Windows 7 Help! My window 7 hibernate become lock screen!!!
serge327
My window 7 have some problem, when i put my window 7 to hibernate it became screen lock. Note: I really press Hibernate, no lock. Can someone help me to solve this problem.... Thx for the help....
I had the same thing happen to me even though I used Sleep or Hibernate. I guess the lock is used to protect your computer from other people messing with you files.
Go into Control Panel>Power Options>Advanced Power Options and disable the Password on Resume option.
