FaceTime not working on an iPad is usually fixed by restoring its FaceTime registration, checking the Apple Account and reachable addresses, testing the network, or removing a restriction. These steps apply to iPads running current iPadOS releases, including Wi‑Fi-only and Wi‑Fi + Cellular models. On newer iPadOS versions, FaceTime settings are under Settings > Apps > FaceTime; older versions may show Settings > FaceTime directly.
Tablet displaying a failed video call, surrounded by connectivity, signal, user, security, loading, and upload icons.1. Confirm FaceTime is enabled and using the right account​
Use this first when calls do not ring, FaceTime is stuck on activation, or people are trying to reach an old email address or phone number.
  1. Open Settings > Apps > FaceTime.
  2. Turn on FaceTime.
  3. If prompted, sign in with the Apple Account you use on your other Apple devices.
  4. Under You Can Be Reached by FaceTime At, select the email addresses and, where shown, the phone number that people should use.
  5. Check that the address or number you expect is selected—not merely listed.
  6. Open the FaceTime app, tap New, enter a known contact, and try a short call.
If a contact still cannot reach you, ask them which number or email address they are calling. A contact card containing an outdated FaceTime address can send the call to the wrong destination.
FaceTime video and audio calling are not available in every country, region, or carrier network. If FaceTime has never worked on this iPad, rather than failing only recently, verify that the feature is available where the iPad is being used.
2. Refresh FaceTime registration and restart the iPad​
Turning FaceTime off and back on forces it to register again. This is the primary fix for Waiting for Activation, sign-in failures, and a FaceTime switch that will not stay enabled.
  1. Go to Settings > Apps > FaceTime.
  2. Turn FaceTime off.
  3. Restart the iPad:
    • iPad without a Home button: Press and hold either Volume button and the Top button until the power-off slider appears. Drag the slider, wait 30 seconds, then hold the Top button until the Apple logo appears.
    • iPad with a Home button: Hold the Top button until the power-off slider appears. Drag it, wait 30 seconds, then hold the Top button until the Apple logo appears.
  4. Return to Settings > Apps > FaceTime.
  5. Turn FaceTime back on and sign in if requested.
  6. Wait for the activation message to clear, then make a test call.
If the iPad is frozen, use a force restart instead:
  • Without a Home button: Quickly press and release the Volume button nearest the Top button, quickly press and release the other Volume button, then hold the Top button until the Apple logo appears.
  • With a Home button: Hold the Home button and Top button together until the Apple logo appears.
A force restart does not erase the iPad.
3. Check Apple Account, date, time, and activation status​
FaceTime requires a working Apple Account sign-in. Activation can also fail when the iPad has an incorrect time zone or cannot reach Apple’s servers.
  1. Open Settings > General > Date & Time.
  2. Turn on Set Automatically.
  3. Go to Settings > Apps > FaceTime and confirm that the correct Apple Account is shown.
  4. If the account password was recently changed, sign out of FaceTime, then sign back in with the updated password.
  5. In a browser, check Apple’s System Status page for a FaceTime outage before changing more settings.
If you are trying to use a phone number as a FaceTime address, the number must first be activated through the associated iPhone and carrier service. Apple notes that carrier verification can take up to 24 hours. Do not repeatedly toggle FaceTime during that period if activation is already in progress.
If FaceTime works through an email address but not a phone number, focus on the iPhone, SIM/eSIM, carrier service, and iMessage/FaceTime activation associated with that number.
4. Test Wi‑Fi, cellular data, and network filtering​
FaceTime needs a working broadband Wi‑Fi or cellular data connection. A web page loading proves basic internet access, but it does not prove the connection is stable enough for live video and audio.
  1. Open Safari and load a few websites.
  2. Try FaceTime on a different Wi‑Fi network, such as a trusted home network or phone hotspot.
  3. If the iPad has cellular service, turn off Wi‑Fi temporarily and test FaceTime on cellular data.
  4. If the call connects but shows a black screen, choppy video, connection alerts, or drops, stop other streaming, downloads, cloud backups, and gaming activity on the same connection.
  5. Restart the Wi‑Fi router if FaceTime fails only on your home network.
  6. Temporarily disconnect any VPN app or VPN configuration, then test again.
If FaceTime works on cellular but not Wi‑Fi, the Wi‑Fi router, firewall, DNS filtering, security software, or network administrator is likely blocking or interfering with the service. This is a network problem, not an iPad hardware fault.
For a work, school, hotel, or public Wi‑Fi network, ask the administrator whether FaceTime traffic is restricted. Do not remove required work or school security software without approval.
