VIDEO How To Fix Asus Computer Boot Loop, Stuck Loading, Stuck Diagnosing PC, Stuck Automatic Repair
whoosh
Cooler King
:curious:
How to Fix Asus Computers Stuck in Boot Loop Issues: A Comprehensive Guide If you're encountering boot loop issues with your Asus laptop, you are not alone. Many users face problems like being stuck on the initial startup logo, continuous restarts, or halting at diagnosing PC messages. Fortunately, a recent video sheds light on how to troubleshoot and resolve these issues effectively.
Key Points from the YouTube Video​
The video titled, "How To Fix Asus Computer Boot Loop, Stuck Loading, Stuck Diagnosing PC, Stuck Automatic Repair," provides a step-by-step guide for users dealing with boot failure scenarios. Here’s a summary of the main troubleshooting steps covered:
  1. Remove External Devices:
    • The first recommendation is to disconnect all external devices, including USB drives and CDs. Sometimes, the system attempts to boot from these devices and gets stuck.
    []Accessing the BIOS:
    • If the laptop doesn’t start properly, the next step is to access the BIOS settings. This is typically done by powering on the laptop and repeatedly pressing the Delete key. Ensure the computer is completely shutdown before attempting this.
    ]Check System Time and Date:
    • Within BIOS, check if the system date and time are set correctly. An incorrect system time can cause various start-up issues. Adjust as necessary, save changes, and restart.
    []Switch Boot Options:
    • Users should confirm if the boot mode is set to UEFI or Legacy (CSM). If one is enabled, try switching to the other. This can vary based on how the operating system was installed.
    ]Operating System Check:
    • If the issue persists, it might be due to a corrupt operating system. The video recommends trying to reinstall Windows. If that works, you'll have solved a software issue. If the installation fails again, turned it may suggest a hardware fault.
  2. Hard Drive Troubleshooting:
    • Ultimately, if the operating system fails to install correctly and you suspect hardware issues, consider replacing your hard drive if necessary.
      Relevance for Windows Users​
      This guide is particularly significant for Asus users but can offer insight that may be applicable to other brands as well. Problems like these can be frustrating, especially when your laptop becomes unresponsive during critical moments. Understanding how to access BIOS, check system settings, and differentiate between software and hardware issues is essential knowledge for all Windows users.
      If you're stuck in an Asus boot loop, these troubleshooting techniques could lead to a resolution. It's a straightforward DIY approach that can save time and eliminate anxiety. Don't hesitate to consult the video for more detailed instructions, and follow the steps carefully. For more troubleshooting tips and community discussions, feel free to engage with fellow members of WindowsForum.com!
