Frequent crashes on hibernate/during hibernation
Hi everyone
Last week my computer started crashing every time I closed the lid/went to hibernate. No idea what I did for this to suddenly start happening.
After searching for a while on Google, I thought it may be to do with Dropbox so I installed the latest version. This has helped a bit but the system still crashes quite often.
It has also crashed on shut down. It seems to be taking a lot longer to shut down than it used to and on occasion it's taken so long I've had to force switch it off.
Looking at bluescreen view it seems to be caused by ntkrnlpa.exe. I've attached the dump files.
If anyone can help, it would be greatly appreciated.
Adam
Elmer
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes:
Device driver
Outdated Drivers. Update:
Alps pointing device O.E.M.
Apfiltr.sys Wed Dec 12 09:01:21 2007
Intel 82567V Gigabit Network driver
e1y6032.sys Thu Jul 17 00:37:51 2008
Smart Card Reader? ? Option N.V.? ?
gtuhs51.sys Wed Jun 04 15:32:32 2008
gtuhsbus.sys Wed Jun 04 15:53:54 2008
gtuhssc.sys Thu Jun 05 10:23:38 2008
gtuhsser.sys Wed Jun 04 15:38:57 2008
Intel Rapid Storage.
iaStor.sys Wed Apr 16 01:07:31 2008
Intel Wi-Fi
netw5v32.sys Thu May 14 16:40:33 2009
InterVideo regi.sys driver. Uninstall. This XP software won't run on Win 7 except in the XP mode.
regi.sys Mon Apr 16 16:19:05 2007
Ricoh Memory Card Reader O.E.M.
rimsptsk.sys Wed Mar 12 10:43:06 2008
risdptsk.sys Wed Jul 09 05:27:28 2008
Realtek HD Audio R2.57
RTKVHDA.sys Fri May 22 19:03:37 2009
Sony HDD Protection Driver
shpf.sys Fri Aug 22 08:48:03 2008
Sony Programmable I/O Control Device
SonyPI.sys Fri Aug 03 06:41:08 2007
TouchChip USB Kernel Driver (FingerPrint Sensor)
tcusb.sys Tue Jun 09 19:07:02 2009
Analysis
Loading Dump File [D:\ DOWNLOADS\ DUMPS\adamski\021411-19546-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?ffffffff`8078ada4?
Symbol search path is: SRV*C:\XSymCache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16695.x86fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0x82e4f000 PsLoadedModuleList = 0x82f97810
Debug session time: Mon Feb 14 18:45:56.142 2011 (UTC + 0:00)
System Uptime: 0 days 1:22:56.060
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
0: kd> !analyze
BugCheck 9F, {3, 855aeec8, 8078adb0, 85d1f9f8}
Unable to load image \SystemRoot\system32\DRIVERS\appliand.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for appliand.sys
*** ERROR: Module load completed but symbols could not be loaded for appliand.sys
Probably caused by : ntkrpamp
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 00000003, A device object has been blocking an Irp for too long a time
Arg2: 855aeec8, Physical Device Object of the stack
Arg3: 8078adb0, Functional Device Object of the stack
Arg4: 85d1f9f8, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  ntkrpamp
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: ntkrpamp
FAULTING_MODULE: 963c8000 appliand
IRP_ADDRESS:  85d1f9f8
DEVICE_OBJECT: 8761f028
DRIVER_OBJECT: 8733be90
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  fssm32.exe
CURRENT_IRQL:  2
STACK_TEXT:
8078ad64 82e8b044 0000009f 00000003 855aeec8 nt!KeBugCheckEx+0x1e
8078add0 82e8a8d8 8078ae7c 00000000 858e9bd8 nt!PopCheckIrpWatchdog+0x1f5
8078ae08 82eb916d 82f90a20 00000000 69fb11fb nt!PopCheckForIdleness+0x73
8078ae4c 82eb9111 82f78d20 8078af78 00000001 nt!KiProcessTimerDpcTable+0x50
8078af38 82eb8fce 82f78d20 8078af78 00000000 nt!KiProcessExpiredTimerList+0x101
8078afac 82eb734e 0004de00 bdee8d34 00000000 nt!KiTimerExpiration+0x25c
8078aff4 82eb6b1c bdee8ce4 00000000 00000000 nt!KiRetireDpcList+0xcb
8078aff8 bdee8ce4 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2c
WARNING: Frame IP not in any known module. Following frames may be wrong.
