- Thread Author
- #1
Cant connect to web using Dlink DPR1260. I connect a desktop (wired) to dlink this is wireless to netgear router.
Things that work. If I move PC to other room and hardwire to Netgear all is fine. Can down load printer driver for printer that is connected to the Dlink.
I have the PC set to Static IP for both PC and Dlink. DHCP gave the exact same results.
PC shows connected to net.
Problems: If I open IE8 by default it opens MSN. This errors out. But if I type in Google.com it opens and I can read all header in Google ONLY.
If I open a CMD prompt I can ping google with not loss packets. If I ping MSN it timesout everytime.
I cannot donwload any updates for windows 7. This is a fresh install, No adobe, No Office, Just standard install with Harddrive formatted prior to install.
Now I have had this Dlink print server for a couple of years now without any problems running WinXP Pro 32 bit.
This problem is with either 32 or 64 bit Win 7.
Please if you have an Idea post. I have been reading and reading to no avail.
HELP
racinj
HELP
racinj
