graemeakerby
Hi guys,
I recently upgraded my GPU to an ATI Radeon HD 5750 and have been having some issues with it, or perhaps the drivers. I have ensured that the latest drivers are installed and have tried a few solutions suggested on the web, such as cleaning my registry and reinstalling the graphics card drivers but the problem is still there.
The problem is that my graphics seem to stop at random points. If I start playing a game, say Civilization 4; it will run for a few minutes, or an hour or a few seconds, until the screen goes black. If I reboot, then the game will start up again but its incredibly frustrating. The same thing happens on Dragon Age Origins. I have not got my GPU overclocked and I have checked on HW Monitor and the temperature is staying nice and low (between 40-60c). It also occasionally (although not too often) crashes when on VLC media player playing .mkv files, but this is quite rare.
When it first did this, Windows would say "your drivers have been recovered" and it would continue playing the file on VLC player, but it seems as though I just get a black screen now.
Please help! I recently got back into building PCs again and have just realised why I stopped doing it years ago lol! I looked up the "your drivers have been recovered" bug on Google and every suggested fix doesn't seem to work. Any help will be greatly appreciated!
Edit:
Please follow TG's suggestions first, update your realtek, uninstall AVG.
Oh, looks like I misunderstood you the first time, about the permissions issue. I see now.
090310-19858-01.dmp
VIDEO_TDR_TIMEOUT_DETECTED (117)
Bug Check 0x117: VIDEO_TDR_TIMEOUT_DETECTED
The display driver failed to respond in timely fashion
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_TIMEOUT
FAILURE_BUCKET_ID: X64_0x117_IMAGE_atikmpag.sys
Atikmpag.sys AMD multi-vendor Miniport Driver
(atikmpag.sys Wed Aug 04 04:15:45 2010)
The amd driver is Ok, but it did cause the error. I would completely uninstall your current Catalyst, all of it, reboot, apply driver sweeper, reboot, and finally install the latest Catalyst. To make sure no ATI files or...
Use Driver Sweeper from Guru3d.com in safe mode, to clear the machine of all ATI and if you previously had an NVIDIA card, all NVIDIA files too. (Leave the chipset drivers alone if you have NVIDIA chipset.)
Reboot to normal mode and install the latest driver from here:
Although the issue seemed to be fixed, I am still getting random crashes, although much more rarely. Any ideas?
Before installing the new version, did you uninstall your old catalyst first?
Attach the crash dumps found in your C:\Windows\Minidump.
Yes I uninstalled it first. Since then I have had to install nvidia PhysX (it came with Mass Effect 2), that game seems fine, but video crashed when watching an mkv yesterday.
When I try attaching the file it says I need to be administrator to do it. I am on the only account on the PC and it is Admin, how will I be able to get this file to you on here?
Sorry I'm a bit of a n00b.
PhysX might be the problem if you're using it with an ATI card. As for attaching .dmp files, zip them and use the advanced reply option to attach the archive with your post.
Edit:
You can also upload them to a file hosting service and post the link. e.g. windows live skydrive,
Ok well the issue occured before I put Mass Effect 2 on, so not sure about that. It still won't let me zip it, says Access is denied on WinRARs diagnostic message. Also when trying to upload it on Skydrive it says "Sorry there was a problem trying to upload this file. Please try again."
I'm not sure why its doing this as I am the Administrator, is there a way to make the file more accessible?
Uninstall AVG which very well has high chances of being the culrpit here. Do this in safe mode using the tool here:
AV Uninstallers - Windows 7 Forums
Reboot and install MSE.
Update your Realtek lan driver. Type systeminfo in a command prompt then press enter. It will tell you the Realtek lan number. If you have 8111, use this link. If anything else, search the number on the left side of the link:
Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009
Hi TorrentG,
OK I will try that.
What is MSE? I am not sure about the RealTek drivers as I am just using my motherboards built in port (Gigabyte GA-MA770 UD3). I will check out that on command prompt!
Ahh ok Microsoft Security Essentials, OK I will give that a go, removed AVG, updated the LAN drivers. Will let you know how it goes.
Shall I uninstall Ad-Aware if I am using MSE?
