Help please major BSOD problem
Hi guys, getting BSOD at all kinds of times, tried many things but to no avail, here are the dump files on bluescreen event viewer
Dump File : 022011-91853-01.dmp
Crash Time : 20/02/2011 21:45:33
Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000008e
Parameter 1 : 0xc0000005
Parameter 2 : 0x82e494a0
Parameter 3 : 0x8d39b774
Parameter 4 : 0x00000000
Caused By Driver : ntkrnlpa.exe
Caused By Address : ntkrnlpa.exe+23e4a0
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16695 (win7_gdr.101026-1503)
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\022011-91853-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7600
Dump File Size : 140,064
Dump File : 022011-76549-01.dmp
Crash Time : 20/02/2011 20:38:46
Parameter 2 : 0x82e424a0
Parameter 3 : 0x8d197774
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+23e4a0
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\022011-76549-01.dmp
Major Version : 15
Dump File Size : 147,472
Dump File : 021711-149994-01.dmp
Crash Time : 17/02/2011 22:53:12
Parameter 2 : 0x82e534a0
Parameter 3 : 0x8ca4f774
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\021711-149994-01.dmp
Major Version : 15
Dump File Size : 144,232
Dump File : 021711-69685-01.dmp
Crash Time : 17/02/2011 22:03:31
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Parameter 2 : 0x82d043e1
Parameter 3 : 0x8d39ba60
Parameter 4 : 0x8d39b640
Caused By Address : ntkrnlpa.exe+bb3e1
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\021711-69685-01.dmp
Major Version : 15
Dump File : 021711-107952-01.dmp
Crash Time : 17/02/2011 21:56:06
Parameter 2 : 0x82d0f3e1
Parameter 3 : 0x8d58fa60
Parameter 4 : 0x8d58f640
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\021711-107952-01.dmp
Major Version : 15
Dump File : 021711-120042-01.dmp
Crash Time : 17/02/2011 21:49:48
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 0x000000a0
Parameter 2 : 0x00000002
Parameter 3 : 0x00000001
Parameter 4 : 0x82c8186c
Caused By Address : ntkrnlpa.exe+4681b
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\021711-120042-01.dmp
Major Version : 15
Dump File : 021511-52119-01.dmp
Crash Time : 15/02/2011 12:59:55
Parameter 2 : 0x82e584a0
Parameter 3 : 0x8d5cb774
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\021511-52119-01.dmp
Major Version : 15
Dump File : 091610-33087-01.dmp
Crash Time : 16/09/2010 18:30:51
Bug Check String : KERNEL_DATA_INPAGE_ERROR
Bug Check Code : 0x0000007a
Parameter 1 : 0x00000020
Parameter 2 : 0xc000009d
Parameter 3 : 0x87f347c4
Caused By Address : ntkrnlpa.exe+832f4
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\091610-33087-01.dmp
Major Version : 15
Dump File Size : 150,408
Dump File : 091310-35271-01.dmp
Crash Time : 13/09/2010 14:07:09
Parameter 1 : 0xc07f44c0
Parameter 3 : 0x38fdc8c0
Parameter 4 : 0xfe898320
Caused By Address : ntkrnlpa.exe+dcd10
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\091310-35271-01.dmp
Major Version : 15
Dump File : 091210-56019-01.dmp
Crash Time : 12/09/2010 11:15:53
Parameter 3 : 0x87ddf044
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\091210-56019-01.dmp
Major Version : 15
Attached the zip file as requested, unfortunately could only run from admin acc on this comp, hopefully it still shows the problems
Can I see your crash dumps from C:\Windows\Minidump folder ?
here are the files
Wow, that's quite a few of crashes! I am impressed.
