Google’s Gemini 3.5 Pro is reportedly several months behind schedule after missing internal expectations for coding performance, particularly on lengthy programming tasks and accuracy across multi-step operations. Google has not announced a revised public release date.
A coding model can appear highly capable in a short demonstration while still failing in a real engineering workflow. The harder task is maintaining the original objective over time: understanding a codebase, identifying related files, proposing changes, using tools, responding to test failures, and recognizing when an earlier assumption was wrong. Errors at any stage can create extra review work or introduce defects that are difficult to detect.
That does not mean a delayed model is unusable or that Google’s current AI offerings lack value. It does mean that enterprises should distinguish between assistance with discrete tasks and trust in systems that act across extended workflows. The latter requires more than convincing code output. It requires predictable behavior when context grows, tools are involved, requirements change, and the model must recover from failure.
Bloomberg-derived reporting said Google updated training data late in the month before the delay was reported, with a focus on programming ability, but that the results did not meet internal expectations. Daily Beirut separately reported that the company rebuilt significant portions of Gemini 3.5 Pro in response to difficulties with extended coding work and multi-step accuracy.
WindowsForum analysis: the reported decision to continue work rather than announce a revised release date suggests that Google is treating long-horizon coding reliability as an important quality threshold for the Pro model. That is an interpretation of the reporting, not a confirmed statement of Google’s release criteria.
The table is important because “Gemini is delayed” is too broad. The reported delay concerns Gemini 3.5 Pro. The supplied reporting also describes partner testing for an upgraded Flash model and other systems, but it does not establish that those models are broadly available or that they can substitute for Pro in a particular enterprise workload.
For buyers, the safest conclusion is straightforward: evaluate what is available under documented terms, and do not convert reports about future models into deployment assumptions.
That gap matters because organizations planning AI adoption do not make decisions only on benchmark comparisons. They make decisions around developer tooling, cloud architecture, procurement cycles, security reviews, data-handling requirements, training plans, and the internal support burden associated with a new platform. A delay can affect those plans even when no existing service has been withdrawn.
WION’s account of Pichai’s I/O presentation said Google was using Gemini 3.5 Pro internally. Internal use can demonstrate that a model exists and has practical applications in a controlled environment. It does not, by itself, establish broad customer availability, product readiness, or a timetable for external deployment.
WindowsForum analysis: internal use and public availability are different milestones. A model can be useful within a company’s own environment while still requiring more work before it is offered to a wide set of customers with different codebases, policies, toolchains, and operational constraints.
Google’s products named in the reporting include Search, Gmail, Maps, Android, Chrome, Workspace, Cloud, and YouTube. Those product names illustrate why a Gemini model announcement receives unusual attention: Google operates across consumer software, enterprise services, cloud infrastructure, and developer platforms. But the reporting does not establish that Gemini 3.5 Pro will be integrated into each product, nor does it establish a particular rollout sequence.
The “boil an ocean” description from a former employee, reported by Bloomberg and repeated by WION and Deccan Chronicle, captures a concern about the breadth of Google’s AI efforts. It should not be read as proof that integration complexity caused the Gemini 3.5 Pro delay. The reported performance issues—especially coding and multi-step accuracy—remain the clearest stated explanation.
June 2026: Gemini 3.5 Pro had been expected to launch after I/O, according to reporting cited by WION and other outlets.
Late June 2026: Bloomberg-derived reporting says Google updated training data to improve programming ability, but the results reportedly did not meet internal expectations.
July 17, 2026: Bloomberg-derived reports say Gemini 3.5 Pro is several months behind schedule and remains in testing, with no new public launch date announced.
July 18, 2026: Daily Beirut reports that significant portions of Gemini 3.5 Pro were rebuilt to address reported problems involving extended coding work and multi-step accuracy.
Deccan Chronicle reported that Chief AI Architect Koray Kavukcuoglu was working with the main engineering organization to unify internal AI coding tools. It also reported that a DeepMind team focused on AI coding had been formed earlier in the year under research engineer Sebastian Borgeaud.
The same report identified Google Antigravity as a framework involved in the company’s AI efforts. Beyond its name and its inclusion in that reporting, its specific technical functions should not be assumed.
The broader lesson does not depend on details about any one internal framework. Reliable coding systems require more than a base model that can generate text or source code. Organizations using AI for development need governance around access, approvals, testing, logging, rollback, and review. Those controls matter whether the AI comes from Google or another vendor.
Google’s reported claim that 75% of its code is generated by AI is another point that requires careful interpretation. Deccan Chronicle reported the 75% figure, but the supplied reporting does not establish how the metric is defined, which teams or codebases it covers, or how it maps to customer use cases. It is therefore evidence of Google’s stated internal AI adoption, not a direct measure of how Gemini 3.5 Pro will perform for external enterprises.
That distinction is particularly important for long-running coding tasks. A company’s internal systems may include established repositories, familiar tools, standardized engineering practices, and experienced reviewers. An external customer may have a more varied environment, custom dependencies, legacy applications, different identity controls, and different tolerance for error. A model that is helpful in one setting is not automatically ready for all settings.
