The thread discusses methods to identify which applications are currently accessing the camera and microphone on Windows, with suggestions including using antivirus features, Task Manager, and Process Explorer, while noting the absence of a direct registry solution. The original poster seeks alternative approaches beyond built-in settings, and responses recommend various tools and caution about system risks. Later comments briefly touch on recording meetings without permission, highlighting privacy concerns.
simonenitron90
Hello Everyone,
I am curious to know which application using my camera and micophone currently?
Most of the anivirus like avast, norton,Kaspersky they are having the feature called "webcam Protection", in that they can easily showing that,
I know in windows setting>privacy & Security we have the option to see. is there any other way without usesing this settings options ?
Is there a rigistry path to check which application surrently using the WindowsCamera.exe or FrameServer.dll?
Hi, You're right, many Anti-virus programs like Avast, Norton, Kaspersky, etc. include features that show which applications are currently accessing your webcam. But you may also use the Windows Task Manager or a third-party software like Process Explorer to get this information if you want multiple ways to check this. Windows Task Manager:
  • Open Task Manager by pressing Ctrl + Shift + Esc.
  • Click on More Details to expand the Task manager.
  • Go to the Performance tab and select Webcam in the sidebar. This will display all the applications that are currently using your webcam. Process Explorer:
  • Download and install the Process Explorer tool from the Microsoft website.
  • Run...
  • Run Process Explorer as an administrator.
  • Go to Find > Find Handle or DLL.
  • In the Handle or DLL substring: box, type in WindowsCamera.exe or FrameServer.dll, and click on 'Search'. This will pull up a list of processes that are currently using these files. As for your other query regarding the registry path, there isn't a direct registry key which shows which application is currently using the WindowsCamera.exe or FrameServer.dll. But, you can use the steps above to find that information. Remember to use these tools carefully, as they provide detailed information about your system’s processes and changing something mistakenly can cause serious issues with your system. I hope this helps! Let me know if you have any other questions.
Monika AA
I know that Google Meet with the Bluedot Chrome extension can record a meeting without permission. But for the most part, the company records meetings only by appointment and does not provide access to them. In principle, we can use this software How To Record A Google Meet Without Permission in 2024 ourselves to record the screen. However, this will not result in recording the audio of other meeting participants.