1. PCTools is a bad idea when Symantec Norton is running alongside.
- Uninstall PCTools
- Then if crashes persist, uninstall Norton too
Download and run the Norton Removal Tool to uninstall your Norton product | Norton Support
https://www.microsoft.com/security_essentials/
2. Update Intel Gigabit Adapter
e1k6232.sys Mon Jun 22 14:04:20 2009
Intel® Driver Update Utility
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021711-107952-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x86 compatible
Built by: 7600.16695.x86fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0x82c54000 PsLoadedModuleList = 0x82d9c810
Debug session time: Thu Feb 17 16:53:08.169 2011 (UTC - 5:00)
System Uptime: 0 days 0:05:32.558
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1000007E, {c0000005, 82d0f3e1, 8d58fa60, 8d58f640}
Probably caused by : ntkrpamp.exe ( nt!RtlImageNtHeaderEx+4a )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 82d0f3e1, The address that the exception occurred at
Arg3: 8d58fa60, Exception Record Address
Arg4: 8d58f640, Context Record Address
Debugging Details:
FAULTING_IP:
82d0f3e1 663902          cmp     word ptr [edx],ax
EXCEPTION_RECORD:  8d58fa60 -- (.exr 0xffffffff8d58fa60)
ExceptionAddress: 82d0f3e1 (nt!RtlImageNtHeaderEx+0x0000004a)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000000
   Parameter[1]: 7ffa0000
Attempt to read from address 7ffa0000
CONTEXT:  8d58f640 -- (.cxr 0xffffffff8d58f640)
eax=00005a4d ebx=89cfc244 ecx=00000000 edx=7ffa0000 esi=00000000 edi=8d58fb3c
eip=82d0f3e1 esp=8d58fb28 ebp=8d58fb28 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
nt!RtlImageNtHeaderEx+0x4a:
82d0f3e1 663902          cmp     word ptr [edx],ax        ds:0023:7ffa0000=????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  00000000
EXCEPTION_PARAMETER2:  7ffa0000
READ_ADDRESS: GetPointerFromAddress: unable to read from 82dbc718
Unable to read MiSystemVaType memory at 82d9c160
 7ffa0000
FOLLOWUP_IP:
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from 82d13484 to 82d0f3e1
STACK_TEXT:
8d58fb28 82d13484 00000000 00000000 89cfc008 nt!RtlImageNtHeaderEx+0x4a
8d58fb5c 82c6bc95 859ff468 00000000 00000004 nt!RtlImageNtHeader+0x1a
8d58fc18 82c22ba9 89cfc008 00000000 8d58fc60 nt!EtwpCCSwapTrace+0x433
8d58fd00 82cc203b 80002930 00000000 859dd4c0 hal!KfLowerIrql+0x61
8d58fd50 82e629df 00000001 a00e5b57 00000000 nt!ExpWorkerThread+0x10d
8d58fd90 82d141d9 82cc1f2e 00000001 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!RtlImageNtHeaderEx+4a
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc78ed4
STACK_COMMAND:  .cxr 0xffffffff8d58f640 ; kb
FAILURE_BUCKET_ID:  0x7E_nt!RtlImageNtHeaderEx+4a
Drivers:
start    end        module name
957d4000 95800000   1394ohci 1394ohci.sys Mon Jul 13 19:51:59 2009 (4A5BC89F)
834ba000 83502000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
92903000 9295d000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
93400000 93412000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
833ad000 833b6000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
83400000 83409000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
83409000 8342c000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
95018000 95638000   atikmdag atikmdag.sys Tue Aug 03 21:35:57 2010 (4C58C3FD)
9358a000 935c3000   atikmpag atikmpag.sys Tue Aug 03 21:15:28 2010 (4C58BF30)
8b95a000 8b961000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
934ab000 93557000   BHDrvx86 BHDrvx86.sys Mon Nov 15 17:35:02 2010 (4CE1B596)
9349d000 934ab000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
832aa000 832b2000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
96b8e000 96ba7000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
9341e000 9349d000   ccHPx86  ccHPx86.sys  Fri Feb 05 15:57:22 2010 (4B6C8632)
9a790000 9a7ae000   cdd      cdd.dll      unavailable (00000000)
8b8b4000 8b8d3000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
832f4000 8339f000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
8b85c000 8b881000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
832b2000 832f4000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8b5a2000 8b5ff000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
935ec000 935f9000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
98993000 989a0000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
92f54000 92fb8000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
92fb8000 92fd0000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
92f48000 92f54000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
8b84b000 8b85c000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
9897a000 98993000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
989a0000 989ab000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
989b5000 989c6000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
989ab000 989b5000   dump_msahci dump_msahci.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
8b881000 8b88b000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
95638000 956ef000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:37:53 2010 (4CCF7981)
956ef000 95728000   dxgmms1  dxgmms1.sys  Wed Feb 02 22:34:49 2011 (4D4A2259)
