Windows 7 How to change BootManager entry for USB Flash Drive?
pstein
I have a couple of USB Flash Drives which contain different bootable systems.
When I plugin the USB falsh drives into the USB ports of my mainboard, boot my computer and let BootManager show up then they all appears as "Sandisk Cruzer"
So it is difficult to distinguish between them.
Is there a way to change the BootManager entries and rename them e.g. to "mytoolsusb1"
"backupusb2",....
This renaming should be done (if possible) with changes from USB flash drive (not from BootManager).
So that the changed name appear an other computers as well.
How can I achieve this?
Peter
livix07
Honorable Member
I don't know if it is possible to do that but don't you think it would be better if you only connected one USB flash drive at a time?
