Help with BSOD - Memory Error? Changed Memory - still crashes, but less
Help. MiniDump Attached.
Navigate to C:\Windows\System32\drivers and delete:
PxHlpa64 PxHlpa64.sys Wed Mar 12 21:58:17 2008
Reboot and run Ccleaner to clean the registry.
Uninstall Kaspersky in safe mode using the tool found here:
AV Uninstallers - Windows 7 Forums
Reboot and install MSE.
Thank you. I'll try your suggestions and post back here.
Not sure why to remove Kaspersky and replace with Microsoft Security Essentials - but will try.
You have to remove Kaspersky because it was causing your crashes. It should have been obvious enough since I posted to do so, but anyhow, enjoy. :)