95747000 9577a000   e1k6232  e1k6232.sys  Mon Jun 22 14:04:20 2009 (4A3FC7A4)
92eea000 92f48000   eeCtrl   eeCtrl.sys   Fri May 21 17:44:53 2010 (4BF6FED5)
96a31000 96a5b000   fastfat  fastfat.SYS  Mon Jul 13 19:14:01 2009 (4A5BBFB9)
8366e000 8367f000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8350b000 8353f000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8b40e000 8b417000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8b819000 8b84b000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
8b74e000 8b77f000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
935dd000 935e2280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
82c1d000 82c54000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
95728000 95747000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
988fb000 9894b000   HdAudio  HdAudio.sys  Mon Jul 13 19:51:46 2009 (4A5BC892)
8b800000 8b813000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
989f6000 989fc480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
8b91a000 8b925000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
96b09000 96b8e000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
8b427000 8b42f000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
92e8f000 92eea000   IDSvix86 IDSvix86.sys Fri Nov 05 17:11:46 2010 (4CD47312)
93578000 9358a000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
8b92a000 8b949000   Ironx86  Ironx86.SYS  Tue Apr 27 20:47:15 2010 (4BD78593)
935c3000 935d0000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8b88b000 8b897000   kbdhid   kbdhid.sys   Mon Jul 13 19:45:09 2009 (4A5BC705)
8726a000 87272000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
98807000 9883b000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
8b58f000 8b5a2000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
833b6000 833db000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
96a90000 96aa0000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
96a5b000 96a76000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
83221000 83299000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
8b8a2000 8b8ad000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
935d0000 935dd000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8b897000 8b8a2000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
835e8000 835fe000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
96ba7000 96bb9000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
96bb9000 96bdc000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
9fa03000 9fa3e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
9fa3e000 9fa59000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
8342c000 83436000   msahci   msahci.sys   Mon Jul 13 19:45:50 2009 (4A5BC72E)
8b9b3000 8b9be000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
8353f000 83547000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8b564000 8b58f000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
92e85000 92e8f000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8b417000 8b427000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
83707000 837be000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
93412000 9341d000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
96ae6000 96af6000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
92e00000 92e22000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
988ea000 988fb000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
929df000 929ed000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
9295d000 9298f000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
837be000 837fc000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
8b9be000 8b9cc000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
92e7b000 92e85000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
82c54000 83064000   nt       ntkrpamp.exe Tue Oct 26 22:30:44 2010 (4CC78ED4)
8b435000 8b564000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
98800000 98807000   NuidFltr NuidFltr.sys Fri May 08 04:35:42 2009 (4A03EEDE)
8b953000 8b95a000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
96aa0000 96ae6000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
9299f000 929be000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
8357c000 8358d000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
83547000 83571000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
8339f000 833ad000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
8367f000 836b8000   PCTCore  PCTCore.sys  Sun Mar 28 18:47:11 2010 (4BAFDC6F)
928af000 928e5f00   pctgntdi pctgntdi.sys Thu Feb 04 13:33:31 2010 (4B6B12FB)
9fbe0000 9fbef780   pctplsg  pctplsg.sys  Thu Apr 08 00:29:33 2010 (4BBD5BAD)
928e6000 92903000   PctWfpFilter PctWfpFilter.sys Thu Feb 04 13:41:56 2010 (4B6B14F4)
8b400000 8b40e000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
9fa71000 9fb08000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
9894b000 9897a000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
83299000 832aa000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
92fd0000 92fe8000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
92e22000 92e3a000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
