For many users, custom DNS settings are the unsung heroes that help ensure faster, more reliable, and sometimes even safer web browsing. However, a persistent and puzzling problem has been noted across Windows 11 (and 10) systems: carefully chosen DNS configurations often revert to defaults or unwanted addresses upon reboot. This isn’t just a nuisance—it can have genuine implications for user experience, privacy, and network reliability. Let’s investigate why DNS settings reset after reboot in Windows 11, analyze the root causes, examine tested solutions, and explore both the strengths and caveats of recommended fixes.
A computer monitor displays security settings against a digital blue background with flowing light lines and shield icons.Understanding DNS and Why Custom Settings Matter​
DNS, or Domain Name System, is the backbone service translating human-friendly URLs into the IP addresses computers use on the Internet. By default, most Windows installations obtain DNS settings automatically from the network’s DHCP (Dynamic Host Configuration Protocol) server, usually your home router or office gateway. For those who seek enhanced speed, privacy, or desire to circumvent restrictive local policies, manually setting DNS to services like Google (8.8.8.8 / 8.8.4.4), Cloudflare (1.1.1.1), or OpenDNS is a common practice.
Yet, Windows users have increasingly reported a pattern: after a clean reboot or waking from sleep, their DNS servers silently revert to “Obtain DNS server address automatically,” or swap to addresses never explicitly configured. This leads to slower web access, privacy concerns, or even connection failures.
Why Does Windows 11 Reset DNS Settings?​
Multiple factors contribute to this recurring problem:
  • DHCP Lease Renewal: Windows relies on DHCP for dynamic IP and DNS configuration. Upon reboot, lease renewal can overwrite any manual changes with whatever the DHCP server supplies. This is especially aggressive on some networks, where the router or gateway enforces strict settings.
  • Group Policy Enforcement: On enterprise-managed devices, network settings can be forcibly dictated via Group Policy. Even local changes in the GUI may be overridden at every refresh or startup.
  • Network Profile Changes: When Windows detects a new or significantly changed network, it might reset network profiles, including DNS settings, to “safe” defaults.
  • Fast Startup Peculiarities: Windows 11’s Fast Startup can sometimes cache or sync older settings, unexpectedly rolling back manual changes after a reboot.
  • Driver or Adapter Anomalies: Outdated or buggy network drivers may ignore OS-level settings or fail to persist values between sessions.
  • Third-Party Software: VPNs, security suites, or “network optimizers” can impose their own DNS rules, either temporarily (for tuneling) or permanently (for ad filtering, etc..
Validating These Causes​
Technical forums, Microsoft Support, and reputable tech media consistently echo these root causes. Microsoft’s own documentation details how DHCP lease renewal (especially when both “Obtain IP address automatically” and “Obtain DNS server address automatically” are active) will always overwrite custom DNS entries on connection events. Tech journalists and IT support entries confirm numerous cases where VPN or optimization utilities silently undo user preferences. Independent analysis by The Windows Club and TenForums corroborates the pivotal role Fast Startup and Group Policy can play in stubborn resets, especially in mixed Windows domain environments.
How to Fix DNS Settings Resetting After Reboot: Tested Solutions​
Addressing recurring DNS resets in Windows 11 often requires a multi-pronged approach, customized for whether you’re on a consumer PC or a managed workplace device.
1. Flush the DNS Cache​
The DNS cache sometimes stores outdated or rogue DHCP-linked information. Flushing it can correct transient issues—though it won’t address underlying override mechanisms.
How to do it:
Open Command Prompt or PowerShell as administrator, then run:
ipconfig /flushdns
Reboot and check if DNS settings hold. This method is quick and safe, but alone rarely fixes persistent resets if the root cause is DHCP or policy enforcement.
2. Reset Winsock and Release/Renew TCP/IP Stack​
Corrupted or misconfigured network components can force Windows to favor default settings:
netsh winsock reset
netsh int ip reset
ipconfig /release
ipconfig /renew
Run each command in an elevated Command Prompt or PowerShell. This suite resets core networking components to defaults and releases/renews DHCP leases.
Strengths​
  • Resolves right-to-left misconfigurations.
  • Often required after malware or VPN software removal.
Weaknesses​
  • Will erase custom settings, so DNS must be reconfigured after executing.
