XwXSpaWnXwX
The following issues are preventing Windows from upgrading. Cancel the upgrade, complete each task, and then restart the upgrade to continue.
Upgrading Windows will affect the following devices and/or programs:
Not sure how to uninstall PowerShell its not in the Add/Remove and I don't really get why this would be a problem.
[*]For these items, make the following changes:
- Uninstall these programs. Open Control Panel and search for "uninstall a program".
[*]Windows PowerShell
- These programs might not work properly after the upgrade. We recommend uninstalling these programs before upgrading. Cancel the upgrade, open Control Panel, and search for "uninstall a program".
[*]Daemon Tools
