windows10disaster
- Joined
- Aug 7, 2015
- Messages
- 3
- Thread Author
- #1
Holding down any key for several seconds and then releasing it makes a jingle sound. After which, Windows treats the key as being held down until the same key is pressed again.
For example, if I hold down control long enough and then release, I can zoom in/out using the scroll wheel by itself (ctrl + scroll wheel). Sticky, filter, and toggle keys are off.
I Never had this problem on Windows 7.