  • If the DHCP server is set up to push DNS settings, they’ll return to default upon renewal regardless.
3. Examine and Edit Registry Settings​
Sometimes, specific registry settings instruct Windows to ignore user changes or enforce particular network configurations.
Where to look:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
  • Locate the subkey matching your network adapter’s GUID (find using ipconfig /all).
  • Check for the existence of entries defining DNS servers, or options like “DisableDHCPMediaSense.”
Mitigation:
  • If DisableDHCPMediaSense isn’t present, create it (DWORD 32-bit), set its value to 1.
  • Double-check for custom DNS entries and ensure their persistence.
Caution:
Always backup your registry before changes. An error can render your system unbootable.
4. Check and Modify Group Policy​
On systems joined to a domain (or those where Local Group Policy Editor is available), settings here can forcibly override local configurations.
How to check:
  • Open Local Group Policy Editor: gpedit.msc
  • Navigate: Computer Configuration > Administrative Templates > Network > DNS Client
  • Ensure “Configure DNS servers” is either not configured or disabled.
To further restrict resets due to network location changes:
  • Go to Computer Configuration > Windows Settings > Security Settings > Network List Manager Policies
  • Set the profile to “Private” for your main connection, and disable DNS overriding.
5. Set DNS via PowerShell (and Lock It In)​
The regular GUI approach in the Windows network dialog sometimes fails to truly “lock” DNS changes—especially if competing services (DHCP, policy) interfere. PowerShell offers a more granular (and, for advanced users, scriptable) approach.
Steps:
  • List active network adapters:
    Get-NetAdapter | Where-Object {$_.Status -eq "Up"} | Format-List Name, InterfaceIndex
  • Set DNS for the adapter (replace 8 and DNS addresses as needed):
    Set-DnsClientServerAddress -InterfaceIndex 8 -ServerAddresses ("8.8.8.8", "8.8.4.4")
  • Prevent dynamic updates:
    Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters" -Name "DisableDynamicUpdate" -Value 1
This last change disables Windows’ dynamic DNS registration, preventing the system from automatically re-registering the DNS server with each network change.
Strengths​
  • Shell-level changes are less likely to be silently overridden.
  • Enables scripting for enterprise or repeated deployments.
Weaknesses​
  • Misuse of PowerShell or registry changes can cause network failure.
  • Does not prevent all forms of enforcement (e.g., some aggressive malware or endpoint management solutions).
6. Use Network Reset​
For particularly stubborn cases, sometimes only a reset of all network components works.
To perform:
  • Open Settings
  • Go to Network & Internet > Advanced network settings > Network reset
  • Click "Reset now" and reboot.
This erases all custom network configurations, requiring re-entry of DNS and Wi-Fi settings, but often shakes loose deeply embedded corruption or misapplied policies.
What If the DNS Server Keeps Switching from Auto to Manual (or Vice Versa)?​
This common “flip-flop” is a classic sign of conflicting policies or software interference. DHCP override, aggressive group policy, or VPN software that “restores defaults” on disconnect are usual culprits.
Best practices:
  • Implement the above solutions with special attention to Group Policy and registry entries.
  • Use a “clean boot” (disable all non-Microsoft services) to confirm if a third-party app is the trigger. If DNS no longer resets, re-enable services until the culprit is found.
Additional Troubleshooting and Considerations​
Interfering Third-Party Applications​
Many VPN, privacy, or “internet speedup” utilities impose their own DNS on connection—sometimes hard-coding settings and failing to restore originals upon exit. Common offenders include:
  • VPN clients (NordVPN, ExpressVPN, Cisco AnyConnect, etc.
  • Network monitoring or ad-blocking apps (NetBalancer, AdGuard)
  • Enterprise endpoint protection platforms
If you suspect such an app, try temporarily uninstalling or disabling it, and confirm if DNS settings remain stable across reboots.
Fast Startup Implications​
Windows 11’s Fast Startup feature can cause system state, including network configurations, to be cached and quickly restored from hibernation files on reboot. This backfires if you made recent changes—your new settings may be lost.
Solution:
  • Disable Fast Startup: Control Panel > Power Options > Choose what the power buttons do > Change settings that are currently unavailable > Uncheck Fast Startup.
  • Save, reboot, and retest changing your DNS.
