How will I add W7 over the evaluation copy?
Discussion in 'Windows 7 Installation' started by dusty, Oct 21, 2009.
  1. dusty
    dusty New Member
    Oct 20, 2009
    2
    0
    I have W7 evaluation copy 7100 on my laptop and base computer. They are a joy to use and work extremley well. I read horror stories about upgrades and new appliciations of W7 giving all types of problems. I have not had anything other then normal hicups with my two copies. I am only concerned with the HOW do I setup W7 and COST, which seems to be excessively high.
    My questions is this. How will I add newly released W7 over the old 7100 evaluation copy I now have? Will it be an upgrade or a completley new OS? What will my cost be and what selections will I have?
    dusty
  2. BAD311
    BAD311 New Member
    Oct 21, 2009
    2
    0
    I'd like to know the same thing. I have Win7 RC1 (Build 7100) and will be putting on my Win7 Ultimate when it arrives from the company store tomorrow.
  3. busydog
    busydog New Member
    Feb 11, 2009
    1,056
    31
    There are folks that will advocate a clean install and that you can't do what you want to do. If you do a search for cversion.ini (in this forum or elsewhere), you will get the guidance you need.
Share This Page
Loading...
