HDF5 1.14.6 CVE-2025-7067 Heap Overflow Crashes Applications
A heap‑based buffer overflow has been publicly disclosed in HDF5 1.14.6: the flaw resides in the free‑space serialization callback H5FS__sinfo_serialize_node_cb within src/H5FScache.c and can be triggered when an application processes crafted or corrupted .h5 files, producing a one‑byte out‑of‑bounds write that leads to heap corruption and reliable crashes under sanitizer builds.
Blue grid platform with a sparking block and binary rain, beside a red CVE-2025-7067 warning.Background​
HDF5 (Hierarchical Data Format 5) is a widely used binary container and C library for storing large numerical arrays, chunked datasets and rich hierarchical metadata. Because HDF5 is often linked directly into command‑line tools, language bindings (Python, R), container images, scientific pipelines and vendor appliances, a memory‑safety bug in the core library can surface across a broad set of consumers and deployment models.
The vulnerability tracked as CVE‑2025‑7067 was disclosed publicly on July 4, 2025, and has been indexed by major vulnerability databases and vendor trackers. Public advisories consistently identify HDF5 1.14.6 as the affected release and describe the problem as a heap‑based buffer overflow in H5FS__sinfo_serialize_node_cb.
What the advisory says (concise summary)​
  • Vulnerable component: HDF5 library, version 1.14.6.
  • Faulty function: H5FS__sinfo_serialize_node_cb (file src/H5FScache.c).
  • Vulnerability class: heap‑based buffer overflow (CWE‑122 / CWE‑119).
  • Attack vector: local file input (an attacker must cause a vulnerable process to parse or open a crafted .h5 file); in practice, server‑side ingestion pipelines that accept untrusted files may be remotely triggerable by uploading a malicious file.
  • Immediate impact: Denial‑of‑service (process crash) and heap corruption; arbitrary code execution (RCE) is possible in theory but not demonstrated as a trivial outcome in public advisories.
  • Disclosure date and tracking: Publicly disclosed July 4, 2025; PoC evidence and sanitizer traces were made available in the upstream issue tracker.
These points are consistent across vulnerability aggregators and distribution trackers.
Technical anatomy: where and why it happens​
The call path and sanitizer evidence​
The reporter provided an AddressSanitizer trace showing a one‑byte write at H5FScache.c:1441 inside H5FSsinfo_serialize_node_cb. The ASAN stack trace demonstrates the write occurs while serializing free‑space section information and that the write flows through the library’s free‑space and cache flushing machinery (H5SL_iterate → H5FScache_sinfo_serialize → H5Cgenerate_image → H5Cflush_single_entry → H5Cflush_ring → H5C_flush → H5F__flush_phase2 → H5Fdest → H5F_try_close). That chain makes the defect reachable during normal file close/flush operations. The upstream issue includes reproduction steps for building HDF5 with sanitizers and running an OSS‑Fuzz‑style harness to reproduce the crash deterministically.
Root cause (high level)​
The serialization routine writes address and section metadata into a serialization buffer using per‑field lengths derived from on‑disk metadata. The implementation assumes the caller reserved sufficient space but does not validate the buffer bounds before performing byte‑wise writes. When the input file contains malformed or adversarial length/offset values, the serialization loop can advance and write past the allocated buffer, producing a one‑byte out‑of‑bounds write to heap memory. That single byte overwrite is sufficient to corrupt heap metadata or adjacent heap objects, depending on allocation layout, enabling crashes and — under favorable allocator conditions — more serious exploitation. The GitHub report and reproduction harness make this flow explicit.
Why a one‑byte overflow matters​
One‑byte overflows are small but significant: they can alter a critical byte in heap metadata, size fields, or adjacent control structures. On older allocators or in predictable heap layouts, that can be leveraged for information disclosure or control‑flow hijack. Modern mitigations (ASLR, hardened allocators, RELRO/PIE, control‑flow integrity) make reliable remote code execution substantially harder, however — so public advisories are cautious, treating immediate impacts as denial‑of‑service and data corruption first, and potential RCE as speculative until demonstrated.
Evidence and proof‑of‑concept status​
  • Upstream GitHub issue: the reporter included a full sanitizer trace, build instructions and a small PoC harness demonstrating the crash when a malformed .h5 input is processed. The issue identifies the failing line and the stack backtrace.
  • Distribution trackers: Debian and Ubuntu have recorded the CVE and linked the upstream issue and related pull requests; Debian points to a specific pull request/commit intended to remediate related free‑space handling.
  • Third‑party vulnerability databases (NVD, Snyk, SUSE, INCIBE, Wiz, cvefeed) list CVE‑2025‑7067 with medium/low‑to‑medium severity scores and note that a PoC has been disclosed. These independent records corroborate the existence and mechanics of the defect.