Edit:
090310-19858-01.dmp
The amd driver is Ok, but it did cause the error. I would completely uninstall your current Catalyst, all of it, reboot, apply driver sweeper, reboot, and finally install the latest Catalyst. To make sure no ATI files or registry records are left before reinstalling it.
I would test the video card too.
You may want to update this product:
000.fcl Fri Sep 26 16:11:22 2008
Cyberlink
If more crash dumps follow, please attach them.
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\090310-19858-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02a09000 PsLoadedModuleList = 0xfffff800`02c46e50
System Uptime: 0 days 8:55:22.471
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
BugCheck 117, {fffffa8005fe6380, fffff88003b86dcc, 0, 0}
Unable to load image atikmpag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+6dcc )
Followup: MachineOwner
0: kd> !analyze -v
The display driver failed to respond in timely fashion.
(This code can never be used for real bugcheck).
Arguments:
Arg1: fffffa8005fe6380, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88003b86dcc, The pointer into responsible device driver module (e.g owner tag).
Arg3: 0000000000000000, The secondary driver specific bucketing key.
Arg4: 0000000000000000, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
atikmpag+6dcc
fffff880`03b86dcc ??              ???
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x117
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`0216b400 fffff880`044884ef : fffffa80`05fe6380 00000000`00000024 fffffa80`05fe6380 fffff880`04488190 : watchdog!WdDbgReportRecreate+0xa3
fffff880`0216b920 fffff880`04488926 : 00000000`00001000 fffff8a0`0152c900 00000000`00000008 00000000`00004080 : dxgkrnl!TdrUpdateDbgReport+0xcb
fffff880`0216b970 fffff880`04489bda : fffffa80`05fe6380 fffffa80`05fe6380 fffffa80`062e97d0 fffffa80`04df2410 : dxgkrnl!TdrCollectDbgInfoStage1+0x2e6
fffff880`0216ba10 fffff880`04530f07 : fffffa80`05fe6380 00000000`00000000 fffffa80`062e97d0 fffffa80`04df2410 : dxgkrnl!TdrIsRecoveryRequired+0x17a
fffff880`0216ba40 fffff880`0455ab75 : 00000000`ffffffff 00000000`001f6868 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`0216bb20 fffff880`045592bb : 00000000`00000102 00000000`00000000 00000000`001f6868 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`0216bb50 fffff880`0452c2c6 : ffffffff`ff676980 fffffa80`04df2410 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`0216bbf0 fffff880`04558e7a : 00000000`00000000 fffffa80`062e97d0 00000000`00000080 fffffa80`04df2410 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`0216bd00 fffff800`02d1dc06 : 00000000`fffffc32 fffffa80`04ded4d0 fffffa80`03973890 fffffa80`04ded4d0 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`0216bd40 fffff800`02a57c26 : fffff800`02bf3e80 fffffa80`04ded4d0 fffff800`02c01c40 fffff880`01222534 : nt!PspSystemThreadStartup+0x5a
fffff880`0216bd80 00000000`00000000 : fffff880`0216c000 fffff880`02166000 fffff880`02169ff0 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+6dcc
SYMBOL_NAME:  atikmpag+6dcc
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME:  atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4c58bf41
fffff800`00b96000 fffff800`00ba0000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02a09000 fffff800`02fe5000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff800`02fe5000 fffff800`0302e000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c4c000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00c53000 fffff880`00c60000   mcupdate mcupdate.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00c60000 fffff880`00c74000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00c74000 fffff880`00cd2000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00cd2000 fffff880`00d92000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00d92000 fffff880`00dee000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00e53000 fffff880`00ef7000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00ef7000 fffff880`00f06000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f06000 fffff880`00f5d000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00f5d000 fffff880`00f66000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f66000 fffff880`00f70000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00f70000 fffff880`00fa3000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fa3000 fffff880`00fb0000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00fb0000 fffff880`00fc5000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00fc5000 fffff880`00fda000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00fda000 fffff880`00fe1000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00fe1000 fffff880`00ff1000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00ff1000 fffff880`00ffc000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01086000 fffff880`010c0000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`010d2000 fffff880`010e6000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`010e6000 fffff880`010fb000   Lbd      Lbd.sys      Tue May 25 10:45:36 2010 (4BFB8020)
