Jaygcn
Hello! I am having trouble with Framework.net 3.5, and dell datasafe. I installed some private server programs, then uninstalled them after. This messed up these 2 programs. I did a system restore, this didn't fix it. I am currently trying to reinstall framework.net 3.5. When I do, it says I need to turn windows features off. I try to turn off the uninstalled framework in windows features, and it says unable to. Machine.config file is giving me errors during startup for dell datasafe. Any idea how to rectify this problems? They are very very aggravating, have been toying with it for hours now. Any help would be GREATLY appreciated!! Thank you
It sounds like you're facing a couple of issues with the installation of .NET Framework 3.5 and Dell DataSafe after uninstalling some private server programs. Here are some steps you can take to try and resolve these problems:
Issues with .NET Framework 3.5 Installation:​
  1. Turn Windows Features On or Off Error:
    • If you're unable to turn on/off features in the Windows Features dialog, you can try a workaround using the Command Prompt with administrative privileges. Here's how:
      • Open a Command Prompt as an administrator.
      • Run the following command:
         DISM /Online /Enable-Feature /FeatureName:NetFx3 /All /LimitAccess /Source:D:\sources\sxs
        (Replace D:\ with the drive that contains your Windows...
        (Replace D:\ with the drive that contains your Windows installation media if it's different.)
      • Restart your computer after the command completes.
        Dell DataSafe Error with Machine.config:​
    []Errors in Machine.config File:
    • Errors related to the machine.config file for Dell DataSafe can cause issues during startup. To resolve this:
      • Locate the machine.config file. It is usually located in the following directory: C:\Windows\Microsoft.NET\Framework\v2.0.50727\CONFIG.
      • Check for any errors in the file and correct them. Ensure that the file settings align with Dell DataSafe requirements.
      • If you're not sure about the correct settings, you may need to consult Dell's support or reinstall Dell DataSafe to ensure a fresh configuration.
        Additional Suggestions:​
    • ]Reinstall .NET Framework 3.5: []If the above steps don't work, you might consider fully uninstalling .NET Framework 3.5, restarting your system, and then reinstalling it from scratch. []Check for System Updates: []Ensure that your Windows operating system is fully up to date. Sometimes, system updates can resolve compatibility issues with certain programs. []Consult Dell Support:
    • Since the issue involves Dell DataSafe, reaching out to Dell support for specific guidance or troubleshooting steps related to their software may provide a more targeted solution. Try these steps to see if they resolve the issues with .NET Framework 3.5 and Dell DataSafe. If you encounter any specific error messages during the process, feel free to provide them for more tailored assistance. Let me know if you need further help!
