The Automatic Repair screen that reads “Your PC did not start correctly” is not a dramatic flourish — it’s Windows telling you that the boot process failed one of its early checks and the system has moved you into the Windows Recovery Environment (WinRE) so you can try to fix it. The advice from the community guide you uploaded — which recommends a measured, step‑by‑step approach (restart, Startup Repair, System Restore, Safe Mode, command‑line BCD repairs, then Reset or pro help if needed) — is sound and reflects the same options Microsoft exposes in WinRE. (support.microsoft.com)
A laptop with holographic recovery tools floating around a Windows-style error screen.Background / Overview​
Windows will automatically attempt to enter Automatic Repair (the blue “Your PC did not start correctly” screen) after multiple failed boots or when startup diagnostics detect something wrong. The recovery environment gives you several tools:
  • Restart (quick check for transient faults)
  • Startup Repair (automated diagnostics targeting boot files and BCD)
  • System Restore (roll back system files and drivers to a previous snapshot)
  • Startup Settings / Safe Mode (a minimal environment for troubleshooting)
  • Command Prompt (manual repairs, disk checks and bootrec)
  • Reset this PC / Reinstall (last resort) (support.microsoft.com)
These options are exposed in the WinRE “Advanced options” menu and are the formal route Microsoft documents for recovery. (support.microsoft.com)
Why the “Your PC did not start correctly” message appears​
The message is a symptom, not a diagnosis. Common root causes include:
  • Corrupted system files or boot configuration data (BCD) — Windows can’t find or load required boot files.
  • Failed or incomplete Windows updates — an interrupted/buggy update can leave files in an inconsistent state.
  • Bad drivers — a driver that runs at boot and fails can halt startup.
  • Sudden power loss / improper shutdown — file system or metadata corruption may follow.
  • Hardware faults — failing SSD/HDD, bad RAM, or power issues can show the same symptoms. (support.microsoft.com)
Microsoft’s recovery guidance and community troubleshooting both emphasize that the same end‑state (unbootable Windows) can have different causes, so work from the least‑invasive fixes to the most invasive. (support.microsoft.com)
Quick triage checklist (do this first)​
  • Restart — click Restart on the Automatic Repair screen. Many transient glitches clear with a simple reboot.
  • Disconnect external devices — unplug USB drives, external HDDs, printers and other peripherals (including extra monitors). External hardware sometimes prevents normal boot. (asus.com)
  • If the machine re-enters Automatic Repair, choose Advanced options to access the recovery tools. (support.microsoft.com)
If those quick checks don’t recover the system, follow the ordered steps below.
Step‑by‑step repairs (ordered, with verified commands and cautions)​
1) Run Startup Repair (automated; first real tool)​
Startup Repair runs diagnostics and attempts to repair missing or damaged system files and BCD issues.
  • From the Automatic Repair screen, choose Advanced options → Troubleshoot → Advanced options → Startup Repair.
  • Select the account to sign in (may require credentials). The tool will scan and attempt repairs automatically.
  • Reboot after the tool completes. (support.microsoft.com)
Why try this first: the tool is non‑destructive and automates many routine fixes. It’s exactly the step the original GuidingTech walkthrough suggests.
2) Use System Restore (if you have restore points)​
If Startup Repair fails and you have restore points, System Restore can revert drivers, updates and system files:
  • In Advanced options choose System Restore.
  • Select a restore point made before the problem began and follow prompts. Optionally choose Scan for affected programs to see what will be removed.
  • Reboot when finished. (support.microsoft.com)
Important note: Windows 11 (from 24H2 updates) has changed the retention window for restore points in recent updates; some systems may keep them for up to 60 days rather than older retention defaults — make no assumptions a long‑ago restore point exists. If System Restore is unavailable, you’ll need other options.
3) Boot into Safe Mode to uninstall recent drivers or updates​
Safe Mode loads Windows with minimal drivers and services so you can remove offending software.
  • From Advanced options choose Startup Settings → Restart.
  • On the Startup Settings screen press the key for Enable Safe Mode (usually 4).
  • Once in Safe Mode, uninstall recent updates or drivers via Settings → Windows Update → Update history → Uninstall updates, or Device Manager for drivers.
Why this helps: driver or update regressions are common causes; Safe Mode isolates them so you can remove or roll back without the normal boot agents interfering.
4) Repair boot records manually (use with caution)​
If BCD or MBR is corrupted, manual boot repair via Command Prompt can rebuild them. These commands are documented by Microsoft and widely used, but they should be followed precisely.
From Advanced options choose Command Prompt and run these commands, pressing Enter after each:
bootrec /fixmbr
bootrec /fixboot
bootrec /scanos
bootrec /rebuildbcd
If bootrec /fixboot returns an “Access is denied” error on UEFI/GPT systems, additional steps may be required (assigning drive letters to the EFI partition, running bcdboot). Use caution — improper use of diskpart and BCD edits can make things worse. (support.microsoft.com)
Also consider running:
sfc /scannow
DISM /Online /Cleanup-Image /RestoreHealth
chkdsk C: /f /r
These commands repair system file integrity and check disks for hardware errors; run them from the recovery environment or after booting into Safe Mode with Command Prompt privileges.
5) Reset this PC or reinstall (last resort)​
If all repairs fail, use Reset this PC (Keep my files or Remove everything) or perform a clean install from USB installation media.
  • Reset will reinstall Windows; choose Keep my files to preserve user data when possible.
  • If BitLocker is enabled, you may need the recovery key to proceed; have it at hand (Microsoft account or saved recovery key). (support.microsoft.com)
If your data is critical and reset looks risky, stop and consider data recovery by booting from a Linux live USB or have a technician image your drive before destructive operations. The GuidingTech guidance emphasizes seeking professional help when data matters — that’s prudent.
