Windows 8 How delete a partition?
gianniscfa
Well-Known Member
Hello, i have windows 8 64bit.. i have 1 partition D 186gb.. my HDD is 500gb.. i want to merge the D partition but i cant, i have try with all programms for partitions but this not fix my problem.. please help me, i dont have space..
You would of had to manually create all those partitions. I would delete all 4 on the right (F, New, New, D) then you can merge that space into the C drive. You can't merge non-contiguous space in Windows. The first two partitions (New volume, and the small one) would have had to been created during install and don't need to be there, but you would need to boot into something like a live linux disc and use gparted to get rid of those and reclaim that space, or do a clean install of Windows.
I was referring to the 2MB one, that's probably nothing. An EFI partition should say EFI System Partition. I'm really curious how this computer was partitioned because it sure wasn't from the Windows install media.
The other thing I see is the disk is dynamic so there can be up to 2000 volumes even if the disk is using an MBR version GPT partitioning scheme.
Good point. I'm guessing something like gparted partitioned the disk. I'd be reinstalling if my partitions were like that.
The one small one just before C: is for EFI boot. Removing that would be an awful idea. The others ot the right, I'd just delete the volumes and then expand inot the unused space.
Maybe the problem is that the partitions is dynamic. some programs tell me that can't be done because the partition is dynamic...I couldn't change them from dynamic to basic..
