Have original product key but no cd
Srlec
I bought notebook few months ago(win7 home premium) and i have my original product key but i dont have CD, is it possible to download WIN7 Home premium somewhere and to use this key?
catilley1092
Srlec, here you go:
Download Retail Windows 7 ISO from Official Website | Windows7hacker
You can choose from the original Windows 7 install disk or the post SP1 install disk, whichever you prefer. If you intend to install SP1, you may as well download the one with SP1 already on it, it'll save you a lot of time on the SP install alone, which has most of the original updates already rolled into it.
EDIT: Be sure, if possible to use a download manager, such as "Down Them All" in Firefox (this is one example, there are others), as this is well over 2GB (32 bit) and 3GB (64 bit). Burn it slow for best results.
Hope this helps!
Cat
whs
To activate it, use the product key that is on the COA sticker on the bottom of your laptop - NOT the key that was in the OEM Windows system. That is a generic key the OEMs use to activate the OS.
