1/ I want to use some system tools, but i can find that folder by START->ALL PROGRAM->ACCESSORIES->..at here i can not find SYSTEM TOOLS icon
2/ I want to hide text next to the icon on QUICK LAUNCH bar.
You're on the right path. After clicking [accessories] you should see [system tools] right near the bottom of the submenu. It has been there all the time.
That is interesting.
I do not have that right click option??
The only way I have succeeded is by
1. Right click on empty section of the Taskbar, then select Properties.
2. Under Taskbar menu, go to Taskbar buttons dropdown box and change to Always combine, hide labels from either Never combine or Combine when taskbar is full.