fffff880`010fb000 fffff880`01159000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01159000 fffff880`011cc000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`011cc000 fffff880`011e2000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01214000 fffff880`013b7000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013b7000 fffff880`013d1000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`013d1000 fffff880`013e2000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`013e2000 fffff880`013ec000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`013ec000 fffff880`013fe000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`0142b000 fffff880`01475000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`01475000 fffff880`01485000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`01485000 fffff880`0148d000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`0148d000 fffff880`01496000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`0149d000 fffff880`0158f000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`0158f000 fffff880`015ef000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`01811000 fffff880`01841000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01877000 fffff880`018a1000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`018a1000 fffff880`018aa000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`018aa000 fffff880`018b1000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`018b1000 fffff880`018bf000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`018bf000 fffff880`018e4000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`018e4000 fffff880`018f4000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`018f4000 fffff880`018fd000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`018fd000 fffff880`01906000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`01906000 fffff880`0190f000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`0190f000 fffff880`0191a000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`0191a000 fffff880`0192b000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`0192b000 fffff880`01949000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`01949000 fffff880`01956000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`01956000 fffff880`019a7000   avgtdia  avgtdia.sys  Fri Jun 04 00:09:57 2010 (4C081A25)
fffff880`019a7000 fffff880`019ec000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02c00000 fffff880`02c51000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`02c51000 fffff880`02c5d000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`02c5d000 fffff880`02c68000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`02c68000 fffff880`02c77000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`02c77000 fffff880`02cb5000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff880`02ccd000 fffff880`02d57000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02d57000 fffff880`02d60000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d60000 fffff880`02d86000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02d86000 fffff880`02d95000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d95000 fffff880`02db2000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02db2000 fffff880`02dcd000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02dcd000 fffff880`02de1000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02de1000 fffff880`02dfb000   SCDEmu   SCDEmu.SYS   Mon Apr 12 11:52:25 2010 (4BC2DF49)
fffff880`03a00000 fffff880`03a2f000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`03a3b000 fffff880`03abe000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03abe000 fffff880`03adc000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03adc000 fffff880`03aed000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03aed000 fffff880`03af4080   avgmfx64 avgmfx64.sys Mon Apr 26 00:06:15 2010 (4BD4AEC7)
fffff880`03af5000 fffff880`03b3c000   avgldx64 avgldx64.sys Fri Jun 04 00:06:48 2010 (4C081968)
fffff880`03b3c000 fffff880`03b62000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03b62000 fffff880`03b77000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03b77000 fffff880`03b80000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`03b80000 fffff880`03bc7000   atikmpag atikmpag.sys Wed Aug 04 04:15:45 2010 (4C58BF41)
fffff880`03bc7000 fffff880`03beb000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`03c00000 fffff880`03c1b000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`03c1f000 fffff880`0438d000   atikmdag atikmdag.sys Wed Aug 04 04:39:08 2010 (4C58C4BC)
fffff880`0438d000 fffff880`043e3000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`043e3000 fffff880`043f9000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`04400000 fffff880`0441d000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`0441d000 fffff880`0442d000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`0442d000 fffff880`04521000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`04521000 fffff880`04567000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`04567000 fffff880`0458b000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`0458b000 fffff880`045bd000   Rt64win7 Rt64win7.sys Thu Feb 26 11:04:13 2009 (49A65B0D)
fffff880`045bd000 fffff880`045c8000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`045c8000 fffff880`045d9000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`045d9000 fffff880`045e6000   fdc      fdc.sys      Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`045e6000 fffff880`045f2000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`045f2000 fffff880`045fe000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`04a00000 fffff880`04a22000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`04a22000 fffff880`04a27200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`04a6b000 fffff880`04a8c000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`04a8c000 fffff880`04aa6000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`04aa6000 fffff880`04ab1000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`04ab1000 fffff880`04ac0000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`04ac0000 fffff880`04acf000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`04acf000 fffff880`04ad0480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`04ad1000 fffff880`04b14000   ks       ks.sys       Tue Jul 14 03:00:31 2009 (4A5BCA9F)