Model rankings are unstable and highly dependent on the task, evaluation method, tool configuration, price, latency, context limits, and human oversight. Enterprises should be cautious about treating any single benchmark or launch narrative as a lasting market verdict.
Still, coding has become a meaningful test of broader AI capability. Software tasks can require planning, context retention, use of external tools, structured output, iterative correction, and verification. Those same properties matter in other business workflows, including data analysis, operations, support escalation, document processing, and internal automation.
This does not mean every organization needs an autonomous coding agent. In many environments, the most valuable deployment may remain a developer assistant that drafts code, explains unfamiliar systems, generates tests, or helps with documentation under human review. The right level of automation depends on the risk of the task and the organization’s ability to inspect the output.
Google has said it remains engaged with the U.S. government on model testing and broader AI frameworks, according to the reporting. That context is relevant to frontier-model releases, but the reported explanation for Gemini 3.5 Pro’s postponement is performance, particularly coding capability and multi-step accuracy. The available reports do not establish regulation as the direct reason for the schedule change.
The strongest practical takeaway is to separate three questions:
Long-horizon coding reliability deserves special attention because it is easy to overestimate. A model may perform well on isolated tasks yet fail when required to preserve a goal over many actions. Admins and engineering leaders should test for failure modes directly:
That is enough for enterprises to make a sensible near-term decision. Treat Gemini 3.5 Pro as a future option, not a current dependency. Evaluate currently available AI tools against actual workflows. Keep high-risk actions under human control. Require evidence of reliability over the full task, not just an impressive first response.
WindowsForum analysis: if Gemini 3.5 Pro eventually arrives with stronger long-horizon coding performance, its value will be determined less by the “Pro” label than by whether organizations can verify dependable behavior in the messy conditions of real work: incomplete context, changing requirements, multiple tools, security boundaries, and the need to recover from mistakes. Until then, the direct checklist is more valuable than speculation about release timing.
What is confirmed
- Bloomberg-derived reporting says Gemini 3.5 Pro is delayed by several months and that Google has not provided a new public launch date.
- Daily Beirut reported that Google encountered problems with extended coding tasks and maintaining accuracy across multi-step work, and that significant portions of the model were rebuilt.
- WION reported that Sundar Pichai discussed Google’s internal use of Gemini 3.5 Pro during the company’s I/O presentation.
- Google has said it is testing Gemini 3.5 Pro, an upgraded Flash model, and other systems with selected partners, according to the reports.
What is not confirmed
- A broad public availability date for Gemini 3.5 Pro.
- Broad availability of the upgraded Flash model.
- Whether the reported delay will affect specific Google products, cloud services, or developer tools.
- Whether organizational complexity, safety review, capacity, or product integration is a direct cause of the delay. Those are possible considerations, but the reporting centers on model performance.
What admins should do this week
- Do not base a production roadmap on Gemini 3.5 Pro until Google publishes supported availability and commercial details.
- Keep coding-assistant testing model-neutral and use real internal tasks rather than vendor demonstrations.
- Separate currently available Gemini capabilities from models that are only being tested with selected partners.
- Require human review and change controls for AI-generated code, especially for infrastructure, security, and multi-file changes.
Google’s Problem Is Not Code Completion; It Is Sustained Execution
The reported issue is not simply whether Gemini can generate a function, explain a code block, or create boilerplate. Daily Beirut’s account points to trouble with long programming tasks and preserving accuracy across multi-step operations. That distinction matters because those are the conditions under which AI moves from a conversational assistant toward a tool used in software delivery and business processes.A coding model can appear highly capable in a short demonstration while still failing in a real engineering workflow. The harder task is maintaining the original objective over time: understanding a codebase, identifying related files, proposing changes, using tools, responding to test failures, and recognizing when an earlier assumption was wrong. Errors at any stage can create extra review work or introduce defects that are difficult to detect.
| Model / status | Public position described in reporting | Reported role | Availability described | Practical takeaway |
| Gemini 3.5 Pro | Reported to be delayed; Google is said to be testing it with selected partners | Flagship model associated with demanding reasoning and coding work | No revised public release date has been announced | Do not assume availability or performance details until Google provides them |
| Upgraded Gemini Flash model | Google is reported to be testing it with selected partners | A Flash-model update | Selected-partner testing is described; broader availability is not established | Treat it as a separate model status from Gemini 3.5 Pro |
| Other Google AI systems | Also described as being tested with selected partners | Broader model and product development | Not specified | Avoid treating Google’s AI portfolio as a single release event |
The I/O Promise Has Become a Calendar Problem
Reporting described Gemini 3.5 Pro as expected after Google I/O 2026, with a June launch expectation cited in accounts carried by WION and other outlets. By mid-July, Bloomberg-derived reports said the model was several months behind schedule, with no new date publicly announced by Google.That gap matters because organizations planning AI adoption do not make decisions only on benchmark comparisons. They make decisions around developer tooling, cloud architecture, procurement cycles, security reviews, data-handling requirements, training plans, and the internal support burden associated with a new platform. A delay can affect those plans even when no existing service has been withdrawn.