Taken together, the PoC, sanitizer output and independent indexing show high confidence the bug exists and is reproducible (the “existence and mechanics” metric is strong). The remaining question for defenders is exploitation maturity: converting crash‑level evidence into reliable RCE remains environment‑dependent and unproven at scale in public writeups.
Affected scope and real‑world exposure​
Affected versions and package scope​
  • Canonical affected upstream release: HDF5 1.14.6. Public advisories and CVE entries list this release as containing the vulnerable code.
  • Distribution packaging: Several distributions shipped or packaged HDF5 builds derived from the 1.14.x line. Debian and Ubuntu trackers list their package statuses and note that some suites remain vulnerable until backports or patched packages are produced; the Debian tracker references the upstream issue and a fix commit. Administrators must verify their vendor package contains the upstream fix commit rather than assuming a later package version number always equals fixed status.
High‑risk deployment models​
  • Server‑side ingestion and preview services that accept arbitrary user uploads and parse .h5 files automatically (e.g., cloud ingestion, thumbnailing, preview generation).
  • Long‑running services or worker processes that open, process and flush many .h5 files (heap corruption in a long‑lived process increases the chance of exploitable conditions).
  • Statically linked binaries, vendor appliances or container images that bundle an unpatched HDF5 runtime (these require rebuilds to remediate).
  • Language bindings and prebuilt wheels (for example, h5py) that ship a bundled HDF5: wheels built with HDF5 1.14.6 embed the vulnerable runtime and must be rebuilt/replaced.
Desktop users who only open vetted .h5 data have lower immediate exposure, but the ubiquity of HDF5 in scientific ecosystems raises operational risk for research institutions and shared services.
Exploitability and risk analysis​
Likely immediate outcome: denial‑of‑service​
The most reliably reproducible impact is a crash — AddressSanitizer reproductions are available and demonstration PoCs produce deterministic crashes on vulnerable builds. For defenders, the priority is preventing service disruption and avoiding fleet‑level crashes engineered by attackers or fuzzers.
RCE: theoretically possible but unproven publicly​
Heap overflows are a traditional path to arbitrary code execution, but modern mitigations make exploitation non‑trivial. Public records and vendor advisories do not claim trivial, widely reproducible RCE from this particular CVE; they treat RCE as possible only given favorable allocator and runtime conditions (e.g., predictable heap layout, lack of ASLR, static linking, older allocators). Until independent exploit writeups demonstrate a working chain, RCE should be treated as speculative — defenders should not ignore the possibility, but should prioritize containment and patching to remove the primitive.
Confidence metric: high for existence, medium for exploit maturity​
  • Existence and mechanics: high confidence (ASAN trace, PoC, upstream issue and fixes).
  • Public exploit maturity: medium/low — only PoC-level evidence is public; no widely‑validated weaponized RCE has been published. This matches multiple tracker assessments.
Upstream fixes and vendor status​
Upstream maintainers accepted pull requests addressing the free‑space handling and added defensive checks. A specific PR and commit referenced by distribution trackers (commit ea4b483d…) addresses unlinking of the free‑space section on failure to update data structures and related defensive handling; the PR closes the GitHub issue when merged. Downstream distributors are mapping those commits into their packaging and backports; timelines differ by vendor and release. Administrators should confirm the presence of the upstream commit SHA or an explicit CVE mention in the package changelog. Vendor trackers (Debian, Ubuntu, SUSE, Snyk, INCIBE) list the CVE and either show pending status, backport work, or availability of fixed packages depending on the distribution and release. Some distributions mark the issue as “needs evaluation” or “postponed” for certain suites, underscoring that remediation timelines may vary.
Practical mitigation and remediation guidance​
Apply the following prioritized steps, ordered by speed and permanence:
Immediate (short term)​
  • Stop automatic processing of untrusted HDF5 files in high‑exposure services (disable ingestion, previews, auto‑conversion) until the runtime is confirmed patched.
  • Isolate HDF5 processing into sandboxed containers, VMs or separate privileged domains with strict limits to reduce blast radius.
  • Run processes that parse external files under least privilege and disable networking where possible for worker processes that only need file access.
  • Enable crash monitoring, alerting and automated quarantining of files that trigger crashes; collect core dumps for offline analysis (but handle cores as potentially sensitive).
  • If possible, enable memory safety instrumentation (ASAN, UBSAN) and run sample workloads in a testing environment to detect vulnerabilities in situ.
Medium term​
  • Deploy vendor or upstream patched packages that include the fix commits (verify the commit SHA or CVE reference in package changelogs). Do not assume arbitrary version numbers are fixed: confirm the patched commit is present.
  • Rebuild statically linked binaries, container images and wheels (e.g., Python wheels that bundle HDF5) using updated HDF5 builds.
