- Thread Author
- #1
Hi every one,
I tried to find solution to my question but didn't help much. so I'm starting ne.w thread.
I already have Home premium installed on my laptop. I want to upgrade to win 7 pro.
the windows tool " upgrade any time " doesn't help me because I already have the disk.
what should I do just paste the new win 7 pro key or i've to go for new fresh install.
I don't wanna loose my data.
Thanks
Thanks
- Joined
- May 16, 2010
- Messages
- 5,703
- Joined
- Oct 16, 2009
- Messages
- 15,156
- Thread Author
- #4
- Thread Author
- #5
I got a strange error while installing it. I boot it from DVD room as soon as i click install now i get this error " A required CD/DVD drive device drive is missing. IF you have a drive flppy disk, cd, USB. bla bla
NOTE: if the windows installation media is the CD/DVD drive you can safely remove it.
any help
any help
- Thread Author
- #6
ya were right mate,
It's just a bazaar, first i had problem with cd room detection n then made another ISO which fixed the issue it was bad burning Image. As I tried to install it gives another error " use " upgrade any time in order to move from one OS version to another OS. It simply means waste of Bandwidth.
I spent time downloading the ISO now to upgrade I've to waste some more bandwidth. so ridiculous why they Make the ISO file in first place
- Joined
- Oct 16, 2009
- Messages
- 15,156
- Joined
- May 16, 2010
- Messages
- 5,703
- Thread Author
- #9
Thanks every one,
I successfully installed windows 7 a clean install. Every thing seems fine. My great concern was Virtual PC. Every one is complaining that they can't install or run virtual PC. I've no any problem running virtual PC on 64 bit Win 7 pro. Neither I had problem in windows 7 home premium. I just downloaded virtual pc 2007 64 bit. I don't need to download windows xp mode
wo ho...I love my laptop...
- Joined
- May 16, 2010
- Messages
- 5,703
w7pro
Banned
- Joined
- May 17, 2010
- Messages
- 53
Thanks every one,
Hi Her0,
Glad to hear that you installed everything just fine. After you've installed XP Mode, there is a video at Link Removed due to 404 Error that explains how to install your older applications.
Ahmad A
Windows 7 Professional Outreach Team