82eb6b1c 00000000 0000001a 00d6850f bb830000 0xbdee8ce4
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  0x9F_3_IMAGE_ntkrpamp
Drivers:
96231000 9625d000   1394ohci 1394ohci.sys Tue Jul 14 00:51:59 2009 (4A5BC89F)
8b0a0000 8b0e8000   ACPI     ACPI.sys     Tue Jul 14 00:11:11 2009 (4A5BBF0F)
8af9f000 8aff9000   afd      afd.sys      Tue Jul 14 00:12:34 2009 (4A5BBF62)
9632b000 9633d000   AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
8b30b000 8b314000   amdxata  amdxata.sys  Tue May 19 18:57:35 2009 (4A12F30F)
962ad000 962d9000   Apfiltr  Apfiltr.sys  Wed Dec 12 09:01:21 2007 (475FA361)
963c8000 963d2000   appliand appliand.sys Fri May 28 12:54:28 2010 (4BFFAEF4)
9c18d000 9c196000   asyncmac asyncmac.sys Tue Jul 14 00:54:46 2009 (4A5BC946)
8b1d0000 8b1db000   BATTC    BATTC.SYS    Tue Jul 14 00:19:15 2009 (4A5BC0F3)
92f3c000 92f43000   Beep     Beep.SYS     Tue Jul 14 00:45:00 2009 (4A5BC6FC)
9373c000 9374a000   blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
8aeaa000 8aeb2000   BOOTVID  BOOTVID.dll  Tue Jul 14 02:04:34 2009 (4A5BD9A2)
9871b000 98734000   bowser   bowser.sys   Tue Jul 14 00:14:21 2009 (4A5BBFCD)
95e0b000 95e18000   BthEnum  BthEnum.sys  Tue Jul 14 00:51:35 2009 (4A5BC887)
9501f000 9503a000   bthpan   bthpan.sys   Tue Jul 14 00:51:43 2009 (4A5BC88F)
92e32000 92e96000   bthport  bthport.sys  Tue Jul 14 00:51:30 2009 (4A5BC882)
9381b000 9382d000   BTHUSB   BTHUSB.sys   Tue Jul 14 00:51:36 2009 (4A5BC888)
92e96000 92f09000   btwavdt  btwavdt.sys  Sat Oct 04 02:32:03 2008 (48E6C793)
81e00000 81e1e000   cdd      cdd.dll      unavailable (00000000)
92f16000 92f35000   cdrom    cdrom.sys    Tue Jul 14 00:11:24 2009 (4A5BBF1C)
8aef4000 8af9f000   CI       CI.dll       Tue Jul 14 02:09:28 2009 (4A5BDAC8)
8b7ac000 8b7d1000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
8aeb2000 8aef4000   CLFS     CLFS.SYS     Tue Jul 14 00:11:10 2009 (4A5BBF0E)
9377d000 93780700   CmBatt   CmBatt.sys   Tue Jul 14 00:19:18 2009 (4A5BC0F6)
8b363000 8b3c0000   cng      cng.sys      Tue Jul 14 00:32:55 2009 (4A5BC427)
8b1c8000 8b1d0000   compbatt compbatt.sys Tue Jul 14 00:19:18 2009 (4A5BC0F6)
962ff000 9630c000   CompositeBus CompositeBus.sys Tue Jul 14 00:45:26 2009 (4A5BC716)
93b25000 93b32000   crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
936c0000 93724000   csc      csc.sys      Tue Jul 14 00:15:08 2009 (4A5BBFFC)
b0e25000 b0eb5000   CVPNDRVA CVPNDRVA.sys Mon Aug 24 04:40:30 2009 (4A920BAE)
93724000 9373c000   dfsc     dfsc.sys     Tue Jul 14 00:14:16 2009 (4A5BBFC8)
936b4000 936c0000   discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
8b79b000 8b7ac000   disk     disk.sys     Tue Jul 14 00:11:28 2009 (4A5BBF20)
936b3000 936b3de0   DMICall  DMICall.sys  Tue Dec 05 07:14:23 2000 (3A2C95CF)
9630c000 9632ae80   dne2000  dne2000.sys  Tue Nov 11 00:59:21 2008 (4918D8E9)
93aa1000 93aba000   drmk     drmk.sys     Tue Jul 14 01:36:05 2009 (4A5BD2F5)
93800000 93811000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
