VIDEO How to Build a Gaming PC in 2022
whoosh
Cooler King
:curious:
How to Build a Gaming PC in 2022 - A Comprehensive Guide for Windows Users For Windows enthusiasts and gamers interested in constructing their own gaming PCs, Austin Evans' video titled How to Build a Gaming PC in 2022 provides an in-depth walkthrough. This tutorial is particularly relevant given the current trends in PC gaming and hardware.
Key Takeaways from the Video​
  • Starting with the Graphics Card: The video recommends selecting a graphics card first. The current choice is the MSI RTX 3060, but AMD options are also viable. This strategy caters to the ongoing graphics card shortages, emphasizing the importance of choosing one that fits your budget and availability.
  • Choosing the Right CPU: Following the graphics card, picking a compatible CPU is crucial. For gamers, a mid-range CPU like the Intel Core i5 is often sufficient. However, for those who plan on extensive gaming or creative tasks, upgrading to a Core i7 can be beneficial.
  • Motherboard Selection: The motherboard must support the chosen processor. It’s essential to verify compatibility with the socket type (like 12th Gen Intel). The tutorial highlights the importance of selecting the correct size (ATX, microATX, etc. based on your case.
  • RAM and Storage Considerations: Austin suggests aiming for at least 16GB of RAM and highlights the efficiency of SSDs over traditional hard drives. The focus is on utilizing M.2 SSDs for faster boot and load times, specifically featuring the Samsung 980 PRO.
  • Cooling Solutions: Whether using a stock cooler or opting for a more advanced AIO liquid cooler, ensuring adequate cooling is crucial. The tutorial explains how to properly install both types.
  • Power Supply Requirements: The wattage of the power supply should tend to be around 750W to ensure sufficient power for future upgrades. The importance of 80 PLUS certification is also stressed to guarantee efficiency.
  • Installing Components: The video provides a step-by-step on how to fit components into the case, stressing the merits of proper cable management and installation order to avoid headaches later.
  • BIOS Configuration: Once assembled, participants are led into the BIOS to set up the machine, ensure recognition of all components, and adjust settings for optimal performance.
    For Windows users looking to build or upgrade their PC, this video serves as a solid foundation. Understanding the components and their interactions is vital, especially considering the variety of tasks a gaming system might need to handle. Moreover, with Windows 11's introduction of features that leverage modern hardware capabilities, users are encouraged to opt for the latest operating systems to maximize performance.
    Austin Evans’ How to Build a Gaming PC in 2022 is not just a tutorial; it’s a gateway for Windows Forum community members to demystify the building process. Whether you’re a seasoned builder or a newbie, the insights shared in this video can greatly enhance the overall experience of assembling your own PC. Integrating high-performance hardware with Windows can lead to a seamless and enjoyable gaming experience. For more resources, including links to components discussed in the video, check the description within the YouTube video. Happy building!