Advanced diagnostics and hardware checks​
  • Run Memory Diagnostics (mdsched.exe) to rule out bad RAM. Faulty RAM causes boot and stability errors.
  • Test your SSD/HDD with manufacturer tools or via CHKDSK; failing drives are a common underlying cause.
  • Reset BIOS/UEFI to defaults and check boot order; sometimes the firmware misconfiguration or a required Secure Boot setting will prevent Windows from starting.
If firmware (UEFI/BIOS) is suspected, check your vendor’s support site for notes about known compatibility issues and consider updating firmware only if a vendor‑provided fix is relevant. Vendor instructions for UEFI/BIOS updates are specific and must be followed exactly. (asus.com)
File encryption and BitLocker: special cautions​
If your drive uses BitLocker, certain recovery steps (like accessing the EFI partition, running System Restore, or resetting the PC) may require the BitLocker recovery key. Microsoft documents how to find a saved recovery key in your Microsoft account — get that key before you proceed with deep recovery actions. Losing the BitLocker key can mean permanent data loss if drives are decrypted or partitions rebuilt. (learn.microsoft.com)
Newer Windows recovery features to know about (Quick Machine Recovery)​
Microsoft has expanded WinRE capabilities in recent updates with features like Quick Machine Recovery (QMR)/cloud remediation that can attempt cloud‑based fixes for boot failures (available in Windows 11 24H2 and later). QMR can automatically upload diagnostics and attempt a fetch of a fix from Microsoft Update before falling back to the legacy Startup Repair toolkit. It is helpful when a widespread update issue is responsible for an outage. QMR is best‑effort and doesn’t guarantee success, but it can save hours in some update‑related cases. (windowscentral.com)
Note: QMR behavior and availability depend on Windows version, edition (Home vs Pro settings differ), and whether cloud remediation is enabled. Verify your OS build and settings if you want to rely on cloud recovery. (windowscentral.com)
When to call a professional (or replace hardware)​
  • You’ve tried WinRE tools, bootrec, SFC/DISM, and CHKDSK without success.
  • Disk diagnostics show SMART errors or numerous bad sectors.
  • Memory tests show errors.
  • The system fails before any diagnostic screen can appear (power, BIOS/UEFI stage).
  • You cannot access a BitLocker key and the drive is encrypted.
In these cases, a technician can image your drive for data recovery, test components (PSU, motherboard, storage), or perform advanced firmware repairs. The GuidingTech article and community threads all reach the same conclusion: when software fixes are exhausted, hardware diagnosis or professional help is the right next step.
Practical recovery playbook — recommended order of operations​
  • Restart and remove external devices.
  • Try Startup Repair from WinRE. (support.microsoft.com)
  • If that fails, System Restore (if any restore point exists). (support.microsoft.com)
  • Boot to Safe Mode; uninstall recent updates/drivers.
  • Use Command Prompt: run SFC, DISM, CHKDSK, then run bootrec series if needed. Example sequence:
  • sfc /scannow
  • DISM /Online /Cleanup-Image /RestoreHealth
  • chkdsk C: /f /r
  • bootrec /fixmbr ; bootrec /fixboot ; bootrec /scanos ; bootrec /rebuildbcd. (support.microsoft.com)
  • If nothing works, backup data (via external boot media) and then Reset this PC or clean install.
Always proceed from non‑destructive to destructive, and keep backups of important files.
Strengths and limitations of the standard WinRE workflow​
Strengths:
  • Built into Windows — no third‑party tools needed. The sequence (Startup Repair → System Restore → Safe Mode → Command Prompt → Reset) covers most software causes. (support.microsoft.com)
  • Automated for common cases — Startup Repair and, more recently, Quick Machine Recovery can fix widespread update issues with minimal user intervention. (windowscentral.com)
Risks and limitations:
  • Not everything is fixable by software — failing SSDs, bad memory, or PSU issues require hardware work or replacement.
  • Manual BCD edits and disk repairs carry risk — mistakes with diskpart, BCD or formatting can destroy data. Always image the drive if data is irreplaceable. (support.microsoft.com)
  • BitLocker complicates recovery — missing recovery keys can block access after certain repair steps. Keep recovery keys stored securely before you need them. (learn.microsoft.com)
  • Restore point availability is not guaranteed — recent Windows 11 updates can affect retention windows; don’t assume restore points exist for months‑old dates.
Preventive steps to avoid seeing the message again​
  • Keep regular full backups (image + file-level backups) and verify them.
  • Enable System Protection (System Restore) and set appropriate disk space so restore points are created. (support.microsoft.com)
  • Delay non‑critical Windows updates for a short window (two weeks) to let early adopters find regression issues.
  • Use vendor‑provided firmware/driver updates only from official websites and apply them carefully.
  • Keep BitLocker recovery keys saved to your Microsoft account or another secure location. (learn.microsoft.com)
Final thoughts​
The “Your PC did not start correctly” screen is an unpleasant but useful safety net that moves you into WinRE rather than leaving Windows in limbo. The stepwise approach in the GuidingTech material — restart, Startup Repair, System Restore, Safe Mode, Command‑line fixes, then reset or professional help — matches Microsoft’s documented guidance and community best practice. Use non‑destructive tools first, keep backups and BitLocker keys accessible, and escalate to hardware testing or a technician if software repairs don’t restore bootability. (support.microsoft.com)
If the computer is critical and contains unsaved, important data, prioritize imaging the drive before attempting destructive repairs or reinstalling Windows — losing files is permanent once partitions are rebuilt or drives are wiped.
Source: Guiding Tech Fix Your PC Did Not Start Correctly (Windows 11) Message
