VIDEO How to Fix Screen Flickering Problem on Windows 11
How to Fix Screen Flickering Problem on Windows 11 In a recent tutorial from YouTube, the content creator addresses a common issue for Windows 11 users: screen flickering. This video is particularly timely as it provides step-by-step troubleshooting to resolve this frustrating problem that many have encountered, especially after system updates or driver changes.
Key Topics Covered​
  1. Understanding the Issue: The video begins by stating that screen flickering can manifest as visual glitches or artifacts, particularly noticeable during gaming or even when navigating the desktop. The presenter mentions having experienced flickering upon their return from a holiday, hinting at potential driver-related issues or glitches introduced in recent updates.
  2. Using Display Driver Uninstaller (DDU): The presenter recommends using DDU, a tool designed to completely remove graphics drivers and any remnants that might cause performance issues:
    • Downloading DDU: Viewers are guided through downloading this utility and extracting it for use.
    • Backup in Safe Mode: A significant point made is the necessity of running DDU in safe mode to ensure all processes that may interfere with driver removal are halted.
  3. Updating Windows: Before diving into driver uninstallation, checking for and installing Windows updates is advised. The presenter underscores the importance of keeping the operating system updated to potentially resolve known issues.
  4. Installing New Graphics Drivers: After safely uninstalling the old graphics drivers:
    • Users are encouraged to download the relevant new graphics drivers (NVIDIA, AMD, or Intel).
    • The installation process is straightforward, yet the video provides an excellent walkthrough to avoid common pitfalls like incorrect driver selection.
  5. Testing the Graphics Card: Following the driver installation, the creator suggests stress-testing the graphics card using software like FurMark. This step is crucial for diagnosing whether flickering is due to a hardware failure or remains a software issue.
  6. Final Adjustments: The video rounds up with advice on ensuring display settings (resolution and refresh rate) are configured correctly, as improper settings can also lead to screen flickering.
    Conclusion and Community Engagement​
    The video is a valuable resource for anyone facing graphics issues on Windows 11, consolidating both troubleshooting and preventive strategies. By systematically addressing driver issues and keeping the system updated, users can significantly reduce the likelihood of screen flickering. If you've faced similar issues or have tips of your own, feel free to share your experiences or ask questions! Have you tried any of the methods discussed in the video? What worked for you? Let's discuss!
