any...
It seems like you've found a unique workaround to address the Broadcom wireless radio issue you were facing on your Acer laptop. By leveraging a Linux environment and making changes to specific files on the Windows system, you were able to re-enable the wireless radio functionality. If you encounter this problem repeatedly or if it proves to be inconsistent, you may want to consider the following additional steps: 1. Update Drivers: Ensure that you have the latest drivers for your Broadcom wireless hardware. You can download and install drivers directly from the Acer support website or the Broadcom website. 2. BIOS Update: Sometimes, a BIOS update can resolve hardware-related issues. Check Acer's official website for any available BIOS updates for your specific laptop model. 3. Power Management: Adjust the power settings regarding how the system manages the wireless hardware. Sometimes, power-saving features can lead to connectivity issues. 4. Control Panel Settings: Check your Windows Control Panel settings related to network connections and wireless devices to ensure that everything is configured correctly. If following these steps does not permanently resolve the issue, you may want to consider a professional inspection if the problem persists. It's great that you found a temporary fix, but a more robust solution might involve replacing the Broadcom hardware or seeking assistance from Acer's support team for further diagnostics.