Router and DHCP Server Configuration​
Sometimes, the operating system is not at fault—your router could be persistently re-imposing certain DNS settings. Logging into your router’s admin interface and observing which DNS addresses it allocates can help determine whether the problem is upstream. For users on corporate or ISP-managed networks, policy-based blocking of custom DNS is increasingly common.
Critical Analysis: Strengths and Risks of These Solutions​
What Works Well​
  • PowerShell and Registry Tweaks: These provide more “sticky” DNS settings on Windows 11, especially compared to GUI options. PowerShell scripting allows for replicable, cross-device deployment, making it ideal for IT environments.
  • Network and Policy Reset: For non-managed machines, network resets and cleaning Group Policy settings are usually effective, and relatively risk-free.
  • Process of Elimination with Clean Boot: This simple, methodical approach helps isolate troublesome third-party applications, which are a common but overlooked culprit.
Notable Risks and Limitations​
  • Enterprise Policy Constraints: If your organization enforces DNS settings via Active Directory or endpoint management (Intune, SCCM), the only sustainable fix is to coordinate with IT—local changes will never persist.
  • Registry and PowerShell Hazards: Incorrect entries or commands can disable networking entirely or, in extreme cases, compromise system stability. Always back up before making low-level changes.
  • VPN and Security Software: Some security suites intentionally prevent changes to DNS as a security-layer feature. Uninstalling or disabling may leave the system more exposed unless alternate protections are enabled.
  • Router Enforcement: Changes made to the PC are meaningless if the upstream DHCP server is responsible. In such scenarios, only modifying the router’s settings or using per-device static configuration with DHCP disabled will suffice.
Hard-to-Verify Claims​
A few online sources suggest that Microsoft intentionally made DNS settings “sticky” only when both IP address and DNS are statically assigned. Empirical testing and Microsoft’s official documentation confirm that manually set DNS servers revert if IP settings remain on “automatic.” Claims that “resetting network stack always fixes DNS resets” are overly broad—if a VPN or group policy remains active, resets may not help. As always, correlating reports across both Microsoft support and information security communities gives the clearest picture.
The State of DNS on Windows 11: A 2025 Perspective​
Windows 11 has inherited much of its network stack from Windows 10, and with it, some legacy quirks regarding DNS configuration persistence. The balance between automation (DHCP, group policy) and user preferences reflects Microsoft's drive for user-friendliness and security—but it can be frustrating for power users or those with special needs. The addition of PowerShell-based management in recent Windows releases represents progress, but many still stumble due to incomplete documentation or the subtle interplay of service, driver, and software-based overrides.
Best Practices for Ensuring DNS Settings Stick​
  • Prefer configuring both IP and DNS statically whenever possible.
  • Use PowerShell over GUI for critical network changes on Windows 11.
  • Regularly review installed network utilities (VPNs, ad-blockers), especially after OS updates or troubleshooting.
  • Keep network drivers up to date via Windows Update or vendor websites.
  • On enterprise or shared PCs, coordinate with IT instead of repeated local fixes; policy beats manual changes.
  • Regularly reboot after key changes, observing whether settings persist across both cold starts and wakes-from-sleep.
Future Directions: What Should Microsoft Do?​
Despite workarounds, persistent DNS resetting remains a thorny issue for many. Microsoft could consider:
  • Exposing more granular DNS lock options in the Settings app.
  • Providing clearer, context-sensitive prompts when group policy or DHCP are responsible for reverts.
  • Enhancing Fast Startup logic to fully respect recent manual network changes.
  • Improving documentation, particularly around the interplay between GUI, PowerShell, and registry-based network configuration.
The DNS settings reset issue on Windows 11 highlights the tension between automation for mainstream users and control for power users. For most, following the steps outlined above—particularly PowerShell configuration, registry tweaks, and policy auditing—will resolve stubborn resets. However, ultimate authority often lies with upstream DHCP servers or enterprise IT policies, meaning some limitations are simply the cost of a managed environment.
Nonetheless, staying informed, periodically checking for new features in upcoming Windows updates, and employing best-practice troubleshooting steps are the keys to keeping your DNS configuration exactly as you want it: fast, private, and persistent.
Source: The Windows Club DNS Settings reset after reboot in Windows 11