93b32000 93c00000   dump_iaStor dump_iaStor.sys Wed Apr 16 01:07:31 2008 (48054343)
93811000 9381b000   Dxapi    Dxapi.sys    Tue Jul 14 00:25:25 2009 (4A5BC265)
95661000 95718000   dxgkrnl  dxgkrnl.sys  Tue Nov 02 02:37:53 2010 (4CCF7981)
95718000 95751000   dxgmms1  dxgmms1.sys  Thu Feb 03 03:34:49 2011 (4D4A2259)
95751000 9578b000   e1y6032  e1y6032.sys  Thu Jul 17 00:37:51 2008 (487E864F)
8b348000 8b359000   fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
8b314000 8b348000   fltmgr   fltmgr.sys   Tue Jul 14 00:11:13 2009 (4A5BBF11)
8b5b8000 8b5c1000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:11:14 2009 (4A5BBF12)
8b808000 8b810400   fsbts    fsbts.sys    Fri Oct 15 13:14:47 2010 (4CB845B7)
9368c000 9369bb20   fsdfw    fsdfw.sys    Sun Nov 01 05:05:19 2009 (4AED170F)
9369c000 936a3100   fses     fses.sys     Tue Oct 13 13:46:36 2009 (4AD476AC)
9c08a000 9c0ad000   fsgk     fsgk.sys     Tue Sep 21 11:51:05 2010 (4C988E19)
936a4000 936b2f80   fshs     fshs.sys     Wed Nov 04 11:34:45 2009 (4AF166D5)
93684000 9368c000   fsvista  fsvista.sys  Tue Nov 03 14:20:53 2009 (4AF03C45)
8b769000 8b79b000   fvevol   fvevol.sys   Sat Sep 26 03:24:21 2009 (4ABD7B55)
8b96a000 8b99b000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:12:03 2009 (4A5BBF43)
962f9000 962fe280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:16:53 2009 (4A1151B5)
9c0df000 9c0f8e80   gtuhs51  gtuhs51.sys  Wed Jun 04 15:32:32 2008 (4846A780)
9c0ce000 9c0dc600   gtuhsbus gtuhsbus.sys Wed Jun 04 15:53:54 2008 (4846AC82)
9c106000 9c10b480   gtuhssc  gtuhssc.sys  Thu Jun 05 10:23:38 2008 (4847B09A)
9c0dd000 9c0def80   gtuhsser gtuhsser.sys Wed Jun 04 15:38:57 2008 (4846A901)
82e18000 82e4f000   hal      halmacpi.dll Tue Jul 14 00:11:03 2009 (4A5BBF07)
95000000 9501f000   HDAudBus HDAudBus.sys Tue Jul 14 00:50:55 2009 (4A5BC85F)
98696000 9871b000   HTTP     HTTP.sys     Tue Jul 14 00:12:53 2009 (4A5BBF75)
8b800000 8b808000   hwpolicy hwpolicy.sys Tue Jul 14 00:11:01 2009 (4A5BBF05)
96288000 962a0000   i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
8b23d000 8b30b000   iaStor   iaStor.sys   Wed Apr 16 01:07:31 2008 (48054343)
9503a000 95661000   igdkmd32 igdkmd32.sys Thu Aug 13 22:47:54 2009 (4A848A0A)
93aba000 93add000   IntcHdmi IntcHdmi.sys Fri Jul 10 14:44:50 2009 (4A5745D2)
9376b000 9377d000   intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
962a0000 962ad000   kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
80ba8000 80bb0000   kdcom    kdcom.dll    Tue Jul 14 02:08:58 2009 (4A5BDAAA)
93781000 937b5000   ks       ks.sys       Thu Mar 04 03:57:52 2010 (4B8F2FC0)
8b597000 8b5aa000   ksecdd   ksecdd.sys   Tue Jul 14 00:11:56 2009 (4A5BBF3C)
8b717000 8b73c000   ksecpkg  ksecpkg.sys  Fri Dec 11 04:04:22 2009 (4B21C4C6)
957f0000 95800000   lltdio   lltdio.sys   Tue Jul 14 00:53:18 2009 (4A5BC8EE)
8b5c1000 8b5dc000   luafv    luafv.sys    Tue Jul 14 00:15:44 2009 (4A5BC020)
8ae21000 8ae99000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:06:41 2009 (4A5BDA21)