92fe8000 92fff000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
92810000 92827000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
92e3a000 92e7b000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
92827000 92831000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
8b99b000 8b9a3000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8b9a3000 8b9ab000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8b9ab000 8b9b3000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
8b7cf000 8b7fc000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
96af6000 96b09000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
9fb08000 9fb12000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
8b7c7000 8b7cf000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
8b949000 8b952080   SRTSPX   SRTSPX.SYS   Wed Feb 24 18:55:07 2010 (4B85BC5B)
9fb8f000 9fbe0000   srv      srv.sys      Thu Aug 26 23:31:26 2010 (4C77318E)
9fb40000 9fb8f000   srv2     srv2.sys     Thu Aug 26 23:30:45 2010 (4C773165)
9fb12000 9fb33000   srvnet   srvnet.sys   Thu Aug 26 23:30:39 2010 (4C77315F)
935f9000 935fa380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
83618000 8366e000   SYMDS    SYMDS.SYS    Mon Aug 17 19:34:39 2009 (4A89E90F)
836b8000 836e5000   SYMEFA   SYMEFA.SYS   Wed Apr 21 17:46:52 2010 (4BCF724C)
9288a000 928af000   SYMEVENT SYMEVENT.SYS Thu Aug 13 18:22:41 2009 (4A849231)
92831000 9288a000   SYMTDIV  SYMTDIV.SYS  Tue May 04 00:29:10 2010 (4BDFA296)
8b605000 8b74e000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
9fb33000 9fb40000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
8b9e3000 8b9ee000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8b9cc000 8b9e3000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
92800000 92810000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
836e5000 836f6000   TfFsMon  TfFsMon.sys  Mon Feb 01 13:56:36 2010 (4B6723E4)
836f6000 83707000   TfSysMon TfSysMon.sys Mon Feb 01 13:56:44 2010 (4B6723EC)
9a760000 9a769000   TSDDD    TSDDD.dll    Mon Jul 13 20:01:40 2009 (4A5BCAE4)
93557000 93578000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
9883b000 98849000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
989c6000 989dd000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
9886e000 9886f700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
9577a000 95789000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
988a6000 988ea000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
95789000 957d4000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
989eb000 989f6000   usbprint usbprint.sys Mon Jul 13 20:17:06 2009 (4A5BCE82)
98861000 9886e000   usbrpm   usbrpm.sys   Mon Jul 13 20:14:30 2009 (4A5BCDE6)
989dd000 989eb000   usbscan  usbscan.sys  Mon Jul 13 20:14:44 2009 (4A5BCDF4)
95000000 95017000   USBSTOR  USBSTOR.SYS  Mon Jul 13 19:51:19 2009 (4A5BC877)
83571000 8357c000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8b961000 8b96d000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8b96d000 8b98e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8b77f000 8b787380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
8358d000 8359d000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8359d000 835e8000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8b788000 8b7c7000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
98870000 988a6000   vpchbus  vpchbus.sys  Tue Sep 22 21:18:06 2009 (4AB9774E)
929cf000 929df000   vpcnfltr vpcnfltr.sys Tue Sep 22 21:18:04 2009 (4AB9774C)
98849000 98861000   vpcusb   vpcusb.sys   Tue Sep 22 21:18:08 2009 (4AB97750)
8b8d3000 8b919880   vpcvmm   vpcvmm.sys   Thu Dec 31 01:47:17 2009 (4B3C48F5)
929be000 929cf000   vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3)
929ed000 92a00000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8b98e000 8b99b000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
8343b000 834ac000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
834ac000 834ba000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
92998000 9299f000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
9a500000 9a74b000   win32k   win32k.sys   Tue Jan 04 22:37:16 2011 (4D23E76C)
935e3000 935ec000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
83502000 8350b000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
9298f000 92998000   ws2ifsl  ws2ifsl.sys  Mon Jul 13 19:55:01 2009 (4A5BC955)
96a76000 96a90000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
Unloaded modules:
96a00000 96a21000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00021000
96bdc000 96bfd000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00021000
9fa59000 9fa71000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8b881000 8b88e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8b88e000 8b899000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000B000
8b899000 8b8a3000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000A000
8b8a3000 8b8b4000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
95000000 95018000   i8042prt.sys
    Checksum:  00000000
    ImageSize:  00018000
8b8d3000 8b92a000   SRTSP.SYS
    Checksum:  00000000
    ImageSize:  00057000