5. Enable FaceTime for cellular data​
This fix applies only to a Wi‑Fi + Cellular iPad with an active cellular plan. A Wi‑Fi-only iPad cannot place FaceTime calls over cellular directly.
  1. Open Settings > Cellular, Mobile Data, or Cellular Data. The label varies by region and carrier.
  2. Confirm that cellular data is enabled.
  3. Scroll through the app list and turn on FaceTime.
  4. Test again with Wi‑Fi turned off.
If the FaceTime switch is missing from the cellular app list, update carrier settings and iPadOS before assuming the carrier does not support it.
  1. Connect the iPad to Wi‑Fi or cellular data.
  2. Open Settings > General > About.
  3. Install a carrier settings update if the iPad offers one.
  4. Restart the iPad and retest FaceTime.
Cellular data charges may apply. If FaceTime does not work over cellular after the switch is enabled, use Wi‑Fi and contact the cellular carrier to confirm the plan and local service support.
6. Update iPadOS​
An outdated iPadOS release can cause account sign-in, camera, networking, or app reliability problems. Back up the iPad before installing a major update.
  1. Connect the iPad to power and reliable Wi‑Fi.
  2. Open Settings > General > Software Update.
  3. Review the installed iPadOS version and available update.
  4. Tap Download and Install, then follow the on-screen steps.
  5. After the iPad restarts, open FaceTime and place a test call.
If the wireless update fails, update from a computer:
  1. Connect the iPad by cable.
  2. On a Windows PC, open the Apple Devices app, select the iPad in the sidebar, select General, then choose Check for Update and Update.
  3. On a Mac running macOS Catalina or later, select the iPad in Finder, open General, then select Check for Update and Update.
  4. On older Macs or Windows PCs using iTunes, select the iPad button, open Summary, select Check for Update, then choose Download and Update.
An update should preserve personal data and settings, but a backup gives you a recovery option if the update is interrupted.
7. Restore FaceTime and Camera access​
If FaceTime is missing, will not open, or video is unavailable, check Screen Time restrictions first.
  1. Open Settings > Screen Time > Content & Privacy Restrictions > Allowed Apps & Features.
  2. Make sure FaceTime and Camera are allowed.
  3. If this is a child’s iPad managed through Family Sharing, the organizer may need to open Settings > Screen Time, select the child, and change the restriction there.
  4. If FaceTime is present but only a third-party calling app has no camera or microphone, open Settings > Privacy & Security > Camera or Microphone and allow that app.
The built-in FaceTime app is controlled primarily through FaceTime and Screen Time settings. Camera and microphone privacy lists are more relevant to third-party apps that request access.
For a black camera preview or missing audio, test the hardware outside FaceTime:
  1. Open the Camera app.
  2. Record a short clip with the front camera.
  3. Switch to the rear camera and record another clip.
  4. Play both clips with the volume up.
If either camera fails in the Camera app, or neither recording contains sound, the problem is broader than FaceTime. Remove any case, film, or accessory that covers a camera or microphone opening, then test again. Persistent camera or microphone failures require Apple service or repair support.
8. Reinstall FaceTime or reset network settings​
Reinstall FaceTime if the app is missing or damaged.
Warning: Removing FaceTime prevents FaceTime calls on that iPad until the app is downloaded again.
  1. Touch and hold the FaceTime app icon.
  2. Tap Remove App, then Delete App.
  3. Open the App Store.
  4. Search for FaceTime.
  5. Tap the redownload button.
  6. Open FaceTime, sign in if prompted, and make a test call.
If FaceTime is still missing after reinstalling, return to Screen Time > Content & Privacy Restrictions > Allowed Apps & Features. On a managed work or school iPad, the organization may have disabled FaceTime through device management; only its administrator can remove that restriction.
If FaceTime works on one network but not another, or all account checks are correct but calls still cannot connect, reset the network settings.
Warning: Reset Network Settings removes saved network settings and manually trusted certificates. You will need to reconnect to Wi‑Fi afterward. It does not erase your photos, apps, or personal files.
  1. Open Settings > General > Transfer or Reset iPad > Reset.
  2. Tap Reset Network Settings.
  3. Enter the iPad passcode if asked.
  4. Reconnect to Wi‑Fi.
  5. Turn FaceTime on if necessary and test a call.
If FaceTime still fails after these steps, test the same Apple Account on another Apple device and test the iPad with a different FaceTime contact. If the fault follows the iPad across networks and contacts, or the Camera and microphone tests fail, escalate to Apple Support for account or hardware diagnostics.
References​
  1. Primary source: Technobezz
    Published: 2026-07-18T16:34:07.613000+00:00
  2. Official source: support.apple.com