9c0f9000 9c106000   modem    modem.sys    Tue Jul 14 00:55:24 2009 (4A5BC96C)
95e00000 95e0b000   monitor  monitor.sys  Tue Jul 14 00:25:58 2009 (4A5BC286)
962d9000 962e6000   mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8b1db000 8b1f1000   mountmgr mountmgr.sys Tue Jul 14 00:11:27 2009 (4A5BBF1F)
98734000 98746000   mpsdrv   mpsdrv.sys   Tue Jul 14 00:52:52 2009 (4A5BC8D4)
98746000 98769000   mrxsmb   mrxsmb.sys   Sat Feb 27 07:32:02 2010 (4B88CA72)
98769000 987a4000   mrxsmb10 mrxsmb10.sys Sat Feb 27 07:32:21 2010 (4B88CA85)
987a4000 987bf000   mrxsmb20 mrxsmb20.sys Sat Feb 27 07:32:11 2010 (4B88CA7B)
92f95000 92fa0000   Msfs     Msfs.SYS     Tue Jul 14 00:11:26 2009 (4A5BBF1E)
8b0f1000 8b0f9000   msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
8b56c000 8b597000   msrpc    msrpc.sys    Tue Jul 14 00:11:59 2009 (4A5BBF3F)
9367a000 93684000   mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
8b9f0000 8ba00000   mup      mup.sys      Tue Jul 14 00:14:14 2009 (4A5BBFC6)
8b622000 8b6d9000   ndis     ndis.sys     Tue Jul 14 00:12:24 2009 (4A5BBF58)
96355000 96360000   ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
98673000 98683000   ndisuio  ndisuio.sys  Tue Jul 14 00:53:51 2009 (4A5BC90F)
96360000 96382000   ndiswan  ndiswan.sys  Tue Jul 14 00:54:34 2009 (4A5BC93A)
963ec000 963fd000   NDProxy  NDProxy.SYS  Tue Jul 14 00:54:27 2009 (4A5BC933)
8b7d1000 8b7df000   netbios  netbios.sys  Tue Jul 14 00:53:54 2009 (4A5BC912)
92e00000 92e32000   netbt    netbt.sys    Tue Jul 14 00:12:18 2009 (4A5BBF52)
8b6d9000 8b717000   NETIO    NETIO.SYS    Tue Jul 14 00:12:35 2009 (4A5BBF63)
95e1e000 96231000   netw5v32 netw5v32.sys Thu May 14 16:40:33 2009 (4A0C3B71)
92fa0000 92fae000   Npfs     Npfs.SYS     Tue Jul 14 00:11:31 2009 (4A5BBF23)
93670000 9367a000   nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
82e4f000 8325f000   nt       ntkrpamp.exe Wed Oct 27 03:30:44 2010 (4CC78ED4)
8b43d000 8b56c000   Ntfs     Ntfs.sys     Tue Jul 14 00:12:05 2009 (4A5BBF45)
92f35000 92f3c000   Null     Null.SYS     Tue Jul 14 00:11:12 2009 (4A5BBF10)
9862d000 98673000   nwifi    nwifi.sys    Tue Jul 14 00:51:59 2009 (4A5BC89F)
92fd7000 92ff6000   pacer    pacer.sys    Tue Jul 14 00:53:58 2009 (4A5BC916)
8b12e000 8b13f000   partmgr  partmgr.sys  Tue Jul 14 00:11:35 2009 (4A5BBF27)
8b0f9000 8b123000   pci      pci.sys      Tue Jul 14 00:11:16 2009 (4A5BBF14)
8b13f000 8b16d000   pcmcia   pcmcia.sys   Tue Jul 14 00:19:29 2009 (4A5BC101)
8b5aa000 8b5b8000   pcw      pcw.sys      Tue Jul 14 00:11:10 2009 (4A5BBF0E)
b0eb5000 b0f4c000   peauth   peauth.sys   Tue Jul 14 01:35:44 2009 (4A5BD2E0)
93a72000 93aa1000   portcls  portcls.sys  Tue Jul 14 00:51:00 2009 (4A5BC864)
8ae99000 8aeaa000   PSHED    PSHED.dll    Tue Jul 14 02:09:36 2009 (4A5BDAD0)
8b359000 8b362300   PxHelp20 PxHelp20.sys Fri May 15 22:42:35 2009 (4A0DE1CB)
9633d000 96355000   rasl2tp  rasl2tp.sys  Tue Jul 14 00:54:33 2009 (4A5BC939)
96382000 9639a000   raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