Timeline
May 2026: Google I/O takes place. Reporting indicates that Gemini 3.5 Pro was expected to be introduced around the event period and that Google discussed continuing work on the model.June 2026: Gemini 3.5 Pro had been expected to launch after I/O, according to reporting cited by WION and other outlets.
A Delay Is Also a Test of Google’s AI Organization
Deccan Chronicle reported frustration among current and former employees as Google Cloud, Google DeepMind, and Android pursued AI coding products. Outside observers cannot independently verify the full scope of internal coordination challenges from those accounts alone. Still, the reporting presents an organizational question alongside the technical one: how quickly can Google turn research, models, developer tools, and product teams into coherent offerings?Deccan Chronicle reported that Chief AI Architect Koray Kavukcuoglu was working with the main engineering organization to unify internal AI coding tools. It also reported that a DeepMind team focused on AI coding had been formed earlier in the year under research engineer Sebastian Borgeaud.
The Market Has Turned Coding Into the Frontier Model’s Report Card
The reporting places Gemini 3.5 Pro’s delay in a competitive market that includes OpenAI, Anthropic, and Meta Platforms. Deccan Chronicle reported that OpenAI and Meta had released models viewed as ahead of Google’s current offerings in code-writing AI, while other accounts identified OpenAI and Anthropic as major competitors for enterprise software work.Model rankings are unstable and highly dependent on the task, evaluation method, tool configuration, price, latency, context limits, and human oversight. Enterprises should be cautious about treating any single benchmark or launch narrative as a lasting market verdict.
Action checklist for admins
- Do not build a production migration plan around Gemini 3.5 Pro until Google publishes a public availability date, commercial terms, and supported deployment details.
- Keep coding-assistant evaluations model-neutral. Compare task completion, review burden, latency, cost, tool compatibility, and data handling using representative internal work.
- Treat available Gemini products, partner-tested models, and future Gemini 3.5 Pro expectations as separate categories in procurement and architecture documents.
- Maintain human review and change-control requirements for AI-generated code, especially for multi-file changes, infrastructure automation, identity systems, security controls, and production deployments.
- Test whether an AI tool preserves task context across multiple steps, explains its actions, records changes, and handles failed tests or incomplete tool operations.
- Confirm where prompts, source code, logs, embeddings, and generated artifacts are stored and processed before allowing sensitive repositories into an AI workflow.
- Require a rollback path for automated or semi-automated changes. A tool that can generate a patch should not automatically receive authority to deploy it.
- Avoid comparing products solely by headline model names. The available interface, tool permissions, context limits, pricing, regional support, and governance controls may matter more than the model label.
What the Postponement Actually Changes for Buyers
For IT leaders, the delay should change planning discipline rather than trigger panic. Google remains a major AI platform provider with services used across consumer, enterprise, cloud, and developer environments. But buyers should not infer future Gemini 3.5 Pro capabilities from reports about internal use, selected-partner testing, or other models in the Gemini family.The strongest practical takeaway is to separate three questions:
- What can the organization deploy today?
This requires documented product availability, supported regions, pricing, security terms, administrative controls, and integration details. - What can the organization test through a vendor partnership?
Partner testing may be useful for early evaluation, but it is not the same as a generally available service with stable terms and support commitments. - What is still an anticipated capability?
Gemini 3.5 Pro belongs in this category until Google announces a public launch and customers can validate it in their own environment.
- Does the tool recognize when it lacks sufficient context?
- Does it distinguish a suggestion from an executed change?
- Can it explain which files, services, or dependencies were affected?
- Does it preserve approval boundaries when it calls tools or prepares changes?
- Can it recover gracefully after a failed build, test, or deployment step?
- Does it create output that reviewers can understand and safely reject?
The Forward View: Evaluate the Work, Not the Promise
The key facts remain limited but meaningful: Bloomberg-derived reporting says Gemini 3.5 Pro is delayed by several months, Daily Beirut reports problems with extended coding work and multi-step accuracy, and Google has not announced a revised public release date. Reporting also indicates that Google is testing Gemini 3.5 Pro, an upgraded Flash model, and other systems with selected partners.That is enough for enterprises to make a sensible near-term decision. Treat Gemini 3.5 Pro as a future option, not a current dependency. Evaluate currently available AI tools against actual workflows. Keep high-risk actions under human control. Require evidence of reliability over the full task, not just an impressive first response.
- Primary source: Daily Beirut
Published: 2026-07-18T05:55:20.690000+00:00
Loading…
dailybeirut.com - Independent coverage: BW Businessworld
Published: Fri, 17 Jul 2026 14:45:02 GMT
Loading…
www.businessworld.in - Independent coverage: APAC Media
Published: 2026-07-17T09:18:05+00:00
Loading…
apacnewsnetwork.com - Independent coverage: Межа. Новини України.
Published: 2026-07-17T10:14:34+00:00
Loading…
mezha.net - Independent coverage: WION
Published: Fri, 17 Jul 2026 08:32:00 GMT
Loading…
www.wionews.com - Independent coverage: Deccan Chronicle
Published: 2026-07-17T08:00:40+00:00
Loading…
www.deccanchronicle.com
