dammyshaggs
Dear All,
I have an issue with windows 10 .I have upgraded to windows 10 from windows 8.1. After Upgraded only im facing these kind of issue
.Details :
When i right click any of the file or if i copy - paste any of the file - if i double click any of the installed app icons ,the file will go to recycle bin .
Folders just get automatically deleted
Error shows
2 uninterrupted actions :
Could not find this item ...
Are there programs/adds left over from the 8.1 upgrade i.e. WinHotKey?
If so I would suggest reinstalling Windows from All Settings - Update and Security - System Restore without leaving / saving anything
Screenshots would help. Start with what you see when you return to your computer in the morning, then show what you do and the results.
Sent from my iPhone using Tapatalk
I would suggest booting to safe mode. If the behavior is gone then it's either software or malware.