fffff880`04b14000 fffff880`04b26000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`04b26000 fffff880`04b80000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`04b80000 fffff880`04b8b000   flpydisk flpydisk.sys Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`04b8b000 fffff880`04ba0000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`04ba0000 fffff880`04bc0000   AtihdW76 AtihdW76.sys Thu Jul 15 15:46:49 2010 (4C3F0339)
fffff880`04bc0000 fffff880`04bfd000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`05e00000 fffff880`05e21000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`05e21000 fffff880`05e36000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05e36000 fffff880`05e4e000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05ed6000 fffff880`05f32000   HdAudio  HdAudio.sys  Tue Jul 14 03:06:59 2009 (4A5BCC23)
fffff880`05f32000 fffff880`05f3e000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`05f3e000 fffff880`05f4c000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`05f4c000 fffff880`05f65000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`05f65000 fffff880`05f6d080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`05f6e000 fffff880`05f6ff00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`05f70000 fffff880`05f7e000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`05f7e000 fffff880`05f8b000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`05f8b000 fffff880`05f99000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`05f99000 fffff880`05fbc000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`05fbc000 fffff880`05fca000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`05fca000 fffff880`05fd6000   dump_ataport dump_ataport.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`05fd6000 fffff880`05fdf000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`05fdf000 fffff880`05ff2000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`07a00000 fffff880`07a2d000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`07a2d000 fffff880`07a7b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`07a7b000 fffff880`07a9e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`07aa7000 fffff880`07ab0000   cpuz134_x64 cpuz134_x64.sys Fri Jul 09 14:16:58 2010 (4C37052A)
fffff880`07af7000 fffff880`07bbf000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`07bbf000 fffff880`07bdd000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`07bdd000 fffff880`07bf5000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`07e0a000 fffff880`07eb0000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`07eb0000 fffff880`07ebb000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`07ebb000 fffff880`07ee8000   srvnet   srvnet.sys   Tue Jun 22 06:20:32 2010 (4C202C00)
fffff880`07ee8000 fffff880`07efa000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`07efa000 fffff880`07f25000   000      000.fcl      Fri Sep 26 16:11:22 2008 (48DCDF7A)
fffff880`07f25000 fffff880`07f8d000   srv2     srv2.sys     Tue Jun 22 06:20:47 2010 (4C202C0F)
fffff880`08200000 fffff880`0820c000   usbprint usbprint.sys Tue Jul 14 03:38:18 2009 (4A5BD37A)
fffff880`0820c000 fffff880`08227000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`08227000 fffff880`08258000   WUDFRd   WUDFRd.sys   Tue Jul 14 03:06:06 2009 (4A5BCBEE)
fffff880`08258000 fffff880`08261000   cpuz133_x64 cpuz133_x64.sys Tue May 11 12:58:57 2010 (4BE92A61)
fffff880`082bc000 fffff880`08352000   srv      srv.sys      Tue Jun 22 06:21:11 2010 (4C202C27)
fffff880`08352000 fffff880`08388000   fastfat  fastfat.SYS  Tue Jul 14 02:23:28 2009 (4A5BC1F0)
fffff880`08388000 fffff880`0838f000   pbfilter pbfilter.sys Mon Sep 28 09:02:08 2009 (4AC05160)
fffff880`0838f000 fffff880`083e3000   udfs     udfs.sys     Tue Jul 14 02:23:37 2009 (4A5BC1F9)
fffff880`083e3000 fffff880`08400000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff960`000e0000 fffff960`003ef000   win32k   win32k.sys   Sat Jun 19 07:31:59 2010 (4C1C483F)
fffff960`00590000 fffff960`0059a000   TSDDD    TSDDD.dll    Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff960`00640000 fffff960`00667000   cdd      cdd.dll      Wed May 19 22:48:26 2010 (4BF4408A)
Ok thank you! I will get to that later on. Hope it works :) thanks for helping as I have no clue what to do without this!
Ok I did everything suggested but couldn't get MSE on, so put BitDefender on. PCs been working fine, up until just a few minutes ago when uh-oh another crash...
I also checked Cyberlink and Power DVD says its up to date.
What shall I try now?
Post the crash dump(s) and also begin testing memory with Memtest86+.
Overnight testing is usually best to find errors with ram if any exist. Or sometimes, modules need to be tested one at a time to find errors.
Perhaps there will be something new to see with the new crash dumps, but likely faulty memory or faulty card.
Update the motherboard bios to latest if not already.
The Cyberlink software is not causing issues.