  • Apply network and file access restrictions (e.g., virus/malware scanning, content restrictions) for services that accept external .h5 uploads.
Long term / hardening​
  • Use sandboxing, seccomp filters, restricted capabilities and process isolation for file parsers and previewers.
  • Employ runtime exploit mitigation suites (hardened allocators, CFI, RELRO/PIE).
  • Maintain an inventory of software and container images that embed HDF5; track third‑party wheels and packages to ensure they do not carry vulnerable HDF5 runtimes.
Detection and triage playbook​
  • Inventory: locate all installed HDF5 packages and verify versions; search for statically linked copies inside binaries and container images.
  • Verify: check package changelogs for inclusion of the upstream commit SHA (for example ea4b483d…) or explicit CVE mention. Distribution trackers often reference the upstream PR/commit required to confirm fixes.
  • Test: build a non‑production runner with sanitizers enabled and run known PoC inputs against local builds to confirm vulnerability presence/absence.
  • Monitor: watch for sudden upticks in crashes from processes that call HDF5; correlate crash stacks with H5FScache.c call frames.
  • Quarantine: isolate and preserve sample malicious files for offline analysis and reporting — but avoid running them on production systems.
Practical examples and special considerations​
  • Python ecosystems: prebuilt h5py wheels often embed the HDF5 runtime that was present at build time; users who installed h5py via pip/conda should verify the wheel’s bundled HDF5 version and update to rebuilt wheels that include patched HDF5. Container images used for data processing pipelines commonly include prebuilt HDF5; image rebuilds are required to remediate embedded runtime exposures.
  • HPC and research clusters: cluster images and module trees frequently contain statically linked or older HDF5 builds. Such environments have longer patch cycles; operators should prioritize node images and shared containers where untrusted inputs are processed.
  • Vendor embedded devices: appliances and vendor firmware that statically link HDF5 require vendor‑provided updates or rebuilds to fix the embedded library.
Strengths and limitations of the public record (critical analysis)​
Strengths / what is well‑supported​
  • The existence of the bug and its location within H5FScache.c is well documented in the upstream GitHub issue and reproduced under AddressSanitizer with a PoC harness; this provides high confidence in the defect’s mechanics.
  • Multiple independent vulnerability trackers and distribution advisories have indexed CVE‑2025‑7067, corroborating the disclosure and providing vendor‑specific remediation notes.
  • Upstream accepted pull requests and commit artifacts provide concrete remediation artifacts that downstream packagers can and should reference.
Limitations / risks and open questions​
  • Public advisories and trackers consistently note PoC and crash evidence but stop short of claiming trivial, widely exploitable remote code execution. The gap between a one‑byte overflow and a stable RCE chain depends on many environmental factors (heap allocator, memory layout, additional primitives), and public exploit maturity remains limited. Treat RCE statements with caution unless independent exploit writeups demonstrate them conclusively.
  • Distribution timelines differ: some OS suites remain marked “needs evaluation” or are scheduled for backports. Operators should not assume immediate package availability; verifying the exact package changelog and commit inclusion is essential.
  • The CVSS values vary across trackers; numeric scores differ because CNAs apply different weighting for attack vector, scope and impact. Numeric scores should inform triage but not replace context‑aware risk assessment.
Recommended actions for WindowsForum readers (concise checklist)​
  • Inventory: identify any tools, scripts, containers, wheels or appliances that embed HDF5 1.14.6.
  • Patch: apply vendor updates or rebuild artifacts that include the upstream fixes (confirm commit SHA or CVE mention in changelogs).
  • Contain: temporarily stop automated parsing of untrusted .h5 files in public ingestion endpoints until you confirm a patched runtime is in use.
  • Harden: sandbox file processing services, enforce least privilege, and enable crash monitoring to detect attempted exploitation.
  • Validate: run HDF5 builds with sanitizers and smoke test with PoC inputs only in isolated test environments to verify remediation.
Final assessment​
CVE‑2025‑7067 represents a concrete, reproducible heap‑based buffer overflow in HDF5 1.14.6 that is demonstrably exploitable for denial‑of‑service and heap corruption, with public sanitizer traces and a PoC available in the upstream issue tracker. Upstream fixes and corrective commits exist and have been referenced by distribution trackers, but downstream availability varies. While theoretical escalation to remote code execution is possible in specific environments, public materials do not demonstrate a trivial RCE chain; defenders should prioritize patching, containment and inventory to remove the primitive before an adversary can attempt a complex exploit chain.
A practical next step for administrators and developers is to compile a prioritized inventory of HDF5 usage across systems (binaries, wheels, containers), then plan immediate containment for any service that accepts untrusted .h5 files while coordinating upgrades or rebuilds that include the referenced upstream fixes.