9639a000 963b1000   raspptp  raspptp.sys  Tue Jul 14 00:54:47 2009 (4A5BC947)
963b1000 963c8000   rassstp  rassstp.sys  Tue Jul 14 00:54:57 2009 (4A5BC951)
9362f000 93670000   rdbss    rdbss.sys    Tue Jul 14 00:14:26 2009 (4A5BBFD2)
963d2000 963dc000   rdpbus   rdpbus.sys   Tue Jul 14 01:02:40 2009 (4A5BCB20)
92f7d000 92f85000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:01:40 2009 (4A5BCAE4)
92f85000 92f8d000   rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
92f8d000 92f95000   rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
8b73c000 8b769000   rdyboost rdyboost.sys Tue Jul 14 00:22:02 2009 (4A5BC19A)
b0f4c000 b0f4d500   regi     regi.sys     Mon Apr 16 16:19:05 2007 (462393E9)
93600000 93624000   rfcomm   rfcomm.sys   Tue Jul 14 00:51:41 2009 (4A5BC88D)
9626e000 96288000   rimsptsk rimsptsk.sys Wed Mar 12 10:43:06 2008 (47D7B3BA)
9625d000 9626e000   risdptsk risdptsk.sys Wed Jul 09 05:27:28 2008 (48743E30)
98683000 98696000   rspndr   rspndr.sys   Tue Jul 14 00:53:20 2009 (4A5BC8F0)
93832000 93a71040   RTKVHDA  RTKVHDA.sys  Fri May 22 19:03:37 2009 (4A16E8F9)
9c117000 9c123000   scfilter scfilter.sys Tue Jul 14 00:33:50 2009 (4A5BC45E)
b0f4e000 b0f58000   secdrv   secdrv.SYS   Wed Sep 13 14:18:32 2006 (45080528)
962f6000 962f8480   SFEP     SFEP.sys     Fri Aug 03 06:36:08 2007 (46B2BEC8)
8b9eb000 8b9ef280   shpf     shpf.sys     Fri Aug 22 08:48:03 2008 (48AE6F33)
9c10c000 9c117000   SMCLIB   SMCLIB.SYS   Tue Jul 14 00:45:28 2009 (4A5BC718)
962e6000 962e9980   SonyPI   SonyPI.sys   Fri Aug 03 06:41:08 2007 (46B2BFF4)
8b9e3000 8b9eb000   spldr    spldr.sys    Mon May 11 17:13:47 2009 (4A084EBB)
9c039000 9c08a000   srv      srv.sys      Fri Aug 27 04:31:26 2010 (4C77318E)
b0f86000 b0fd5000   srv2     srv2.sys     Fri Aug 27 04:30:45 2010 (4C773165)
b0f58000 b0f79000   srvnet   srvnet.sys   Fri Aug 27 04:30:39 2010 (4C77315F)
963dc000 963dd380   swenum   swenum.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
8b821000 8b96a000   tcpip    tcpip.sys    Mon Jun 14 04:36:59 2010 (4C15A3DB)
b0f79000 b0f86000   tcpipreg tcpipreg.sys Tue Jul 14 00:54:14 2009 (4A5BC926)
93add000 93ae7f00   tcusb    tcusb.sys    Tue Jun 09 19:07:02 2009 (4A2EA4C6)
92fc5000 92fd0000   TDI      TDI.SYS      Tue Jul 14 00:12:12 2009 (4A5BBF4C)
92fae000 92fc5000   tdx      tdx.sys      Tue Jul 14 00:12:10 2009 (4A5BBF4A)
8b600000 8b610000   termdd   termdd.sys   Tue Jul 14 01:01:35 2009 (4A5BCADF)
962ea000 962f6000   tpm      tpm.sys      Tue Jul 14 00:12:52 2009 (4A5BBF74)
821c0000 821c9000   TSDDD    TSDDD.dll    Tue Jul 14 01:01:40 2009 (4A5BCAE4)
9374a000 9376b000   tunnel   tunnel.sys   Tue Jul 14 00:54:03 2009 (4A5BC91B)
963de000 963ec000   umbus    umbus.sys    Tue Jul 14 00:51:38 2009 (4A5BC88A)
93aea000 93b01000   usbccgp  usbccgp.sys  Tue Jul 14 00:51:31 2009 (4A5BC883)
93ae8000 93ae9700   USBD     USBD.SYS     Tue Jul 14 00:51:05 2009 (4A5BC869)
957e1000 957f0000   usbehci  usbehci.sys  Tue Jul 14 00:51:14 2009 (4A5BC872)
937b5000 937f9000   usbhub   usbhub.sys   Tue Jul 14 00:52:06 2009 (4A5BC8A6)
