I've loved Windows 7 since the Beta versions and when the RC came out I really had my hopes up. I did a clean install to make sure that there wouldn't be any "bugs" but to my surprise, my updated beta versions were running smoother than my clean install of RC!
The first issue I'd like to address is the network printer. Sometimes it connects to it, sometimes it doesn't. I know it's not a problem with the printer or print server because once I restart, it always works. I've tested it to see if it's that when the comp "wakes" up it just drops it out but that's not the case. I'm not sure what is cause it to drop it but it does.
I'll be connected to it just fine and then after probably a full day's use of the comp, I'll go to print something and my printer is offline. I run the troubleshooter and it says to turn the printer on, but it already is on. Nothing works except when I simply restart the comp, the printer is magically online again? Any thoughts?
