Windows 7 Help Me Pleasee !
brentjn
Your computer appears to be correctly configured, but the device or resource (DNS server) is not responding. When i diagonose my internet connection on my desktop it says that & this is causing my internet to respond slowly :(
Run command prompt and enter this command:
ipconfig /all >desktop/ipconfig.txt
Post the output file "ipconfig.txt" from your desktop on here and that should help us identify the problem.
You may need to change that command to: "ipconfig /all > %userprofile%/desktop/ipconfig.txt" if you want to create a text file on your desktop.
I doubt it - without %userprofile%/ it will default to the desktop for the calling user so should be superfluous but by all means try it if you have any problems.