95796000 957e1000   USBPORT  USBPORT.SYS  Tue Jul 14 00:51:13 2009 (4A5BC871)
9578b000 95796000   usbuhci  usbuhci.sys  Tue Jul 14 00:51:10 2009 (4A5BC86E)
93b01000 93b24b80   usbvideo usbvideo.sys Thu Mar 04 04:04:40 2010 (4B8F3158)
8b123000 8b12e000   vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
92f43000 92f4f000   vga      vga.sys      Tue Jul 14 00:25:50 2009 (4A5BC27E)
92f4f000 92f70000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
8b99b000 8b9a3380   vmstorfl vmstorfl.sys Tue Jul 14 00:28:44 2009 (4A5BC32C)
8b16d000 8b17d000   volmgr   volmgr.sys   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
8b17d000 8b1c8000   volmgrx  volmgrx.sys  Tue Jul 14 00:11:41 2009 (4A5BBF2D)
8b9a4000 8b9e3000   volsnap  volsnap.sys  Tue Jul 14 00:11:34 2009 (4A5BBF26)
8b7df000 8b7f2000   wanarp   wanarp.sys   Tue Jul 14 00:55:02 2009 (4A5BC956)
92f70000 92f7d000   watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
8b021000 8b092000   Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
8b092000 8b0a0000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
92fd0000 92fd7000   wfplwf   wfplwf.sys   Tue Jul 14 00:53:51 2009 (4A5BC90F)
81f60000 821ab000   win32k   win32k.sys   Wed Jan 05 03:37:16 2011 (4D23E76C)
8b0e8000 8b0f1000   WMILIB   WMILIB.SYS   Tue Jul 14 00:11:22 2009 (4A5BBF1A)
8b5dc000 8b5f6000   WudfPf   WudfPf.sys   Tue Jul 14 00:50:13 2009 (4A5BC835)
9c0ad000 9c0cd480   WUDFRd   WUDFRd.sys   Tue Jul 14 00:50:44 2009 (4A5BC854)
Unloaded modules:
9c196000 9c200000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
9c000000 9c00a000   fsbldrv.sys
    Checksum:  00000000
    ImageSize:  0000A000
9c123000 9c18d000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
987bf000 987d7000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8b811000 8b81e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
92e37000 92f05000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  000CE000
92f05000 92f16000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
If blue screens continue attach new dump files.
Important! Every thread starter please see. Take snips of the Memory tab and all the Slot #'s available under the SPD tab.
Elmer
Do you recognise this driver/software company?
appliand.sys Fri May 28 12:54:28 2010 Applian Network Service Applian Technologies.
This driver was mentioned in all your dump files. I suggest you uninstall the software until your BSOD's are resolved.
Thanks for the tips.
To update the drivers, is it simply a case of googling them and installing any updates. How do I uninstall a driver?
1. How to uninstall a driver?
--> Control Panel --> Programs and Features --> Uninstall
2. How do I update drivers?
--> Download the latest version from the manufacturer's web site.
Also visit your notebook support.
Downloads
Intel® Driver Update Utility
Realtek
--> See Elmer's post above.
For now you may want to uninstall Applian software and install its latest at some point later when you system gets stable without BSOD's.
