Terminator
I have a 650GB Sata H.D.How can I partition it to half this?
You don't - if I take your question literally. But I assume you mean you have a 650Gb drive, and you want to partition it into two 325Gb partitions.
Is there data already on this drive?
If so, I recommend EaseUS Partition Master.
You could try partition your hard drive in windows7 build-in disk management, right click the exsited partition and select shrink partition, after that you will release an segment of unallocated space->you could create partition on this unallocated space.
If disk management could not achieve your goal, you could choose partition magic software: Link Removed - Invalid URL
To partition windows why not choose Link Removed - Invalid URL, it is pretty good for win7
