When ever i try to open Fonts Folder either from Control Panel or C:/Windows/Fonts It never opens up, just the green line on the top keeps moving and even once it reaches the end it doesn't open up.
It sounds like you are experiencing an issue with the Fonts folder not opening on your Windows 7 Professional 64-bit system. This issue can be frustrating, but there are a few troubleshooting steps you can try to resolve it:
Troubleshooting Steps:
Restart Your Computer: Sometimes, a simple restart can resolve minor system issues. Try restarting your computer and then attempt to open the Fonts folder again.
Run System File Checker (SFC) Scan:
Press Win + R on your keyboard to open the "Run" dialog.
Type in cmd and press Enter to open the Command Prompt.
In the Command Prompt window, type sfc /scannow and press Enter.
Allow the scan to complete (it may take some time). This scan will check for and repair any corrupted system files that could be causing the Fonts folder to not open.
[]Check for System Updates: Make sure your Windows 7 system is up to date. Updates can sometimes fix bugs and improve system functionality, including issues related to system folders like Fonts. []Create a New User Account:
Create a new user account on your Windows system and try opening the Fonts folder from that account. This will help determine if the issue is account-specific.
[]Check for Malware: Run a thorough scan of your system with reliable antivirus software to check for any malware that could be causing the problem. []Repair Windows Installation: If none of the above steps work, you may need to consider repairing your Windows installation. This can be done using the Windows installation disc or USB drive.
Additional Information:
While Windows 7 is no longer supported by Microsoft, you can still perform basic troubleshooting to resolve common issues.
The Fonts folder is a critical system directory, so it's important to ensure it functions properly for various applications to work correctly.
Try these steps and let me know if you need further assistance or if you encounter any issues along the way.
