I have a Gigabyte X570 Aurous Master mobo. PC health check says that my PC can't run Win 11 because I don't have secure boot. I've looked in the BIOS (under Boot menu) and I don't see secure boot anywhere.
Would anyone know, does the Gigabyte X570 Aurous Master support secure boot?
yes it does
there are a lot of bios updates for that old board but before flashing anything go into your bios; in advanced, normally under the settings tab look for something like "Platform Trust Technology" [sometimes its just PTT] and enable it
ok yours is the Amd board, yes you have ftpm turned on... if you click the "trusted computing 2" do any options pop up?
also what CPU chip is installed?
This specification details the AMD processors that can be used with Windows 11 customer systems that include Windows products, including custom images.
the processer is fine for w11 and your board has its firmware turned on to let Microsoft hack into your chip so it should take the upgrade
now post the boot tab please temp disable CSM if its enabled
